Question about Sport & Outdoor - Others
I have a 1987 mercury 9.9 outboard drive problems
I have a 1987 mercury 9.9 outboard on a 12' boat. As I was towing my not-so-good sailor/daughter's sailboat to shore with it, I increased throttle speed a bit and the engine revved high with no power to the propeller. Got it to shore OK after that at lower speed. Next time I used it the engine started & ran fine, reverse worked fine but at above 1/3 throttle I get high revs but no power to the prop again. Below one third throttle the prop can push the boat. The lower housing grease seems fine (except for some red spots in it and the prop did not seem loose when I pulled on it by hand.Have not put a wrench to the prop yet. Thanks
  • r.
The inside of the prop has a rubber between the prop itself and the inside splines to act as a shock absorber,say if you were to hit a rock. that rubber had spun out and the splines are turning inside the prop. the prop is screwed. seen it 100 times before.
Posted on Apr 23, 2009
We were on the way to the lake when we lost a tire on the boat trailer got that fixed and got on the water the boat seemed to run fine when suddenly we felt a **** like we hit something now the engine wont stay running but engine will run out of water in neutral
Posted on Jul 03, 2011
Electric diagram mercury 90hp outboard 1987
Kevin,
Here you go. This is for the 90-115-140 hp models 1980 (ser# 5594657) and up years.
maxrules.com/oldmercs/Wiring/1966ona/37.pdf
Hope this helps get you back on the water. Happy boating.
Fred-
Sep 26, 2016 | Electric Boating
Is there no reverse, goes forward but won't go in reverse
Outboard won't go into reverse ?? - General Discussion Forum ' In ...
www.in-depthoutdoors.com > ... > General Discussion Forum
Aug 9, 2006 - 8 posts - ‎7 authors
There's 2 cables that go into my outboard. ... It would have forward just fine but it would not shift into reverse. Assuming it's a wheel boat does the throttle handle go intoreverse but reverse doesnt work or does it not even ... Here are instructions to recover your old idofishing.com or idohunting.com account:.
Boat won't go in reverse - Lake-Link.com
www.lake-link.com/forums/boats-motors/.../Boat-wont-go-in-reverse
Sep 23, 2013 - 4 posts - ‎3 authors
Fishing Boards - Boats & Motors: Boat won't go in reverse. ... Forward seems to be working OK, but reverse just won't engage. ... I'm not sure if this is something at the throttle control end or something wrong at the motor. Any thoughts ... Looks like there'sa piece missing that's supposed to hold that in place.
Help! Will go in Reverse but not Forward gear! - The Hull Truth ...
www.thehulltruth.com/boating.../526873-help-will-go-reverse-but-not-f...
Jul 30, 2013 - 8 posts - ‎5 authors
Whether you're researching a new boat, or are a seasoned Captain, ... and it was notengaging fully into forward gear, but into reverse just fine. ... I'm a little dumbfounded as to why it will lock the prop when it's not running, but won't go into forward gear when it is ... While your there, change out the bellows. Mercury 125 won't go into reverse - The Hull Truth ...
Mar 17, 2014
Mercury 25 Horse Won't Shift into Reverse
Apr 5, 2009
90hp Yamha won't go in reverse & more - The Hull ...
Oct 4, 2007
Boat wont go forward or reverse - The Hull Truth ...
Jun 6, 2006
More results from www.thehulltruth.com
Dec 16, 2015 | Boating
What will make a johnsonew 50 hp out board motor bog when under load
Evinrude 50 HP Bogs at WOT - MarineEngine
www.marineengine.com > ... > Johnson Evinrude Outboard Archive
Aug 6, 2002 - 17 posts - ‎3 authors
83 50 HP Evinrude - sat out in weather for 4 yrs. Been cleaning ... At WOT, she bogsdown. Up to. ... Yes, this boat/motor is new to me. Actually ... Mercury 50 1987 bogs down when full @ full throttle
Sep 12, 2013
Motor Runs great bogs down under load.
Jun 23, 2011
1984 Johnson 70 idles but won't go
Jun 1, 2011
Johnson 70 hp no power under load Update
Oct 30, 2006
More results from www.marineengine.com
motor bogs down at full throttle Page: 1 - iboats Boating Forums ..
Dec 09, 2015 | Cars & Trucks
Mercury outboard
Sounds Like You Have An Ignition Switch Problem,
Disconnect Yellow/Red Wire From Starter Solenoid In The Engine,
Turn Key On Does It Try To Start Y/N
If Yes Then Starter Solenoid Is At Fault /Replace It!
Good Luck
Apr 02, 2013 | Light Outboard Motor Boat Bass Fishing...
Mercury outboard over charging
Your motor is fine. It needs to put out more than 12 volts or the battery will not charge. Most alternators put out between 13 - 17 volts, so this is well within the range.
May 09, 2009 | Light Outboard Motor Boat Bass Fishing...
Sport & Outdoor - Others Logo
489 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
