Question about iLO 3200 32 in. LCD Television
Ilo tv can not change channel volume with control or manually, just turn on and off
  • patry Aug 25, 2008
    can not change channels or volume either with the remote or manually, unpluging it didn't work
  • iLO Master
  • 6,487 Answers
The control board for the TV is faulty and it already needs a replacement, if you can take it to a repair center or have it replace from the manufacturer will be better..
Good luck........
Posted on Aug 25, 2008
    Genius:
  • 1,447 Answers
Hi-
You need to take tv apart and clean the Printed Circuit Board and remove dirts as well. Check the buttons and its membrance as well.This will take up awhile and suggesting to have it repaired by an expert to save more time and prevent more damages to your tv set.
Hope this helps
  • 10,594 Answers
First check any key on control panel has not been pressed permanently, if No, problem seems in System Control Circuit of your TV. Here is part store offers boards for TV on low prices.
  • iLO Master
  • 1,800 Answers
The configuration panel is damaged try a new one rpalcing it!!
plz rate this post
  • Jalal Sordo
    Jalal Sordo Aug 25, 2008
    a circuit burnet inside teh panel always blows in major cases!!
    Master:
  • 521 Answers
Ok.try to reset the tv by unplugging it for some time and then replugging it.that is automatic reset.
  • iLO Master
  • 19,396 Answers
Try first unplugging power cable for twenty minutes or so.
  • Ginko
    Ginko Aug 25, 2008
    Try first unplugging power cable for a while, so to drain power from TV. This is a simplereset that often can solve troubles with settings and internal boards.
    If this does not work the fault it is probably located on the control panel, where buttons are mounted, that also receive signal from remote.
    The TV must be taken apart, panel connections checked. Panel pcb must be tested and eventually replaced.
    If you do not have experience testing and working on TVs and electronics I suggest calling a repair technician, you find a service number printed on the owner manual.
    Check also guaranty terms.
4 Suggested Answers
  • 26 Answers
SOURCE: Ilo-32HD
Check the menu to make sure it is not in a lock mode. If that is OK, it probably needs a control board. On some brands that might be called a digital or tuner board.
Posted on Jan 22, 2008
  • 7 Answers
SOURCE: ilo tv is stuck on one (1) channel
call 909-974-2859, they have the parts and tech support for this TV.
Posted on Sep 28, 2008
dsacco86
  • 1077 Answers
SOURCE: I have 42 in ilo plasma tv. I can turn tv on but
Most likely the TV has a Mother board related issue. Your TV is just like a computer. When it freezes up, nothing responds and you have to pull the plug to turn it off.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part or replace the whole circuit board. The Service Manual will give you circuit diagrams, test points, and part# lists.Service manual cost about under $20. Most cases the new part cost less than $15. New circiut board, depending on type, may cost about $125.
I hope I shed some light on the subject for you.
Posted on Jul 08, 2009
How to program ilo TV w/universal remote to play DVD
I Believe You Can Go To Channel 2 And Right Below Those Channels Are The 3 Video Channels Turn On Your Dvd Player And Go Through Them. If That Doesn't Work Try Looking At The Buttons On Your Tv For A Tv Video. Make Sure You Dont Have A Tv Video Button On Your Remote If You Do Then Just Click It Till You Find The Appropriate Video Channel.
Jan 05, 2009 | iLO 3200 32 in. LCD Television
ILO LCD Color HDTV does not change channels / volumn...just turns on/off
The symptoms your TV is experiencing is due to a power supply that is not longer providing the 5 volts properly to the circuitry.
It seems to be a common failure on these TV sets.
Apr 29, 2008 | iLO 3200 32 in. LCD Television
Ilotv 32HD
The only way that I know of to eliminate this problem is to buy a new TV. My ILO TV has been repaired twice since May 08 and it went out again for the third time. The problem starts out as an intermittent problem.... You turn the TV on, the audio is fine but there's no picture, you will be unable to change the channel or volume whether you're using the remote control or the buttons on the TV.
This TV should have been recalled. Don't throw good money after bad and don't reward the manufacturer and retailer for their bad behavior, buy your next TV from a different retailer.
Sep 17, 2008 | iLO 3200 32 in. LCD Television
Problem
This TV should have been recalled. Don't reward the manufacturer and retailer for their bad behavior, buy your next TV from a different retailer.
Ilo tv is stuck on one (1) channel
Sep 16, 2008 | iLO 3200 32 in. LCD Television
Ilo tv programming problem
get a surround sound system and once you hook up your audio you can then use the surround sound remote..avi in... to control your volume.. and use your direct tv remote to change channels
May 09, 2008 | iLO LCT32HA36 Television
Remote control code
hi
you can download your manual here for the colossal universal remote.
since ilo tvs dont seem to have a specific code, you can either try the generic codes that are found here in the pdf manual.
hope this helps
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=livingsolutions&dv=universalremote&md=colossal3in1606426&kw=&st=&ar=&dt=&so=&pg=1&file=others/living_solutions/colossal-manual.zip
Jan 22, 2008 | Spectroniq PLTV-42HW68 42 in. LCD TV
Ilo-32HD
Jan 22, 2008 | iLO 3200 32 in. LCD Television
Telvision Problem
Do the controls on the tv itself work or just the remote? If it's the remote mabey it's defective. I would look on the Ilo site and see if they recommend a universal remote for their models ( or just getting yours replaced ). If the problem is within the tv, I'd look into the warranty. Sorry if this wasn't any help.
Apr 25, 2007 | iLO 3200 32 in. LCD Television
iLO 3200 32 in. LCD Television Logo
47 people viewed this question
Top iLO Televison & Video Experts
AFcityboy
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Radames Pagan
Radames Pagan
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
