Question about Kicker Car Audio & Video
I've got a punch 600.1.bd and im trying to run two kicker solo baric L5's at 1 ohm stable. i have popped a couple of fuses on my amp so i was wondering if it can handle 1 ohm or if i have 2 run them in a series to bring them up to 2 ohms
5 Suggested Answers
  • 113 Answers
SOURCE: How to bridge two 15" kicker solo barics 2 ohm voice coil with a kicker zx750.1
put them in series.
Posted on Aug 09, 2007
SOURCE: kicker solobaric l5 12''
how to wire a kicker solo baric l5 12'' 4ohm down 2 and 1 ohm
Posted on Feb 03, 2008
SOURCE: speaker wiring
hi mat
you should have four terminals two plain and two with dots
to get the best power cut two inches off good speker wire
tear apart now place one wire from
plan black to red with white dot then
plain red to black with white dot
this is how set then up with my directed 1100d mono amp .. very loud at half gain
well hope this helps.............. ..benjaminsarmy..
Posted on Mar 23, 2009
r6yamahaturb
  • 6 Answers
SOURCE: whats the best settings for a 2 ohm solo baric 15
settings are all about what amp and box u got. tell what setting your talking about.
Posted on Jul 02, 2009
Best way to hook up a 15" solo baric L7 to a2400w cx 1200.1 kicker amp
The CX1200.1 amp is 2 ohm stable. Hopefully, you have the 4 ohm DVC version of the Solo-Baric L7. If so, connect the DVCs in parallel (both positives together, both negatives together) to the amp. This will maximize the output power of the amp. If you have the 2 ohm DVC version of the Solo-Baric L7, the best you can do is connect the DVCs in series to the amp. This will cut the output power in half, though.
Oct 30, 2015 | Kicker Car Audio & Video
I have one solo baric hooked up in a 4 ohm series to a 1000 watt kenwood amp that I've tried hooked up normal and bridged at 4 ohm. When I turn it up the sub cuts out. I've looked up a bunch of...
hello, first i would find out what ohm your sub is cause you may think your setting it up for 4 ohm you may be going 2 ohm or 8 ohm. here is the link to for wiring solo baric. http://kicker.com/wiring_diagrams
Aug 24, 2011 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
How do i hook up kicker solo baric in the box
Option 1 (parallel/parallel) = 0.5 ohm load
Voice coils wired in parallel, speakers wired in parallel
Recommended Amplifier: Stable at 1/2 ohm mono 2_2ohm_dvc_05ohm.gif
Option 2 (series/parallel) = 2 ohm load
Voice coils wired in series, speakers wired in parallel
Recommended Amplifier: Stable at 2 or 1 ohm mono 2_2ohm_dvc_2ohm.gif
Option 3 (series) = 8 ohm load
All voice coils wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_2ohm_dvc_8ohm.gif Option 1 (parallel/parallel) = 1 ohm load
Recommended Amplifier: Stable at 1 ohm mono 2_4ohm_dvc_1ohm.gif
Option 2 (series/parallel) = 4 ohm load
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_dvc_4ohm.gif
Apr 10, 2010 | Kicker Solo-Baric L5 Car Subwoofer
What amp need to use for Kicker (2) S12L7 12in Solo Baric
you should use an amp with approx half the power of the speakers max output (i.e 1000 watt speaker use no more than 600 watt amp)
May 12, 2009 | Kicker (2) S12L7 12in Solo-Baric L7 + (1)...
My Amp Keeps shutting off
You need to get an amp with higher wattage. Obviously, your amp cannot handle those two 10" monsters. hehe Nice Subs though :D
May 01, 2009 | Kicker Solo-Baric L7 10'' Car Speaker
Wire my kicker
This will help you :)
Below is a link to the subwoofers manual where is clearly states how to wire it all up, it includes both the 2ohm DVC and 4 ohm DVC models.
Click Here for the L7 Solo Baric Manual
Jan 23, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
How to wire my kicker solar baric
All depends on your amp. Is it 1 ohm stable or not?
Parralell:
positive (pos) on voice coil 1 (vc1) to Pos on vc2 and negative (neg) on vc1 to neg on vc2. Then speaker wire from amp to one vc only = 1ohm load.
Series:
Pos from amp to Pos on vc1. Neg of vc1 to Pos of vc2. Neg of vc2 to amp = 4 ohm load.
Jan 21, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker solo-baric L7
ok here is a real pdf manual from kicker and please rate me
www.kicker.com/06/tech-support/manuals/manuals/02SL7TechManualV2_0.pdf
Jan 21, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker solobaric l5 12''
Sep 25, 2007 | Car Audio & Video
Car Audio & Video Logo
125 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
