If the thermal fuse blew you would have no heat, I would suggest to make sure you have a clean vent system to assure the dryer can breath. Simple test, disconnect vent system and run dryer, if the vent system is the cause the dryer should heat. if the fuse is blown you will not get heat. If the dryer heats at first then stops heating, I would lead you to the coil kit on top of the regulator, then can fail but allow some heat at first. Once they get warm they can fail to reopen the gas valve (regulator).
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
