Question about Canon imageRUNNER 5570 Copier
Pgm to staple with a Canon ImageRunner 5000
We have a Canon ImageRunner 5000 which has a stapler option.
This printer support PCL 5e
We need to programatically turn on the staple feature.
With an HP4200 we used a PJL printer command sent to the printer.
@PJL SET PROCESSINGTYPE="STAPLING"
@PJL SET PROCESSINGOPTION="ONE_STAPLE"
@PJL SET PROCESSINGBOUNDARY=MOPY
etc. etc.
But this same string does not work for the Canon Printer.
Do you know what I need to send to the printer to staple or where this may be documented
Thanks
Canon handles it as PJL comments.
Google the string "PJL COMMENT CANPJL"
Posted on Oct 12, 2008
My canon image runner 5000 occur error code e000532-0002? how to solve this problem.
this is a stapler issue in the fininisher, it is either off track or something is stopping it from moving or there could simply be staples jammed up
Aug 10, 2011 | Canon imageRUNNER 5000 Copier
How do I automate the stapler feature when I send a document to the printer?
Stapling is usually listed under "finishing" option when printing. Good luck.
Mar 10, 2011 | Canon imageRUNNER 400S Copier
How do you change a staple cartridge in a canon imagerunner 2870?
first open upper front cover.
then pull handle on left corner of front side, the sorter unit will come out. see behind side of sorter unit u'll find a small green handle to detach the staples cartridge, replace the staples cartridge and insert unit into stapler. push back sorter unit an close the upper front door. end
Dec 20, 2010 | Canon imageRUNNER 2870 Copier
How do i change the staple cartridge
before u can add staples to the stapler cartridge it must be completly empited. also when you order staples that it is for the ir 5000 copiers
Jul 14, 2010 | Canon imageRUNNER 5000 Copier
Installing staples in a Canon imagerunner 5055
Open the finisher door and you will find the place, it is in the front side. Regards
Feb 20, 2009 | Canon imageRUNNER 5000 Copier
The stapler is not working
Take a can of can air after you have removed the staples cartridge and blow out the socket that the staples fir into. Sometimes a jammed staple can stick in there and cause problems. Also if you can remove the bottom blade of staples out of the staple cartridge. Just raise that piece with the green on it and carefully remove just one blade.
If that does not work you most likely need a new stapler assembly and they could cost 2-$300. retail. If its under contract with a dealer this should be replaced for free.
Good Luck!
Jan 08, 2009 | Canon IMAGERUNNER 2230 Copier
How to print and staple landscape using Canon 3220
HI
You go to you printer properties(you will find it if you right click on the printer driver under printers and faxes in the controll panel),select printing prefrences,page setup,there is a option for landscape printing.Next to page setup is the finnisher settings,select the stapler option.
Nov 11, 2008 | Canon imageRUNNER C3220 Color Copier
Adding Staples Image Runner 330S
depednding on sorter im guessing its the small sorter with one tray the stapler is in the rear of the sorter green handle pull it out uses L 1 staples
Jul 24, 2008 | Canon ImageRUNNER 330s Copier
Problems Printing from PC to Copier
What type of driver are you using? Postscript or PCL? Are you printing over TCIP port or a direct connection like a USB? Are there any updates for the Imagerunner since you bought it? They release updates like microsoft releases updates. Also what type of operating system do you have?
Aug 06, 2007 | Canon imageRUNNER 5000 Copier
Canon imageRUNNER 5570 Copier Logo
498 people viewed this question
old marine
old marine
