6. Playback
(1) Set channel 1 to play.Turn the REC/PLAY key on. Then press the channel key of track 1 (the track you just recorded) to set it to Play (key lit green).
(2) Return to the beginning of the song.Hold down the STOP key and press the REW key to return to the beginning of the song (?p.37 "2. Location").
Try a head cleaner first and if that doesnt work then look around for a new cd player or use the computer as if its what i think it is then its not reading correctly and it not really repairable ,Well financialy viable as i think the memory reading of the circuitry is questionable.
It’s necessary to bounce all of your tracks to a stereo pair of tracks before you can export your song to a computer as a WAV or MP3 file for burning onto a CD.
1. In normal mode, push EXIT and UTILITY until you see BOUNCE on the display.
Note: The upper right corner of the display shows the track you’re bouncing to. By default, “12V2”—Tracks 1 and 2, Virtual Track 2—is selected.
2. Press STOP and REWIND together to go back to the beginning of the song.
3. Press RECORD, and then press PLAY.
4.When the song’s finished playing, press STOP.
i read some stuff online and this should help.
First of all, it would be better for you to pan the tracks, and bounce into 2 tracks for stereo separation.
Your "static" may stem from three pausible causes.
One, four tracks into mono may make your output a little muddy.
Two, watch the reverb - if you keep applying reverb after each bounce, it starts to sound bad.
Three, if you have drums/rhythm, turn it off while bouncing. Only have drums on when mastering, because they will keep getting re-recorded during bouncing.
Go to bossbr.net - The best place to get answers!!!!
If you are sequencing midi tracks you can imbed the patch change in the track and the midi channel assignment and when the sequence plays the info will be sent to the keyboard. Do you have it set to receive Omni?
from reading instructions when you record channel 1 and 2 you are recordind channel 1 in stereo so you only recorded channel 1 try rcording on chanel 3 for vocal hope this helps
