Question about Acer Aspire 5630 Notebook
DVD-RW Suddenly burning slower and playing dvd's and music with a choppy lag
Happened about a few days ago, was burning a dvd of about 4GB that would normaly take about 10 minutes, and it for some reason took an hour. Same with everything else I was burning from then onwards.
Today put a DVD in and everything was playing with a choppy lag, the sound kept pausing and playing with computery sounds, and picture kept jerking. Tryed a CD which was less bad but still had simalar problems. No effect on video files, iso discs or data files, they seem ok. Its like the DVD-RW is now slower all of a sudden and can barly play DVD's and CD's. Already tired a DVD cleaner disc and blowing dust off.
I have an Acer Aspire 5630 with HL-DT-ST DVDRAM GSA-T20N DVD-RW, any help I would be vey much greatful for.
  • silentmike Aug 26, 2008
    Normal
    0
    false
    false
    false
    MicrosoftInternetExplorer4
    /* Style Definitions */
    table.MsoNormalTable
    {mso-style-name:"Table Normal";
    mso-tstyle-rowband-size:0;
    mso-tstyle-colband-size:0;
    mso-style-noshow:yes;
    mso-style-parent:"";
    mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
    mso-para-margin:0cm;
    mso-para-margin-bottom:.0001pt;
    mso-pagination:widow-orphan;
    font-size:10.0pt;
    font-family:"Times New Roman";
    mso-ansi-language:#0400;
    mso-fareast-language:#0400;
    mso-bidi-language:#0400;}
    Thanks for the help, I’m not sure what caused it but it was defiantly
    the software. I tried getting rid of all the major programs but had no luck,
    then did a system restore to a month ago which fixed the problem completely. Hopefully
    it wont happen again.
I had exactly this problem! Took me ages to work out what was wrong, but fixed it in the end. The answer: windows had downgraded the disk controller transfer mode from DMA to PIO, whatever that means. It happens if windows encounters problems burning discs more than four times in a row, or something like that. What you do to set it back to DMA mode is:
1) Open the Device Manager, ie. right click My Computer and select Manage, then when the Computer Management window pops up select Device Manager in the left-hand pane.
2) In the right-hand pane double-click IDE ATA/ATAPI Controllers. Then double-click Primary IDE Channel.
3) In the little Properties window that opens, select the Advanced Settings panel. Then in the Transfer Mode dropdown select DMA If Available. Click OK
4) Do the same for the Secondary IDE Channel
5) Reboot yr laptop
Happily you fixed yours already, but this is what to do if it happens again. Such a crappy operating systimmmm!
Posted on Dec 14, 2008
    Genius:
  • 2,028 Answers
This is going to be a software glitch. Start by removing and reinstalling the program or programs used for playing and burning CD/DVD's. Then uninstall the drivers for the DVD drive from the device manager and reboot. The machine will find the DVD drive and reinstall the drivers automatically. This will refreshen the drive and software, and should get you back up to speed. If you continue to have the problem, then look for any software that may be conflicting with each other, ie... two different burning programs. Two like programs can conflict at any time due to the program language, settings, or if the two are fighting for which operates the drive, so if you have multiple burning or playing programs, you may want t only use one. A common cause is when a machine comes with the program, but the owner doesn't like the user friendliness or the way it operates, and downloads another to use without removing the existing program. Don't know if this applies to you, but it's a thought.
Posted on Aug 25, 2008
I BURNED A DVDRW ON MYCPU BUT IT WONT PLAY IT ON XBOX360 OR DVD PLAYERS
If you are trying to play music, then there could be only two problems.
1. Some DVD-RW can unintentionally trick you into thinking that they can play music, if inserted into the right machine. But really what it might really mean is that it can transport music, not play it.
2. The format of the file that you burned onto the disc may not be compatible with the type of DVD-RW that you have.
If you are trying to put an actually DVD/Movie onto the disc, then it is more than likely a format problem. I imagine that it may be really hard to get a video into the correct format so that it can be played on a DVD-RW.
I assume that whatever you are putting onto the DVD-RW is completely original. If it is not (such as a movie you got offline) then copyright laws will take all happiness out of your life.
Aug 04, 2011 | Video Game Consoles & Games
I cant burn or play dvd
try to burn at a slower speed, turn off the screen saver and virus scanner? if these try to run while a burn is going it can cause an error, try to defrag the hardrive if needed before the burn, try another brand of media , check for software updates on the burning software
Nov 26, 2008 | Optorite (dd0405) DVD±RW Burner
EXTENSA 4420 DVD-RW WON'T BURN DVDS
This could be a glitch with your burning software. Try removing and reinstalling it, or using a different software. The other possibility is the drive, occassionally with a CD/DVD combo drive the DVD reader or burner will fail, leaving the CD end working.
Jul 02, 2008 | Acer Aspire 5500 5570-2609 Laptop
LG LS50 DVD/CD-RW DRIVE won't recognize blank dvd-r
Yes does not read DVD-R because if your LS50 Labeled like this (DVD/CD-RW) means that can read only all DVD Disc and cannot write on DVD blank only CD blank.
You can burn only on the blank CD-RW or any blank CD.
Jan 17, 2008 | LG X-Note LM50 Notebook
Formats for dvd
Actually ,, ,What kind of dvd player are you playing it back on.. ??
Did you try other players ?
does it play on the computer ?
if it doesnt then try using a slower speed or different media..
please answer the questions above so i can help you further
Dec 30, 2007 | Plextor PX-708A DVD±RW Burner
CD-RW/DVD-ROM BURNER
if you wish to burn cd's which is your burner then you need a software called nero burning rom or any other burning software that lets you burn data or audio cd's or vcd's to burn with if you wish to burn dvd's then you need a dvd burner combo drive which lets you burn dvds
Aug 11, 2007 | LG GCC-4241N CD-RW/DVD-ROM (Combo) Burner
My burner isn't burning DVDs properly!
Try a different brand of DVD and use a lens cleaner it just may need a clean up.
Nov 29, 2006 | Lite On (SOHW-1693S) DVD±RW Dual...
Acer Aspire 5630 Notebook Logo
110 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
