Master
- Posted on Jul 08, 2011
Re: Hello, first of all problems my car failed emmissions...
Go to your nearest Auto Zone store and
have them put their computer on your vehicle, to see what code comes
up (IT FREE). They should let you know what the problem it...if
not....let me know what the code is and I will let you know what is
wrong..Hope this helps you ??
The fact that you don't know what the guy did when he took the can back in is a concern, because it gives no clue as to the problem being associated with the original fault or not. If you didn't get an explanation, then its a little unfair to sugest that you might get billed for false repairs. The fact that the car has run for 5 months since would suggest that whatever he did was a good fix anyway. The check engine light being on doesn't indicate that the fault is the same this time and it will need some diagnostics to figure out what the engine management system has recorded this time. The fact that the problem started there (and by the way it didn't... It started before you went there), doesn't lock you into having to go back. Any good mechanic will pick up the issue from fresh and sort it out for you. By the way, the original errors of P0442 - Evaporative Emission Control System Leak Detected (small leak) and
P0456 - Evaporative Emission Control System Leak Detected (very small leak)
sound very unlikely indeed to be related to the issue you describe with the gear select, I'd go so far as to say there was no way they were connected and the guy probably did some good work for you
