Question about Canon Rebel XT / EOS 350D Digital Camera
Digital rebel EOS 300D
I need instructions for replacing the card reader in my canon EOS digital rebel 300D
  • taja33 Sep 06, 2008
    I too need same. i think one of the pins in reader is bent? Any help would be appreciated
Thanks K
You were right.Not a DIY. I end up getting a 450D and are awaiting the return of the body to sell for parts. It was going to cost around $600 Aus to fix! Very impressed with the 450!
Posted on Sep 22, 2008
    Problem Solver:
  • 6 Answers
The card reader on this camera is soldered on the mainboard, therefore it requires professional SMD soldering equipment and skills, sadly, not a DIY job. You either sell it for parts on ebay, or buy a broken one (with a good mainboard) from ebay, and replace the mainboard. That should cost you around £50-60 (far less than a professional repair job)...
Follow this link on disassembling 300D (in case you want to replace the mainboard yourself)...
http://ghonis2.ho8.com/rebelmod.html
Good luck!..
K.
Posted on Sep 21, 2008
Sent it off to Canon. Bigger problem that 1st thought. Damaged pins mean a costly fix.
  • 81 Answers
Once the CF access door is open, just push the small square button that will be below the card. That moves it out enough to pull it out. When putting a different card in, take care not to just jam it in as you could bend the pins.
Posted on Sep 18, 2008
Windows 7 unable to recognize EOS 300D
Try using a card reader instead of the camera.
Oct 07, 2010 | Canon Digital Rebel / EOS-300D Digital...
My Digital Camera, EOS 300D, Digital Rebel EOS 5D is not compatible with my new Windows Vista. I can't download my images.
There are two was around this:
1) Get an external USB card reader - I recommend this, because it is faster and does not require any software updating
2) Download the latest EOS Utility from the Canon web site; you also need to download the latest drivers. The cameras you name are supported by Vista, but the original software isn't.
Jul 07, 2009 | Canon Digital Rebel / EOS-300D Digital...
Will a quantaray 28-105 1:3.8-5.4 Zoom lens Autofocus from a 35mm rebel ti fit on Canon EOS Digital Rebel 6.3 MP 300D?
The 35mm Rebel Ti and the Rebel 300D use the same lens mounting protocol. All Canon cameras designated 'EOS' use the autofocus EF lenses. If your Quantaray lens worked on the Rebel Ti, it will fit and should work on the Rebel 300D.
Mar 19, 2009 | Canon Digital Rebel / EOS-300D Body only...
I have images on my card, but my Canon EOS Rebel 300D says "no images in the camera or card folder" how can I get them to download. Will they download at a Wal-Mart card reader?
look very carefully at the pins inside the socket.. you might have a bent or broken pin making the camera unable to read the card. Also, if the images on your card are not Jpg or CanonRAW, the camera won't recognize them.
Feb 28, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon rebel eos ds6041
DS6041 is the model number for Canon EOS Digital Rebel or 300D. It is a 6.3 megapixels DSLR camera from Canon.
All software and manuals available from the Canon site
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=314&modelid=9430
Feb 18, 2009 | Canon Digital Rebel / EOS-300D Digital...
CF Card not found
Ok here is the issues with the Canon 300D digital Rebel XT model of camera. First issue bent pins or broken pins the CF card reader on this camera is Surface mounted soildered onto the bottom half of the mainboard a large ammount of disasimboly is required. After removing the mainboard next you need is a desolder rework station. to carefully remove the CF card reader from the mainboard one messup and it might be easier to replace the mainboard. Sometimes. next issue is the power issue if you have no bent pins or missing pins, and the battery door is pushing on the door closure switch and the memory card door is pusting on its door closure switch then most likely you issue is 1 of 3 fuses underneath the power switch. these switches are the size of a few grains of salt very very small.I charge 150.00 to change the fuses and 225.00 to replace the CF card reader as long as none of the traces are damaged. if they are damaged the main board would need to be replaced and it is around 250.00 + depending on the parts cost at the time. If your good at soldering go for it. if not then let the experts do it.
Dec 22, 2008 | Canon Digital Rebel / EOS-300D Digital...
MANUEL OR INSTRUCTION
This Product Model Code DS6041 is a Canon EOS D-SLR named either "Digital Rebel" or "300D Digital".
You may try these links:-
http://www.theusermanualsite.com/manuals/mfg/canon/eos_300d.html
or here
http://www.cleaningdigitalcameras.com/pdf/EOSDR300DIM-EN.pdf
I hope I can help you!
Feb 16, 2008 | Canon Digital Rebel / EOS-300D Digital...
Canon Rebel XT / EOS 350D Digital Camera Logo
112 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
