Question about Refrigerators
Ice maker not working no water getting to icemaker
  • 1 more comment
  • sdweb Dec 17, 2008
    Ice maker not making Ice. It is not getting water. The Water outlet in the door also has a "Dealy" before it produces water... Whats going on?
  • waltgardiner May 04, 2009
    dometic 1292 ref w/ice maker. ice maker not getting water. water is at selenoid input.
  • patpyc21 May 06, 2009
    ice maker not working replaced it and selinoid don't hear water turn on
Icemaker is making ice slowly. Crushed ice button does work.
Posted on Sep 04, 2008
Icemaker not making ice
If no water is getting to ice maker either the water feed solenoid is not working, the water line is no good, or the cam mechanism of the ice maker is not switching the solenoid on.
Oct 05, 2016 | Refrigerators
Top ice maker in Samsung RFG298AAPN does not make ice. No water cycles into icemaker. Icemaker has been reset, nothing after 2 days. Should I replace the icemaker or the water valve.
On these models I've noticed that the temperature in the ice maker area warms up due to a ball of ice forming inside the freezer compartment ice maker fan that has vent going to the ice maker. Until it is found whether or not that ball of ice is blocking the vent and fan you won't be able to go to the next step. The switch on the ice maker will test the ice maker by filling it with water and rotating the Forks that dump the ice into the ice bin Appliance 911 Sea Breeze
Aug 31, 2016 | Samsung Refrigerators
Is it OK for ice thickener sensor touch water on ice maker
Yes, it has to touch the water. As the ice builds up the thickness sensor moves up and turns of the refrigeration and turns the heater on.
  • How Icemakers Work ' HowStuffWorks How Icemakers Work. ... we'll look at the cycle an icemaker goes through to make ice. ... Get the best of HowStuffWorks by email. Keep up to date on:
  • How Does The Ice Maker On A Refrigerator Work ... - YouTube
    • 4 MIN
    2012-05-15 · Video embedded · This video provides information on how a refrigerator icemaker works and offers troubleshooting tips ... How Does a Refrigerator Water and Ice Dispenser Work?
  • How Ice makers Work - How Ice Makers Work! Learn How Ice Makers Work, ... How Ice makers Work. The Ice Maker Cycle ' Ice Maker Components ' Cube Size Replacement Ice Makers . They Don't Make
  • How Does an Ice Maker Work? - Refrigerators Here's how your ice maker works. BACK TO . Best Right Now; How To s; Award Winners; How We Test; ... How Does an Ice Maker Work? It's more complicated than ...
  • Refrigerator Icemaker Repair How It Works
    May 12, 2016 | Refrigerators
    Ice maker is not making ice through the door water is working
    first thing to do is check to see that water is getting to the icemaker simply stick your finger inside the ice maker and check that there is water in there usually icemaker can be removed by three screws 1/4" against the wall if you have water and can feel ice on the inside remove the icemaker and flush with hot water then reattach the ice maker and wait 24 hrs to see if you get ice if it still does not work then your in need of a new icemaker which uyu can get from marcone appliance parts they willship the unit directly to your door and you wont have to pay a technicain installation charge hope this helps
    Jun 26, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
    My icemaker has stopped receiving water
    it sounds like your water valve is bad. you have a double water valve - one side operates the ice maker and the other side operates the water dispenser. the ice maker side of the valve is bad.
    you can manually pour a little water in the ice maker ice mold and wait an hour or so - if it dumps the ice then you know for sure that the ice maker is cycling and water is not getting to the ice maker from the water valved
    May 25, 2010 | GE GSS20IEP Side by Side Refrigerator
    Icemaker does not work
    if the ice maker cycles but is not getting water check the water supply valve that supplies the water to the machine it split and sends water to the door and the ice maker that side of the valve that goes to the ice maker could be bad you can test it with a 120 volt line cord plugged in the wall plug to that side of the water valve if it works with the hose disconnected it may be a blockage or frozen line to the ice maker
    Apr 09, 2010 | Refrigerators
    Icemaker not working
    The ice maker valve is a dual one. with 2 solenoids. One solenoid operates the water and the other the ice maker. So if the water works that don't mean the ice maker supply is ok. The ice maker itself controls the flow of water. So if the water valve is ok then the ice maker is faulty. I have repair photos HERE
    Feb 14, 2010 | Refrigerators
    GE refridge icemaker won't work
    The ice maker unit give the command to the water valve to relese water for a short time.
    you cna check with volt meter on the water volve that got the pip go to the ice maker unit if it getting 120V for short time when the fingers of the ice maker making full round.
    if you get 120v the problem is the valve (the ice maker and the water have difrent water path so its difrent valve used) if you dont get 120v or the fingers of the ice maker not turning then its your ice maker unit need to be replace.
    I hope you find this Very Helpful and best regards!
    Jan 03, 2010 | GE Refrigerators
    Whirlpool IceMagic Plus not working.
    Pour about 2/3 cup of water into the ice maker . If it dumps the ice but doesn't refill , replace the ice maker . If it doesn't dump , and the cubes stay in the ice maker , replace the ice maker .
    The switch on the icemaker for normal , runs the icemaker normaly . In the ice plus , a small fan comes on , blowing the inside air , over the ice maker mold , to help it freeze faster .
    Sep 14, 2009 | Refrigerators
    Refrigerators Logo
    924 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
