Question about Maytag Dryers
Maytag dryer model no LDE6704ACL, SERIAL NO A1539648KK. Dryer gives squeaking, squeaking, squeaking noise when drum rotates. How do I take a front panel out to see inside? Where are the screws to lift the panel out?
  • Maytag Master
  • 17,130 Answers
This can be due to fault in the bearings or if the drum is warbling within due to suspension issues. Please check the link below for help:
http://www.espares.co.uk/advice/tumble-dryers/a/9
Posted on Jul 08, 2011
SOURCE:
My bosch Nexxt WTMC 3300 dryer makes a squeaking sound when the load is light -- drying a larger/wetter load less likely to make the noise.
I had a similar problem with a different model Bosch dryer. First I made sure the dryer was unplugged. I found, after taking the front and rear panels off, that one of the front wheels that supports the drum was broken. I replaced the wheel and it works fine with no squeaks.
Jan 01, 2013 | Bosch Nexxt WTMC 3300 Electric Dryer
Drum making harsh squeaking sound when maytag dryer model MDE 9606 in use
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Jan 01, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Neptune dryer makes a banging noise on the left side each time the drum rotates
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Dec 12, 2010 | Maytag MDE9700AYM Electric Dryer
I have a maytag dryer model MDE3757AYW that is making a loud squeaking/sqealing noise. the drum still turns and dries the clothes though.
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Oct 02, 2010 | Maytag Dryers
Makes squeaking noise when running
A common problem with many dryers is the wearing of the guide slides or wheels. Different dryers use different methods of hold the drum in place by giving it something to “ride” on. These guides can be either in the front or the back, but usually the back ones wear out first. This is because the drive belt is in the back and puts a bit of extra stress on the back of the dryer drum. The belt can also causes squeaks or “bumps”, thumping, etc… so it is important to either change everything or determine which part is causing the problem.
When these guides or the belt wears it can cause squeaks, thumps, bumps, slow rotation, etc…
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 28, 2009 | Maytag SDG3606A Gas Dryer
MAKING SQUEALING NOISE
heatman101
fgsj
Oct 19, 2009 | Whirlpool GGW9250PL Gas Dryer
Dryer noise
A drum support wheel bearing could need lubrication or be replaced.  Also some drum support wheels have a rubber coating that wears off causing misalignment and noise.  Possibly drum gasket (sometimes felt material) where drum meets rear panel is worn allowing metal-to-metal contact--should be replaced.
Jun 02, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Dryer makes rumbling noise intermittently
It sounds like a faulty roller under the drum. Need to pop the top of the dryer, then remove the front -- you'll probably easily spot the faulty part.
May 06, 2009 | Maytag Dryers
Loud noise
First, UNPLUG YOUR DRYER! Now open the dryer door and remove the 2 screws at the door hinges... remove the door and set aside, then remove the 2 screws opposite the hinges. Grasp the front panel near the top, just below the top panel and pull it toward you... do this on both sides. Tilt the panel forward then lift it off of the lower clips.
With the front panel gone, you'll see a 5/16" screw just below the top panel on both sides, top left and right. Remove these and the clips too... now you can lift the top panel like the hood of your car.
To gain further access, remove the 6 (3 on each side) screws holding the front drum support/blower vent panel, then set this aside.
If you want to remove the drum... first, take a flashlight and look closely at how the belt is routed around the idler pulley and the motor shaft. (You'll have to re-route it for reassembly.) Reach in there with both hands, with one hand rotate the spring loaded idler pulley back to release tension off the belt, then with the other hand remove the belt from the motor shaft. Now lift and pull the drum out the front of the cabinet.
Check to make sure the rollers in the back rotate freely. You can remove the rollers, buff the roller shafts with emery cloth, lube the shaft with light oil (like sewing machine oil) and reinstall the rollers. Lube the idler pulley also. Rotate the motor by hand and listen for the squeak you described.
Also check the front drum support panel you removed earlier. The drum rides on this as it rotates... As you are looking at the drum support from the drum side, inspect the 10 o'clock to the 2 o'clock area closely. If the glides (teflon) are worn it'll squeak when it rotates.
Hope this helps. Oh yeah! Almost forgot.... the belt won't squeak at all. It'll be the motor, rollers or drum glides.
Nov 02, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
101 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Craig Butler
Craig Butler
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
