no year car told. (will Assume starter cranks fast)
NO SPARK (fire only happens with fuel) fueling is last.
when did it last run this car, last week, month, year, ? or never
as in fixing dead car for friend ,etc? for found a dead car?
spark that is called,the High voltage HV ) spark coil makes spark happen on all gas engines. and evolved radically from 1990 to now.
so your not telling cars
year, country, makes answer frankly impossible
Generic answer next. (4cyl. 1.3L)
- fuses blown. (we check them all, )
- icm bad, or bad distributor. or installed wrong.
- 2 coil packs,? 1,3,4,2 fired, and wired backwards (OOPS)
- COPS bad. (coil over plugs x4)
- CKP bad
- CMP bad
- cam belt slipped making CMP and CKP LIE and ECU ignores them. or fires sparks in WRONG TIME.(varies by year made)
- wires bad to all that. or connector, there.
- key switch bad (ing pin)
- bad spark coil HV,or HV wires sets bad. to distrib or to coil packs.
- always test all spark plugs not just one., or bark up the wrong tree easy.
if 2 coil packs the HV lugs most not connected wrong,
or spark firing order is lost.
if 2coil packs, 1 spark plug or 1 HV wire fails 1 spark plugs die
and 4cyl with only 2 sparks good cannot RUN.
1,3,4,2 is order.
1983 to 2011 years wiki says
The Ford Bantam is a coup? utility/pickup (known in South African English as a 'Bakkie') produced in South Africa. Production of the Bantam spanned three generations, with the vehicle produced in South Africa for sale within the
South African market.
Brazilian-designed
Rocam engine is of single overhead-cam configuration with two valves per cylinder.
2002 to 2006, it says.
Zetec Rocam (Duratec 8v)
was cam chain driven, but I'm not sure, none sold here.USA
to replais coil fot aircon on bantam 1.6 Rocam
Ford bantam 2005 160i dash lights working battery not dead but when u turn ignition bakkie won't start
How to remove a water pump of ford bantam rocam
