Received BSOD. Ran Chkdsk and learned that I have multiple unrecoverable errors. What next?
  • 3,051 Answers
If yoiu have the recovery disk for the operating system you should be able to repair the operating system that u have .. or you may just have to reinstall the operating system again ok please keep me posted on this ok best regards mike
Posted on Aug 25, 2008
Error code 026
If you mean the BSOD 0x26 error, your hard disk/drive may be corrupt with bad sectors. You may want to check your event viewer to find out if a program is causing this or if it is just bad sectors. If it is a program, I suggest looking up solutions for that program or uninstalling it entirely. Otherwise, you can run a chkdsk to check your hard drives for bad sectors and fix them automatically. In order to do this, you press the Windows Key + R, and then type cmd in the run window. In the cmd window, type (without quotes) "chkdsk /f /r" and press enter. It may ask you to schedule it for the next restart; if so, then just press Y and then enter, then restart the computer. This may take a while, and if the problem persists afterwards, it may be a hardware issue that you should research immediately, as this can severely damage your computer if left unnoticed.
Feb 21, 2014 | Computers & Internet
Tip
Coping with and avoiding Hard Drive Volume Bit-map Errors
If your computer "locks up" or reboots itself, the problem is frequently lost or corrupted files on your hard drive. Most of the time the problem can be corrected by running chkdsk. However, one of the exceptions is when chkdsk reports that the hard drive has volume bitmap errors.<br /> To run chkdsk, click on Start, All Programs, Accessories and Command Prompt. This will open a "DOS Box" where you can enter DOS commands without the results scrolling off the screen before you can read them. Then key in chkdsk C: (assuming that drive C is the letter of the hard drive where your operating system files and applications programs are stored).<br /> Chkdsk will run in the read-only mode and report (but not repair) problems found on your hard drive. Chkdsk will then ask you to run chkdsk with the F switch to fix the file system. Make a mental note whether or not chkdsk reported any problems with the volume bitmap, then key-in chkdsk C: /F <br /> You will get a message that the drive will be checked (and repaired) on the next system restart.<br /> Enter exit to close the DOS box and the restart your system. Chkdsk will run automatically when your system restarts. If no volume bitmap errors were noted earlier, chkdsk should have repaired the problems with the hard drive. You can verify this by opening another DOS Box and running chkdsk without the /F. However, if bit-map errors were reported initially, chances are they will still be there as chkdsk cannot repair them.<br /> If you still have volume bitmap errors, you can either take your PC to a professional who may be able to repair the volume bitmap with specialized software, or you can back-up all of your data, format the hard drive, and reload the operating system and all applications.<br /> A frequent cause of volume bitmap errors is cloning (copying) a hard drive with more than one partition to another (usually larger) hard drive. The partitions should be sized proportionately on the target drive but sometimes the partition sizes are not reported correctly in the partition table and sometimes in the master boot record. <br /> Avoid cloning drives with multiple partitions, or if you do, immediately run chkdsk on the target drive to check for bit-map errors.
on Oct 25, 2010 | Computers & Internet
Tip
How to fix Blue screen of death (BSOD)
BSOD--- Blue screen of death So guys how to get your computer working if you get a BSOD...???
XXX0000000XXX
well first of all check the exact error code and figure out the cause of it,there could be multiple reason
Bad memory
Bad sector in Hard disk
Registry error
Virus/Trojan/Spyware
Keep the windows disk ready....u might need it
Try the advanced boot menu...
See if you can get through F8 key helps a lot
Try last known good configuration.....
If not then try Safe mode with command prompt,if you can get through then use the system restore u need to be a 'C' prompt by using CD command and then pen the restore console (%systemroot%\System32\restore\rstrui.exe)
Otherwise do a flee power
No go yet.....
Hummmm u need the disk bro
Boot with CD (f2 or F12)
Run Chkdsk /p and chkdsk /f on he recovery console
still no go................
Please comment buddy
post a reply
on Jun 13, 2010 | Computers & Internet
Error code 0f00:131b
Most likely hardware. Run a chkdsk on the drive you will have to do it from command prompt.
Example: ckhdsk c: /r/f
Mar 29, 2013 | Dell Studio Xps 9100 Desktop Computer
BSOD Whenever Flash Drive, Phone, Camera 1st Plugged In
they package most bios flash utilities as an exe any more. you'd just have to check your motherboard to find out what version you need and if there IS an update available. also can you post the logs?
Feb 20, 2012 | Computers & Internet
Ran a diagnostic on a SATA Disk Samsung HD160JJ1p and received the following error code: 650F:065D - Message IDE device failed. The self test failed to read a portion of the test. Will a chkdsk fix this...
No, chkdsk will not help: this is a hardware defect - part of the platter of the disk is damaged. The disk is dead, recover what you can from it and get a new one.
Jun 13, 2011 | Dell OptiPlex GX620 PC Desktop
My emachine loads up PCI device listing and cant exit.
You may have to get a copy of windows xp and boot to it and reformat the hard drive and then reinstall windows. I hope this helps.
Jul 27, 2009 | E-Machines eMachines Desktop PC
Operating System not found! HELP!
If you are running windows, Insert your windows cd and set computer to start from cd. When prompted to, hit a key to boot from CD. Let Windows start the install (relax it is not really installing anything) when it gets to the prompt tell it you want to Repair an existing installation. Then pick the prompt that gets you the recovery console. When you get to the prompt type CHKDSK /R and let it run. Sometimes this can take an hour or more depending on the size of your drive. Do not get worried if the percentages complete go backwards, like from 70% back to 50%. Sometimes it will go back and fix files. Hopefully you will not get the error that there are unrecoverable errors. This has worked for me on about 90% of the hard drives that I received the inaccessible boot device and about 30% of the drives where it said OS not found. If this does not work your hard drive may have failed. Let us know.
May 04, 2009 | Computers & Internet
Ive ran out of ideas!!!
If you have tried recovery disks (i.e. reinstalling operating system) and are still receiving BSOD (blue screen of death) then you most certainly have a hardware problem.  As the person asked above, have you installed any new hardware recently?  Also, can you please tell me when you get the BSOD?  Is it immediate upon booting, or does it happen at random times while using your pc?  Also, if you could post the error message received that would certainly help to further troubleshoot your problem.  Thanks.
Apr 22, 2009 | Sony Computers & Internet
Computers & Internet Logo
Brian Sullivan
Brian Sullivan
David Payne
David Payne
