Question about Kenmore 62872 Electric Dryer
Dryer problem The dryer works for 2 minutes and then turns off. I think it may be the heating element. What do you think? If it is the heating element is it worth getting it repaired or just replacing it? The dryer is about 9 years old.
  • butterflylyn Oct 08, 2008
    my dryer runs for a few minutes then shuts off it gets warm but won't stay running then after a few times of pushing the button it does nothing i've taken the fuses and start button to bell parts here in town and everything test good start buttons good fuses are good and i just changed the heating element in it a year ago any ideas??
  • 943 Answers
Hi thanks for the question are you saying that the whole dryer shuts off after 2 minutes or just the heat if your dryer runs for 2 minutes and then cuts out then you wait 10 minutes it goes again then its the motor thanks the appliance doc
Posted on Sep 15, 2008
Why does my Whirlpool electric dryer - model SEDS800JQ0, shut off after 2 minutes?
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!! SO MY ADIVE IS FREE
Aug 09, 2014 | Whirlpool Dryers
My dryer model dv231aew/xaa Will not shut off unless you open the door....on/off & pause shows its working but its not
follow this steps and fix it. Merry Christmas
Timer
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is faulty replace it. If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. Replace the heating elements.
Dec 17, 2013 | Samsung DV231AEW 7.3 Cu. Ft. White...
My Kenmore HE4 electric dryer runs for 2 minutes and stops
follow this steps and fix it. God bless you
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is faulty replac it. If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. Replace it
Oct 01, 2013 | Kenmore Elite HE4 Electric Dryer
Dryer wont stop buzzing
Timer
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is bad and need replaced. If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. replace the heating elements
Jul 09, 2013 | Dryers
The Whirlpool Ultimate II dryer heats up at first and then the heat shuts off after approximately 10 minutes and doesn't come back on. If I let dryer cool for 10 minutes it will do the same thing again.
If the dryer is not drying the clothes then you would need to check for the following things-
Electric Dryer---
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Hope this helps...
Daniel
Sep 14, 2010 | Dryers
Have a frigidaire "gallery" series stackable washer/dryer, the heating element initially turns on when the dryer starts. you can see the element light up and feel heat but after a minute of run time the...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 22, 2010 | Frigidaire Dryers
Kenmore dryer
Okay, the little white thingy you mention is the thermal fuse. If it were to blow, the dryer would not run at all. They usually blow like a fuse and require replacement, however, I have experienced on one occasion where the dryer would shut down in the manner you mention, and it was caused by a thermal fuse that was tripping off. I couldn't explain it, but I replaced it and the dryer worked fine after that. That could very well be a possiblity. Normally, problems like this are caused by the operating thermostat going bad. That the other thingy thats mounted next to the thermal fuse. The link I sent you should have information on how to check them. The heating element should not be considered a problem at this point. It would not cause the dryer to shut down if it were to fail. Your symptom would be a dryer that runs, but does not heat. Let em know if you have further questions.
Aug 15, 2008 | Kenmore 63942 Dryer
Only a little heat is going to the cylinder
Zuraxus what you are seeing is normal for a time. Here is how this dryer works. With a wet towel in the dryer, the first 5 minutes is testing to see if the load is wet. If so then between 5 & 10 minutes the dryer will turn on the 800 watt heater section (only in clockwise rotation). If still wet enough from 10 minutes to 15 minutes it will turn on the 1900 watt heater (heating only in clockwise). If still wet enough 15 to dry will turn on the full 2700 watts in clockwise and 800 watts in counter clock wise. That is how the cycle works. However it is hard to tell with the rear cover removed as the blower pushes the air thru the heater. Careful that by running with the back panel off you don't trip the high temp manual reset protector. So yes this sounds normal. What is the issue that is causing you to think the dryer isn't working proper?
Apr 20, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Kenmore Seris 90 Front load dryer
I agree with you that the possible culprit is the thermal cut off sensor. The extreme heating could be caused by a malfunctioning thermostat or heating element.
Mar 07, 2008 | Dryers
Kenmore 62872 Electric Dryer Logo
106 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
