Question about Daewoo DP42SM 42 in. HD-Ready Plasma Television
Components are not working
When I hook up the cable or the DVD to Component 1 or 2 the picture is like a scrambled purple and black color. I can see the broadcast but it has a lot of this purple and black interference. Please advise
  • pamela white Sep 08, 2008
    when I turn on the tv purple and black lines appear. They go a way when the tv seems to warm up. what is happening? Is the tv going out or what?
  • pamela white May 11, 2010
    what causes the purple lines?
    Genius:
  • 1,139 Answers
Hello pam_white53,
I have seen this in my shop, on one set I had to replace the panel, on another set it was the data IC connector (flexboard) causing the problem. I would suspect the panel more so.
I would suggest that yoy get this looked at by a qualified TV technician due to the fact that it may be the panel causing this problem.
I hope this helps
Thank you,
Shuttle83
Posted on Sep 11, 2008
This is a new system, however, when I first hook up the system up, I got a good clear color picture, but no audio, just buzzing, I changed my wire connection around, and I got the volume and picture, but I...
i would hook it up via an optical cable for audio or left and right rca cable for audio and try and stick with components for the video should solve the problem. the no color means if you are using a component cable you have put them in wrong. the blue and green look alot alike ihave messed up before. also i did some research on this model. i have heard some people running into these problems no matter how they hooked it up. hdmi the way to go tho.
Mar 14, 2011 | Memorex MVD2016 DVD Player
Ihave a bose 321gsx, I want to hook up my hdtv . ,blue ray dvd and vcr. Brain is frozen right now. Could use some help.
How to Connect an HDTV to a DVD Player
Hooking up a DVD player to an HDTV, or high-definition TV, is just as simple as hooking one up to a standard-definition TV. While a regular DVD player may be hooked up to an HDTV, it does not necessarily mean it will have high-definition quality picture. Unless a Blu-Ray player is connected to the HDTV, only a standard-definition picture will be shown.
Things You'll Need:
* Component cables
Instructions
Turn off and unplug the HDTV set and the DVD player before attempting to connect component cables to them.
Match the red, green and blue colored cables to each of the color-coded counterparts on the back of the DVD player. Be sure the cables are being plugged into the TV-out section of the DVD player.
Plug the other end of the color coded cables into the HDTV set. There should only be a red, green and blue cable being plugged into the TV. It does not matter what input these cables are plugged in, but keep track of which particular one it is. Most HDTV sets will have more than one A/V input, which is why it's important to take note of where the component cables are located.
Power on the DVD player and the HDTV set. If not already plugged in, ensure both of these are properly plugged into an outlet.
Press the "Source" button using the HDTV remote and locate the input channel that has the component cables plugged into it. The HDTV set should now show the DVD player logo or an introduction to the DVD.
Do not purchase HDTV component cables to hook up a regular DVD player to an HDTV set. Unless using a Blu-Ray player, only standard component cables are required. HDTV sets consume a lot of energy and should be plugged directly into an electrical outlet rather than a power strip.
Turn off all electronics before connecting and disconnecting wires to reduce the chances of getting an electrical shock.
Ensure that you have the proper cables to hook up your new HDTV. Take inventory to see if you have an ANT-IN, DVI-D/HDCP IN, Video In or Component Video In cables. The placement of these plugs will be indicated in your user book.
Begin by connecting the coaxial cable to the back of your cable box. Run a video cable to the TV; an S-Video cable may be used as well if you do not have any other video cables.
Locate a digital audio cable, or analog audio cable. Connect the audio cable to the TV from the cable box.
Now connect all other components including DVDs, VCRs or LaserDISC players. Try using all digital audio and digital video connections for the most complete HDTV experience.
Use a splitter to connect multiple components such as cable box to DVD or TV to VCR to avoid running out of chords. Calibrate your HDTV before enjoying fully, adjust the brightness, contrast and color settings.
Tips & Warnings
You can utilize a program to help with proper calibration of your HDTV system; these instructional videos can be purchased from many electronic stores.
You can opt for the store from which you purchased your HDTV to hook up the system for you. They will often calibrate the system for you as well.
Hope it helped.
Have a nice day...
Feb 26, 2011 | Bose 3 2 1 GSX System
Components are in black and white instead of color
Wrong connection. Hook up the component output from DVD player or Wii to TV component input using component cable(red, green and blue plug)
Dec 29, 2009 | LG Televison & Video
I hook up my tv cable to the Component 1, and it works
make sure you are using component video red green blue cables for video and not just the yellow composite video cable not sure if this helps you but good luck
Nov 30, 2009 | Insignia 42" Flat-Panel Plasma HDTV
No color
Please set your TV on Auto Color system to get colors on VHS and DVD.
Dec 07, 2008 | Philips Magnavox DVD/VCR Dual Player
Hi, I just purchased a Samsung series 3 330 model#LN40A330 I'am having problems with the AV inputs on back of television. I hooked up a DVD player to Component 1 it works fine Then I hooked up Nintendo...
I figured it out,
The solution to my problem was to update my video cables for my new HDTV.
I found out through trial and error that I can only have one Anolog device hooked up to the TV because with two Anolog devices hooked up the same way it must confuse the TV somehow making one of the inputs showing up in Black and White, So I purchased the color coded AV jacks and everthing works like a charm now.
Jun 21, 2008 | Samsung Televison & Video
TV displays only two colors yellow and purple
you can only have the component video hooked into the component video if you try to down grade (used s video or the yellow cable to connect video you you will get funny colors you need to change the output of the dvd player to one of those not progressive scan on the component side. hpe this helps
May 13, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
DVD plays only in black and white
Hey, I had this problem on Thanksgiving Day, trying to watch a dvd on my mother's HDTV. You should be able to hook up most standard dvd players to hdtvs. First you have 3 cords, mine were red, yellow, and white. The connections go as follows:
HDTV:
Audio| Component. The white cord should be in a white audio slot. The yellow cord should be in a yellow component slot (video) and the red cord should be in a red video component slot labeled Pr/Cr. Make sure you match the component numbers. For instance, if you want to use component one, then hook all of the cords into the slots for component one. Most hdtvs have multiple component hookups ( think multiple "channels" for your game system, dvd player, etc) so it's important that the corresponding cords go to the correct component slots.
DVD:
Match the yellow and white cords to the appropriately colored slots. The red cord should go into the slot labeled component video out Cr/Pr. Not the red audio out. This worked for me. Hope this helps.
May 02, 2008 | Televison & Video
Weird problem not convergence
Mine is doing the exact same thing! have you found a fix yet?
Apr 23, 2007 | JVC AV-48WP74 48" Rear Projection...
DVD Plays in Black and White
Depending what cables you have, try plugging only the yellow cable into "video out", I previously had red, white, and yellow cables plugged into "comopents out" and only got black and white. Doing only the yellow into video out gave me color.
Jun 17, 2006 | Sony DVP-NS700P DVD Player
Daewoo DP42SM 42 in. HD-Ready Plasma Television Logo
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
