Question about Sport & Outdoor - Others
Over heating light
I have an 2004 atv Arctic cat 400 auto. I ran in a hot day and my o-h light was on but the fan did not start before. He started very late and he got off with the o-h light still on. I made the road remaining (~10 miles) at high speed to vent the radiator always with the o-h light on. Was it dangerous for my motor/transmission and where is the problem?
  • 4 Answers
Yes it was bad to run the engine hot. When the light came on you should shut the macine off and take it an authorized repair facility as soon as possible. Your problem could be electrical or something as simple as the radiator is low on coolant or the cooling fins are clogged with dirt and wont allow air to pass through them. In any case you should take the machine to an authorized repair facility that will warrant their work and use good parts to fix the problem.
Posted on Sep 21, 2009
    New Friend:
  • 41 Answers
Hello, yes that was not good to run hot!! problem could be low colant, water pump, fan not kicking on (bad sen or bad fan motor) radiator dirty, and could be the hot sen is bad and your not running hot at all. I hope this helps u
Posted on Nov 25, 2008
I have a 05 arctic cat 400 atv. My problem is that it's has constant fire to the coil, with the key off and I can't figure out why.
sounds like the switch may be shorted, or a wire(s) have shorted to one another.... Find the plastic connector for the switch and unplug it... it should not fire.. if it does.. maybe someone has hot wired it??? ... BE CAREFUL!!
2005 Arctic Cat 250 300 400 500 650 ATVs Service Repair Workshop Manu
Arctic Cat ATV repair manuals
Arctic Cat ATV Service Repair Manuals
Arctic Cat ATV Service Manuals Online
Jul 15, 2017 | ATVs
I keep losing spark and my 400 artic cat will not start. I have checked the ignition coil, magnets, and the cdi. What should I check next?
Sometimes when bad parts heat up they fail. I have seen this with the cdi. Be very aggressive when checking your connections. Do you lose spark after it has been run for a while or at certain temps?
Apr 02, 2017 | Arctic Cat 2004 400 DVX
The starter engages and starts the motor fine when the motor is cold. however if you ride and try to restart the starter just spins and you can only start using the kick stater.
"ATV" service and repair manuals - CRXSi.Com
.. arctic cat 400 4x4 engine · 04 arctic cat 4x4 400 4 wheeler manual trans startergears ... 2000 2x4 red atv artic cat repair manual · 2000 300 arctic 4 wheeler instructions .... 2007 arctic cat 90 c c four wheeler wiring diagrams · 2007 arctic cat 90four .... Atv Arctic Cat 2010 - Arctic Cat Dvx 300 And 300 Utility Service Manual ...
Aug 12, 2015 | Arctic Cat 2007 90 DVX 2x4
Arctic cat troubleshooting
oil cooler is plugged go pressure wash it and clean it if that don't work cracked head
Aug 08, 2014 | Arctic Cat 2004 400 4x4
Artic cat 400 i started it let it run for 10 minutes and then it died and will not start now is not getting any fire to the spark plug
guessing you changed the spark plug? .. you can fry the coil from heat...I used to wrap coils in rags when I tested them on a coil tester to try to make them break down from the heat quicker. It worked too.
Mar 29, 2014 | Arctic Cat 2004 400 DVX
Arctic Cat 400 dvx clicks, but doesn't start
Weak battery. Bad connection between battery and solenoid or btween solenoid and starter.
Here are the service manuals for all Arctic cat ATvs
Parts House Lawn Mower Parts and Chain Saw Trimmer Parts
Feb 15, 2014 | Arctic Cat 2006 400 DVX
Sport & Outdoor - Others Logo
269 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
