I have a 42" hitahci hdtv. Before I left for vaction, I unplugged my tv. I plugged my tv back in when i got home, but when I press the on/off switch, the red light comes on for a second and goes out. It seems like the switch might be bad. But I'm not sure.
  • 6,487 Answers
The first thing to do is a system reset using the reset button on the front panel.
If that does not work, unplug the set and let it sit overnight.
If it still does not come up , then a call to a qualified service repair technician is needed
Hope that helps.........
Posted on Aug 25, 2008
    Master:
  • 521 Answers
Yes obiviously the switch is bad check that first before checking
or doing any thing else.also try to reset if you find the switch is ok.unplug the tv for some time and then replug it ,this is automatic reset.do not worry the problem is minor.and last thing check all the connections properly.
    President:
  • 1,450 Answers
I am not trying to solve your problem but does it cut on with your remote?I know they will wanna know this
    Master:
  • 623 Answers
Check the fuse or
this could be because of moisture on your boards
make sure there is non
  • 1,800 Answers
The ignition panel taht gives a signal to the computer to start is damaged now
the only solution that u got is to replace it.
its not an easy task though but i am affrad that u gonna give it to the nearest repeair shop in ur area u can use our repairman service its confident and quick!!
plz rate this post.
  • 19,396 Answers
Leave the tv inplugged few hours, this should fix it.
  • Ginko
    Ginko Aug 25, 2008
    When power switch is bad it does not switch on at all, check also that power switch is not stuck on pressed position.
    If there is a fault the tv has an internal switch that shut down tv by itself.
    Remove also battery from remote, a faulty remote can cause same problem.
No power to tv
I would suspect bad capacitors on the power supply. They drain when left unplugged from the power source and then when power is restored the weakcapacitors cant recharge and the set wont power up.
Feb 09, 2013 | Panasonic TC-P42X5 42" 720p Plasma HDTV...
LG 42" Plasma - remote wouldn't turn off TV, nor
unplug for a couple of hours. the tv holds charge and bleeds off electricity very slowly.
Mar 22, 2011 | LG 42PG20 42 in. Plasma HDTV
Today 12/16/2010 my HDTV 42 in plasma model 42px12x.41. made a "popping" sound in the back of the screen and the screen went black,( yet there is still sound and a couple of green and red light...
PLASMA TVS DONT HAVE INVERTER CIRCUITS. YOU MOST LIKELY HAVE A Y-SUSTAIN BOARD FAILURE. IT IS THE BOARD TO THE LEFT LOOKING FROM THE BACK. THE LARGE ALUMINUM HEAT SINK LOCATED ON THE BOARD AND THE PART SCREWED TO IT WILL BE THE DEFECTIVE PART.
Dec 17, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
I have a Hitachi 42" plasma/ 42HDT51 and the power
Replace your buffer boards they are two unit located on the right of the plasma if you are looking the plasma from behind. Do you have any sound?
Thanks,
Nov 21, 2010 | Hitachi 42HDT51 42 in. Plasma SLC1551AW
I was watching my LG LCD 42 tv when it went black...I unplugged everything and plugged the tv and cable back in...the picture came back on for a minute and went back black
You may have dying power supply or backlight inverter board, those are the two areas you need to check.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Aug 10, 2010 | LG 42LC2D 42 in. LCD HDTV
Blue power light is on the tv cant turn it off
Unplug the TV wait 10 Seconds and Plug it back in. Should work fine
Sep 26, 2009 | RCA L42FHD37 42 in. LCD HDTV
Lg 42'' plasma 720p no picture
This is not good. Was your tv unplugged or just power button off when you left for vacation. PlasmaTvs are highly susceptible to damage from power surges caused by lighting. Leave unplugged for at least five minutes then plug back in and see if this helps.
Aug 15, 2009 | LG 42PQ30 42 in. Plasma TV
No power to tv after unplugging and replugging
either the fuse is burnt out inside or the the problem is the power supply board. You can remove the back cover to see if the fuse is good or not.
Jan 17, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
TV won't turn on
When I try to turn the tv on, the green light flashes and eventually goes back to red. A very faint picture came across the tv a few times but didn't stay. The tv is only 3.5 years old.
Jul 10, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
