Question about Fuji FinePix 1400 Zoom Digital Camera
Finepix 1400 won't switch on
My battery-powered 1400 switched off while I was downloading images to the pc. Recharged the batteries but now when I switch camera on, it switches itself off half a second later. The batteries are good. I fear it is stuck in USB mode and although have tried reconnecting to the pc, the camera has become an introvert. How can I cure it?
    Master:
  • 425 Answers
I read Something Similuar where This Individual Recharged The Batteries And Then Somehow Rebooted His Comp And The Camera Then began To Respond?
Posted on Sep 04, 2005
Vostro 1400 won't turn on
I doubt there is battery problem, have you tried switching on laptop without battery and connecting through the laptop charger? most probable your battery is not taking the charge. so suggest you to disconnect the battery and try using laptop with charger then you'll find the problem.
Aug 06, 2012 | Dell Vostro 1400 Laptop Computer (Intel...
I have put new batteries in my FinePix A360 camera but it doesn't seem to power on.
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Nov 10, 2011 | Fuji FinePix A360 Digital Camera
Camera won't switch on, put new batteries in it, took a photo to test, since then it won't switch on.
If you were able to take one shot before the camera packed up it can be that the battery does not have charge on it and so after the first shot it has drained the battery. So check out the charge on it or repeat charging to test once again.
Other wise it can be that the camera control unit is faulty. Try and reset by removing battery for a while and trying once again.
Jul 25, 2011 | Olympus Camedia D-540 Zoom Digital Camera
Fuji FinePix E550 Digital Camera stopped working after fresh batteries inserted
due to very low temprature some malfunction may have occured. keep it in normal temprature for few hours and then try switching it ON. even if this not solves take it to some service centre.
Dec 07, 2007 | Fuji FinePix E550 Digital Camera
CAMERA WILL NOT TURN ON
Try new good quality batteries.
i experienced this issue last night. Even after replacing the batteries i had the same problem though the batteries were from a very cheap pack & i'd had them a while. The camera worked fine once i'd recharged my normal batteries. I'm no expert but I expect switching the camera on must use much more power then review mode causing the camera to switch off before it has time to tell you your batteries are low.
Hope this solves your problem!
Sep 03, 2007 | Fuji FinePix S5200 / S5600 Digital Camera
FinePix 1400 won't turn on, it beeps and shuts off immediatly
Toast it seems to be but give a look into Fuji tech support team
May 31, 2007 | Fuji FinePix 1400 Zoom Digital Camera
I have a FinePix 1400 zoom that has been causing a lot of problems. It has errors often when trying to write an image to the card and sometimes seems to suddenly power off when viewing images. It...
I've had 2 of the 1400s and never had a problem. Sounds like your battery contacts may be the problem. Check to see that they are bright and clean. If necessary clean them with a pencil eraser.
Sep 04, 2005 | Fuji FinePix 1400 Zoom Digital Camera
Batteries
The Lithium batteries that are provided with the camera will supply approximately 200 images. The Ni-MH batteries will provide approximate 100 shots per charge. The B-10LPB Lithium Polymer battery will allow 500 - 700 shots per charge and can be recharged approximately 500 times. B-12LPB Lithium Polymer Battery will deliver twice the power allowing 1000- 1400 shots per charge and can be recharged approximately 500 times. The Alkaline batteries, although can be used, is not recommended due to very low battery life.
Aug 31, 2005 | Olympus Camedia E-20N Digital Camera
How can I download captured images to a computer?
You can download captured images with either one of the four following accessories. 1) Included Serial Interface kit 2) Optional Floppy Disk Adapter FD-A2 for floppy disk drive 3) Optional PC Card Adapter PC- AD3 for PC card slot 4) Optional Image Memory Card Reader SM-R1 for USB interface.
Aug 30, 2005 | Fuji FinePix 1400 Zoom Digital Camera
Fuji FinePix 1400 Zoom Digital Camera Logo
138 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
