Question about KitchenAid KSB5 Ultra Power Work Top Blender
Blender base gear knobs broke off
The small gear like knobs on the blender base sheared off - only 3 years old. I guess they don't make kitchenaid like they use to.
  • 8 more comments
  • Jongsma Sep 04, 2008
    My blender coupling also sheared off of my KithenAid KSB5, purchased October 2005. When the blender needs to work harder due to some resistance, it jumps off the base and strips the coupling. Knowing this, I now hold it down when I use the blender, though it's inconvenient. Today, though, the entire coupling ground into powder while I was holding it down. Arrgghh!
  • Anonymous Nov 28, 2008
    i have the same problem and am searching for a solution
  • Anonymous Dec 11, 2008
    My blander base gear knobs were polvarized as I was blending a health shake. It only involved fruit. I need assistance to replace gear with something better than rubber.
  • Anonymous Dec 28, 2008
    Same problem. Black base gear knobs have all snapped off! Very frustrating! This blender is new.
  • statement581 Feb 20, 2009
    The same thing happened to me. Spikes started to break off within months and now half the black is gone. greg.rehwoldt@abc-amega.com
  • Anonymous Feb 26, 2009
    same thing happened to mine/ first I thought I had left the egg shells in it, shook the blender to see if it was on, then still heard it, sounded like spoon or glass in it.. sure enough.. the black base gear knobs broke off,I Love my kitchenaid.... do we get the parts free? do they back up the product? anyone know before i go buy a whole new base, maybe I can find one at a garage sale, but mine is such a pretty blue!!!
  • steeljean Mar 08, 2009
    I probably have used mine a dozen times and the same exact thing happened. I am going to call around. I have a bad feeling though.....
  • adriennesaw Mar 11, 2009
    Exactly the same thing has happened to mine. Haven't even had it a year. Noticed lots of black rubber "dust" and realised the turning mechanism had eroded to nothing.
  • Anonymous Mar 15, 2014
    There's a small plastic disk that has dropped down above the blade ... how do I reattach it?
  • Marie Greally
    Marie Greally May 05, 2014
    I have the same problem. A few weeks ago two of the black little knobs came off and yesterday all the remaining knobs turned to dust as I was using the blender. I was making breadcrumbs so there was very little stress on the machine. Can this be repaired?
Http://www.fixya.com/support/t509590-kitchenaid_ks85_coupling_drive
Reports the same problem and a couple of solutions.
Posted on Sep 26, 2008
I have a kitchen aid blender with a polycarbonate jar. The jar leaks at the blade. I noticed it has a plastic nut on the bottom with left hand threads. However the nut will not fit over the drive gear...
Older KitchenAid blenders had a jar that was made so the blade assembly could be removed for cleaning. On the newer models the blender jar and the blade assembly are all one unit so you have to purchase a new jar to get the blade assembly. All of this is dependent on which model of blender you have.
We would be happy to help you. Please a give us a call at 1-800-339-9297 we would be happy to help! One of our repair technicians can talk you through the repair over the phone free of charge. On the bottom of your blender is the model and serial numbers; have these handy when you call so we can help you order the correct part.
We have several blender jars on our Web site http://www.mendingshed.com/kitaidblen.html for KitchenAid blenders. If we don't have the blender jar that fits your model in-stock we can order it and ship it to you. Please contact us with any further questions. You can also email your model number or questions to customerservice@mendingshed.com
Sincerely,
Mendingshed.com Staff
Aug 28, 2011 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
My son shove the mixing jar into the base when it
Hi, it is quite easy to replace. The simplest way is to use the spanner provided here:
http://kitchenaidblenders.co.uk/Home/tabid/36/p/Two-%282%29-KitchenAid-Blender-Coupler-%2b-WS-Fitting-Tool-9704230_2plusWS/ProductID/175/Default.aspx
instructions at:
http://kitchenaidblenders.co.uk/Howtoremoveablendercoupler/tabid/219/Default.aspx
Dec 28, 2009 | KitchenAid KPCB348PPM Pro Line Series...
The blades stopped turning in the middle of blending a batch of hummus Its is a Kitchen Aid blender about 10 years old
Does the motor still work if you take the pitcher off of the base? If so, the rod that's in the blade assembly is probably corroded. The blades are connected to a metal rod that passes through a brass tube through to the piece that makes contact with the motor when you put the pitcher on the base. The grease wears down eventually and if you don't pulse and run the motor for a long time at once, the heat can corrode the bar and cause the blade to stop spinning. You can either disassemble the blade unit, or buy a new blade unit online. google blender parts and you can get one for $10
Dec 22, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Teeth sheared off the coupler drive on KitchenAid Blender
You should be able to remove this assembly from the other parts - then you will have enough room to work on it.
Remember to clean the seal area if disturbed or it may leak.
Aug 20, 2009 | KitchenAid KSB560 5 Speed Blender
Blender base cog is stripped. Can it be replaced
yes you can get a new base. your best bet is to google the brand name and buy the part from the manufacturer
Aug 12, 2009 | Blenders
The black rubber that blender sits on is breaking off.
The piece that you need is referred to as the coupler. The coupler is a breakway part that is designed to shear and/or wear down in the event that the blender is overloaded. This is to avoid damage to the motor.
The coupler may be purchased individually and is an easy repair that can be done at home. You may purchase the part and access step-by-step replacement instructions at the following link:
http://www.mendingshed.com/kacoupling.html
Jun 26, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
The rubber gear that turns the blade in the kitchen aid blender is stripped how do i get a new one or a new blender?
Jun 25, 2009 | KitchenAid KSB560WH 5-Speed Blender
Blender blade not turning, rotating piece on base not connected
this is getting more and more common there is a part between the motor and the drive gear that snaps for no reason . its job is to snap if the blades jam as a "fuse" to save your house from a overheating ,jammed motor . the problem is there are no parts to buy to fix this . if its new take it back to where you bought it . otherwise shipping it 2 ways for repair to the factory is sometimes as much or more as a new blender ........ i would recomend you do one of two things : go to a goodwill or other type shop and get a nice vintage blender , it will last forever ! or move up to a vita mix . its costly but it will realy last you ... this new made in china junk is just bad news even when it has the kitchen aid name on it . its still the same junk ..... good luck........ Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Mar 24, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Top part of base broke off
This just happened to me too, and I think I just fixed it.  First you have to get a replacement part called the "blender coupling" (I got mine online from Goodmans for $3.99).  I also replaced the square drive and slinger (two parts come together for $2.99)-that's the little part that sticks up and attaches to the pitcher.
Unscrew the bottom four screws of the base where the rubber feet are.  Remove the rubber skirt to reveal four screws that hold the motor in.  They are way in there so you'll need a long screw driver.  Remove the motor and unscrew the old coupling.  Mine had not been replaced since my grandmother bought this blender who knows when, so the coupling was really stuck.  I did not have a tool narrow enough to get a good grip to apply enough torque to remove the coupling so I had to try a few other tricks.  If your blender is the same, remove the bottom nut, fan blade and two washers.  This gave enough of a rod to grip to get the old coupling off.  (I also had to use some WD40, and heat and cool the coupling a few times to break the old seal).
Good luck!  Hope that helps!
Jan 09, 2008 | Oster 465 Work Top Blender
KitchenAid KSB5 Ultra Power Work Top Blender Logo
842 people viewed this question
Top KitchenAid Blenders Experts
Appliance engineer
eyecam
Are you a KitchenAid Blender Expert? Answer questions, earn points and help others
