New build PC, carries out POST, recognises DEL key to access BIOS, but can not use keyboard to change BIOS settings
  • rodlips Aug 29, 2008
    I found the cause of the problem. I disconected the USB connectors and found that the system booted AOK. On closer examination of the 'Quick connect' plug I found that I had crossed over 2 of the connections. Re-connecting the wires in the correct postions and re-connecting the USB 'Quick connect' plug sorted the problem.
    Thanks again for assistance.
  • 3,051 Answers
You may have to try a different keyboard or make sure it is in the right port or you may want to see if you have your bios jumpers set to normal and not setup
Posted on Aug 25, 2008
How do I get it to go into bios when pressing f2 doesn't work?
Per the internet site, it depends upon the model of laptop. Here are some examples:
Laptops - Access Bios Settings Key
Issue
The most common Access Bios key is the "DEL" button or "F2". This depends on the laptop model, however, and can be confusing if you do not know which key to press.
Solution
Here is a list of laptop models and brands with the keyboard commands / key for accessing the BIOS Setup:
Acer: F1, F2, CTRL+ALT+ESC
ARI: CTRL+ALT+ESC, CTRL+ALT+DEL
AST: CTRL+ALT+ESC, CTRL+ALT+DEL
Compaq 8700: F10
CompUSA: DEL
Cybermax: ESC
Dell Laptops:
Dell 400: F3, F1
Dell 4400: F12
Dell Dimension: F2 or DEL
Dell Inspiron: F2
Dell Latitude: Fn+F1 (while booted)
Dell Latitude: F2 (on boot)
Dell Optiplex: DEL
Dell Optiplex: F2
Dell Precision: F2
eMachine: F2
Gateway 2000 1440: F1
Gateway 2000 Solo: F2
HP (Hewlett-Packard): F1, F2 (Laptop, ESC)
IBM: F1
E-pro Laptop: F2
IBM PS/2: CTRL+ALT+INS after CTRL+ALT+DEL
IBM Thinkpad (newer) Windows: Programs-Thinkpad CFG.
Micron: F1, F2, or DEL
Packard Bell: F1, F2, Del
Seanix: DEL
Sony VAIO: F2
Sony VAIO: F3
Tiger: DEL
Toshiba 335 CDS: ESC
Toshiba Protege: ESC
Toshiba Satellite 205 CDS: F1
Toshiba Tecra: ESC then F1 or F2
Toshiba Notebook [Newer models]:
  • Turn on the computer by holding down the power button while pressing the ESC key
    • The machine will beep, then display:
    • Check System, then press [F1] key.
  • Release the ESC key
  • Press the F1 key
Laptops Access Bios Settings Key
Apr 03, 2015 | Computers & Internet
GA-Z68AP-D3 wont recognise keyboard
This sounds very much like a faulty motherboard if it continually reboots. Try accessing the BIOS using the F8 key, however check you manual to make sure your motherboard uses the F8 key. If you can access the BIOS, it would be worth doing a complete reset to factory defaults and see if this fixes the problem. If you cannot access the BIOS, then you will be looking at a new motherboard.
Nov 26, 2017 | Gigabyte Computers & Internet
How to install change first boot divice on ibm thinkcentre computer
You must enter the "BIOS" at start up (sometimes called SetUp). Press F2 or F8 or F11 or other function key that will be required by your computer. Should tell you at boot.
Enter the BIOS settings, find the boot sequence and edit it. remember to save your changes.
BE VERY CAREFUL WHAT YOU SELECT!
Thanks for your visit today.
Feb 01, 2011 | IBM ThinkCentre A50 PC Desktop
HI, I have an MS3200 keyboard and the time is incorrect because of daylight savings. I looked online and the way it showed to fix it did NOT work. How do I change the time? Please and thank you!
You need to access your bios to correct the main clock of the PC. Computer manufacturers use different keys to access the bios, but it will always be as your computer is FIRST starting up, before the operating system or anything else loads. Just watch for a message saying 'Press f2 for setup' or 'DEL to enter bios' immediately after you turn your computer on. Popular bios access buttons are DEL, F2, F12 and F10, but your system may use a different keystroke. Once inside your bios you should see the time that is set. Check the legend at the bottom or the right of your bios screen to see how you would change the values of the time, and then make sure you save before you exit the bios. Avoid changing any other settings, as there are a lot of settings within the bios that if changed, could cause your computer to act strangely, or not even load the operating system.
Nov 19, 2010 | Computers & Internet
I got a new key board it was working yesterday when i kept switching my pc on and off but today it wont work what cud i try
Hi
Please check whether your keyboard is properly plugged in to your computer. If it is plugged in properly then try and change the slot of the keyboard(if its a USB port keyboard). If this doesn't help then try to check the BIOS settings for keyboard settings.
To enter BIOS settings press DEL key continuosly or F8(Function key 8) continuosly until the BIOS menu appears. Under the menu select the option of Hardware->Keyboard-> check whether it is enabled or disabled. If it is disabled then enable it.
Try using this keyboard with another Computer, if it doesn't work with other Computer as well then you can get it replaced for a new one.
Daniel Scott
Jun 12, 2010 | Computers & Internet
Gigabyte BIOS
1st you check Press F1 Button OR Press F2 Button Hope you will be enter in BIOS setup
Mar 13, 2010 | Computers & Internet
Key on keyboard to access bios of M24XS-NP233X
for most desktops the key to press is del ...but it has to be pressed on boot when it shows your devices ....so ...just power it up ...and keep pressing del rhythmical to be sure that you do not miss it ...anyway after a few boots you will see cause it is written on screen press del to enter setup ...if there is another key set to do the job it will specify which one...
for some laptops you have to press F 2but I dont think this is the case...
if helpful ..please dont forget to rate ... Have a nice day !
Jan 18, 2010 | Computers & Internet
How do i access the BIOS of my pc? when my plug and play compatable sound system is connected to my onboard sound, the computer does not detect the device
You can access the BIOS by rebooting the computer. Upon bootup, press DEL button (you may want to press it several times). The BIOS or CMOS settings will appear. You may need to enable USB devices for your computer. Good luck!
Oct 25, 2009 | Audio Players & Recorders
Bios does not find PS2 keyboard/mouse
Did you go into the BIOS and set it to recognize the USB Keyboard after you reset the BIOS? Is windows not noticing it or the BIOS. You stated that it recognized the USB keyboard and then said that it did not.
What does all of this mean? USB keyboard does not activate "del" setup.
If it does not work, it is because you reset the BIOS and did not change the settings back for the USB keyboard.
I hope that I fixed your problem.
Jun 04, 2008 | AOpen AX4BS (91.32Q10.002) Motherboard
Unable to get to CMOS using any of the 3 methods
This machine is one of the first "legacy free" models which means there are no BIOS options to change. All settings and resources must be assigned by the OS.
For details, please check the "legacy free" FAQ on MS Knowledge base.
If you are trying to access the BIOS to change boot order so that you can boot from a CD, hold down the 'c' key during POST/boot. This will case your laptop to boot from CD-ROM.
Apr 09, 2008 | Toshiba Satellite 5005-S504 Notebook
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
