Question about Motorola Cell Phones
I purchased a Motorola V750 Adv recently. The headset jack will not work. tried several different headsets I know work, but won't work with the v750! Suggestions? Took phone back to Verizon, sales person tried several v750's but none worked with headset. She gave up and I walked out frustrated!
    Problem Solver:
  • 12 Answers
My V750 works with both my hands-free set (BodyGlove from Walmart) and my stereo headphones, but there's a trick to using stereo headphones with the 2.5mm jack. You absolutely HAVE to use the 2.5mm-to-3.5mm headphone jack adapter from Verizon. I had a generic adapter from Radio Shack that I used to use with my RAZR, but it wouldn't work with the V750; tons of people have had the same problem.
The ONLY adapter that will work is the one sold by Verizon. It runs between $10 and $15, and it includes a 32 inch extension cable and a clip-on microphone with a call answer/hang-up button. The plus side is that this adapter turns your favorite headphones into a hands-free kit.
Posted on May 04, 2009
I can hear the call they can not hear me?
Sounds like there might be something with your microphone. We recommend you take it back to point of purchase if purchased recently or CONTACT US if it is within the 1 year warranty.
Mark
Motorola Support
Jun 04, 2014 | Motorola Mobility CommandOne Bluetooth...
We recently purchased the Motorola MS350 radios with headsets. We plugged the headsets in and turned the power on, but are unable to communicate back and forth in handsfree mode. We can switch to PTT and...
The three things which come to mind are:
1) Is the headset the VOX headset intended for the radio model? Sometimes the rings on the plug do not match the internal points of contact if it is not the intended headset. Not all headsets are VOX capable.
2) Is the headset plugged in all the way. (You mentioned plugging in and then turning on. This is good. You must always have the radio turned off when plugging or unplugging an audio device.)
3) Try pressing the PTT on the headset cord one time before switching the dip switch to VOX. (Assuming you have a headset with the small box in the line.)
Lastly, if you continue to have difficulties, contact Motorola at the 800# provided in the user guide. They should be able to assist you.
Best regards.
Sep 23, 2013 | Motorola Ms350r Radio Pack
Motorola talkabout MR350 headset only sends audio and can not recieve
Likely not compatible. One thing to try is to make certain the transmitting unit is turned OFF when you initially plug in the headset. Sometimes if a headset is plugged into a radio when it is already ON, the headset will appear to be in VOX (voice activated) mode and will not allow the user to receive. Also, if this headset has an inline PTT, it may not be compatible with the radio and you would need to use the PTT on the radio.
If this doesn't work, you would need to use the TalkAbout headset designed for the MR350.
Best regards.
Mar 03, 2012 | Motorola MR350R Two Way Radio
The handset lifter works, but no sound can be heard or received by either party
If you have a 510a base, then purchased a Plantronics Voyager Pro headset to replace your old headset, it won't work. Those are two different headsets. The Voyager Pro is not meant to work with the 510a base. The correct headset is this:
Plantronics Voyager 510 Replacement Headset
Good luck from Headsets Direct!
Jan 27, 2011 | Plantronics Voyager 500A Deskphone Adapter...
Motorola H170 headset problem
Try charging it for 24 hours, this should reset the headset. then completely delete the pairing and repair the device. If this doesn't work, there could be a problem with the mic portion of the headset.
Feb 18, 2010 | Motorola Mobility H710 Bluetooth Headset
Motorola bt hs820 will not connect to my samsung a777, it just keeps searching for it. I asked before I purchased this phone if it would work and I was told twice by 2 different people it would work.
Hold the phone button on the headset until the light comes on and the head set beeps. When this happens start the discovery process on your cell phone. When the device is discovered it will ask you for the pass code to pair the headset. I can't remember if it is 99999 or 00000 check with motorola or the paperwork that came with the headset.
Jun 29, 2009 | Motorola Mobility HS850 Consumer Headset
Mic Problems with H700 and Ps3
hmm.
1.well try pressing those little arrow buttons on the top and bottom of the headset.
2.Try charging it until the ring turns green.
3.On your PS3 go into accessories, audio and increase the output volume
Hope i helped :)
May 24, 2008 | Motorola Mobility H700 Wireless Headset
Using headset jack - unit always transmits
Try plugging in headset BEFORE turning on radio. You should see the word VOX (not iVOX) on your display. At least this is what works for me.
May 11, 2008 | Motorola Talkabout FR60 (14 Channels)...
HEADSET
A button must be programmed as a "headset" key. When activated, it will lamp red, and put the conversation on the headset jack under the phone (next to the handset jack).
Or you can purchase a headset with an auto lifter for the handset. It picks up the handset enough to answer the call, but transfers the conversation to your headset.
Apr 14, 2008 | NEC DTU 8D-2 Corded Phone
My_Nokia 1112b -No Audio thru Headset Jack.
Dear
ur mobile's headset jack( system connector ) may be faulty.try that in repair center .otherwise UEM(glued ic) will be the problem.
Regards,
Tamil
Oct 28, 2007 | Nokia 1112 Cellular Phone
Cell Phones Logo
100 people viewed this question
Top Motorola Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
