Question about Polaroid FLM-3734B 37 in. LCD HDTV
Polaroid 37" If they do not have the 10V 1000uF capacitors get the 35V 1000uF. The reason it failed in the first place is because they used the wrong ones. I should have mentioned it the first time. Sorry
  • Greg Frost
    Greg Frost Nov 09, 2011
    Hello , And Thank you for your reply , That 10v 100uF was Replaced with the 25v 1000uF , So you think that it (or) They were the wrong Caps? You are probable right , and you think increasing the voltage rating to 35V 1000uF should fix the problem (Fingers crossed ) For God sakes I replaced all the caps and I only had to substitute only one... Thank you very much...Steve
I followed what everyone else had did and i replaced the caps i took apart the tv it only took about 20 mins and call a local tv repair man to desolder and resolder the caps didnt wanna go that far myself put in higher caps then was in orginally now have 25 v 1000uf cap 105 deg c instead of the 10 v 1000uf 105 deg c tv works great only cost 50 bucks and about an hr of my time
Posted on Sep 04, 2008
    Problem Solver:
  • 7 Answers
The reason for the first failure is use of very poor quality or LOW voltage caps.The 35 volt Radio Shack caps will work fine and will give no future trouble.Too low a voltage rating or poor manufacturing leads to leakage and drying out of electrolytic caps.35 volt versus 10 volt is a higher rating and,within reason,will not cause a problem.For technical reasons don't go extremely high(such as 150 volts).This might cause a problem down the line.
Posted on Sep 02, 2008
Polaroid flat screen without picture/sound/indicator light--only chirping noise
The problem could be in the inverter board located near the display.
Jul 31, 2012 | Polaroid TDA-03211C 32 in. LCD HDTV
Not turning on at all
check your power supply. remove it then remove the metal plates on top of the psu. ill bet you find 2x 1000uf 35V ,4 x 1000uf 10V and 3x 670uf 35V capacitors that are swollen or leaking. if you replace the 1000uf caps it will work but if the 670uf caps are swollen as well its a good idea to replace them as well. the 1000uf capacitors can be bought at radio shack for around 10 dollars. you can use the 1000uf 35V caps for the 1000uf 10V caps if you cant find the 10V ones . the 35V caps are a little bit bigger but still work . you will need a good soldering iron (35-60 watts) and a good desoldering tool . easy to do if you know how to solder.
Jun 29, 2010 | TruTech PLV16320 Television
Not getting power on model FLM3732
A common problem with this television is the power unit. Some of the capacitors go out on them within 2 years. You can buy a replacement power unit for about $150 or if you know how to use a soldering gun you can purchase the capacitors for about $5 and fix the unit yourself.
I just fixed my Polaroid 3732 and it cost me $3.49. I would push the power button and the standby light would come on but the picture would not appear. After I changed the capacitors it starts right up.
You can buy the capacitors on Amazon.com. Search for 1000uf 25v (you need 2 of these) and 1000uf 35v (one of these).
Here is a video you can use that will give you the step by step.
Apr 11, 2010 | Polaroid FLM-3732 Television
CAPACITOR 1000 UFD 16V 105C FOR MITSUBISHI WD-52525 52 IN. TV
no you cannot substitute a 680uf 16v 105c in place of a 1000uf
if you want to put a better capacitor in place of the old 1000uf 16v 105c , then use a 1000uf 25v or 35v 105c
the voltage rating will allow the cap to better handle the circuit
Apr 01, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Capacitor size
Sure- that's the maximum rating. In fact, if Polaroid had used 35v rated caps in the first place, we probably wouldn't all be replacing them.
BTW another replacement that worked perfectly here.
Oct 20, 2008 | Polaroid FLM-3732 Television
Capacitor Voltage
If the 35 volts fit in the space provided for the 16 volts, is OK to use them but they must be 1000uF.
Oct 17, 2008 | Akai LCT2785TA 27 in. LCD Television
37" Polaroid Television repair please walk me through it.
I think your looking at the right thing. What does it say on the capacitors? 10v 1000Uf??? If that is what is imprinted on it then you have the right ones. Use 35v 1000Uf as replacements though.
Aug 31, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
Polaroid FLM-3734B 37 in. LCD HDTV Logo
150 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
