Question about Executone Corded Phone
Model 1B I'm looking for instructions as to how to program the keys on Executone Model 1B. Thanks.
    Problem Solver:
  • 10 Answers
You will need to have access to the phone system programming. you can do this through a laptop or through Operators programming if you have one there.
Once you are connected you will access A screen, then the EXT you need to program and then K for Keys. there is where you set up all of the programming on each key.
if you need more info, somehow contact me and I can help over the phone. Every system has a remote access through a modem that is built in on EVCM.card.
Posted on Dec 07, 2008
EXECUTONE 64800 PHONE, HOW TO PROGRAM STATION SPEED DIAL # 'S
from the phone press program key, than 01 for speed dial 1 and then the phone number you need to program in under speed dial 1, after done, press program key. to dial out press outside line key, than program 01 and it will dial out to that numeber. you have 30 speed dials per phone.
Jan 09, 2014 | Executone 64 Corded Phone
How do I program the Executone model 64 LCD to
I assume you mean change the time and date and that depends on which system model you have....assuming you have an "IDS"...go to the receptionists phone ( the phone you reach by dialing 0 or 3001/ 301 ) and without lifting the handset dial 28 followed by the time in military format...if it worked you'll hear a few quick beeps after inputting the time. You might have an Executone Medley...if so > http://www.mainresource.com/PDFs/TipsMedleySysAdmin.pdf
If you have an older version of IDS you need to program it via a programming terminal or laptop. Leave your email here if you get this and I'll email you - can do it remotely via built in modem.
May 14, 2010 | Executone 64 Corded Phone
How do you change the date on executone 64 phone? Our power went off & it reverted to Jan 1. I was able to change the time, no problem, but can't figure out how to change the date. Thanks!
Step 1: Press Menu key
Step 2: Press Park 3 key
Step 3: Enter password followed by # key ex. 543#
Step 4: Enter 9819
Step 5: Enter date with # in between. Ex. 01#26#2009#
Hopefully this will solve your problem.
Jan 26, 2009 | Executone 64 Corded Phone
Executone model 64
In the event you haven't found this information, I got this from www.mainresources.com
To Change The Time
1.
Press the "Menu" key.
2.
Press "Park 3".
3.
Enter the password (default is 456).
4.
Press "#".
5.
Press "1" for System Functions.
6.
Press "4" for System Clock.
7.
Enter the time in 12-hour format.
8.
Press "#".
9.
Press AM or PM by pressing "Park 3" in the LCD screen.
10.
Press "#" to confirm.
11.
Hang up or press "HF".
Top of Page
To Change The Date
1.
2.
Press "Park 3".
3.
4.
Press "#".
5
Press "9819" for the date.
6.
Press the digit for the month (January would be "1").
7.
Press "#".
8.
Press the digit(s) for the day.
9.
Press "#".
10.
Press the digits for the year.
11.
Press "#".
12.
Nov 04, 2008 | Executone 64 Corded Phone
Flex button programming Excutone phone
you will need access to the programming in the phone system.
once you are connected go to A screen and then type in the EXT you want to program. after that press K and K again. the key you are looking for is 830. go to that key with the cursor by hitting ENTER key and press 0 and ten ENTER key. you are done. ESC and ESC and then E for EXIT.
email me for more answers if you need further help on how to get into the phone system.
Oct 24, 2008 | Executone 64 Corded Phone
Phone in night mode
go to EXT 100 and program a key with a code 560.
you will do that by pressing the menu or F1 key and then fallow the steps for programming a key.
once you have programmed the key press it once and the display will start changing from night to day to holiday, pick the day and you are done.
Better yet, go to the phone that has on the display word NGT/night, or DAY, HLDAY and press the each key until the display changes that word on the display. one of the keys is programmed with key code 560. the phones that do not show Day, Night and Holiday will not have the key.
let me know if this does not work for you, or you need other help
Oct 07, 2008 | Executone 64 Corded Phone
Program error
what system is this?
does the Program error apear when you press a button?
if it does, then the keys need to be reprogrammed.
let me know and I will help you with the rest.
Jul 20, 2008 | Executone IDS 82200 Corded Phone
Template showing what the keys represent is missing
all of the keys can be programmed with different key codes.
best thing you can do is press each one and see what it does. if you can get into programming of the phone system, then go to A screen and then that EXT, and K for Keys and you will see what is programmed on each key. You will see many codes, but if you put the cursor on each key you will see the description of each key abve key 2 and 3.
i hope this helps.
Jun 04, 2008 | Executone Corded Phone
Executone 64 Administrators manual
if you can get into the programming then first go to the B screen and then press A and set the drop pulse to 10 and then press C for Copy and then Y .
hit ESC and press J
the cursor should be blinking on the first line on top left corner, there hit F for Flash and press ENTER
Hit ESC and press A , put in the EXT you need to program the key for, then press Enter, then K, then K again and pick a key to programm. once you have picked one by pressing ENTER key to move the cursor program a code 815 ENTER, S for Subcode and then 1 Enter
ESC, ESC E for exit.
contact me for more info
Apr 17, 2008 | Executone 64 Corded Phone
Executone Corded Phone Logo
125 people viewed this question
Top Executone Lands Phones Experts
David Burbee
David Burbee
magna buff
batMichael
Level 1 Expert
Are you an Executone Lands Phone Expert? Answer questions, earn points and help others
