Question about Fuji FinePix 1400 Zoom Digital Camera
I have a FinePix 1400 zoom that has been causing a lot of problems. It has errors often when trying to write an image to the card and sometimes seems to suddenly power off when viewing images. It doesn't appear to be batteries because I've tried fresh ones straight out of the package. I don't think it's the Smart Media card because it does the same thing with 3 different cards of different sizes. Any ideas?
    Master:
  • 425 Answers
I've had 2 of the 1400s and never had a problem. Sounds like your battery contacts may be the problem. Check to see that they are bright and clean. If necessary clean them with a pencil eraser.
Posted on Sep 04, 2005
How to fix fujiflim xp50 zoom error
You've given us a lot of information, but unfortunately no specific description of the error.
Jul 08, 2016 | FUJIFILM Fujifilm 16233283 Compact Camera...
Can i use sdhc class 4 or 6 cards in my fuji finepix 6900zoom
The FinePix 6900 Zoom uses SmartMedia (3.3v) for image storage, and a 16MB card is supplied with the camera. Upgrades are available up to 128MB. The entire SmartMedia card can be write-protected by placing a small sticker on the indicated area of the card. Write-protection stickers can only be used once, and they must be clean to be effective. Individual images can be protected through the Playback menu, which prevents them from being accidentally deleted (except through card formatting).
Dec 22, 2009 | Fuji FinePix 6900 Zoom Digital Camera
I got the card not initialized error
If you can still access it using your PC, copy all the images on the memory card and then once done, reformat the SD card. Try and check if this solved the issue.
Apart from that error, are you getting errors like "Zoom Error"?
Aug 31, 2009 | Fuji FinePix E500 Digital Camera
Zoom error
Just fixed the same problem on mine. This is what I did:
Unscrew 6 small screws around the lens casing and remove the casing (two layers ((rings)). Jiggle the inner most lens casing while you turn power on. The lens moving (i.e., auto focus) mechanism becomes unstuck. Voila.
The problem in my case was caused by the dust that accumulated inside the casing and caused the auto focus mechanism not to move freely.
Good luck.
Mar 05, 2008 | Fuji FinePix S7000 Digital Camera
Fuji FinePix 2600 Zoom Digital Camera Problem
If you have a card reader for your computer, see if the card works on your computer. If it does then try just using windows to format your card, sometimes after extensive use cards can have their contents table messed up with lots of pictures being erased and created. Otherwise try another card to see if it is the camera itself. If more than one card doesn't work its probably the camera, and unless you bought a extended service plan with the people you bought it from your probably be better off to buy a new camera then trying to get it fixed. Small electronics like cameras are very rarely cheap to fix and thats if the manufacturer will even consider doing it
Aug 26, 2007 | Fuji FinePix 2600 Zoom Digital Camera
FinePix 1400 won't turn on, it beeps and shuts off immediatly
Toast it seems to be but give a look into Fuji tech support team
May 31, 2007 | Fuji FinePix 1400 Zoom Digital Camera
Error message on camera "Card not initialised"
I had a similar issue with my Fuji E500. I had been working with it on my Mac, which automatically brings up iPhoto when it's plugged in via the USB port. When I removed the camera from the USB port, it turned on with a Card not initialized message. If your situation was similar to mine, here's how I fixed it: Plug the camera back into the USB port and turn it on. When iPhoto loads, Got to finder and select Eject (unknown) device. Then, when you disconnect the camera and turn it on, the message about not initialized doesn't show up and you're back in business. I hope this helps.
Jan 24, 2007 | Fuji FinePix E500 Digital Camera
Finepix 1400 won't switch on
I read Something Similuar where This Individual Recharged The Batteries And Then Somehow Rebooted His Comp And The Camera Then began To Respond?
Sep 04, 2005 | Fuji FinePix 1400 Zoom Digital Camera
How can I download captured images to a computer?
You can download captured images with either one of the four following accessories. 1) Included Serial Interface kit 2) Optional Floppy Disk Adapter FD-A2 for floppy disk drive 3) Optional PC Card Adapter PC- AD3 for PC card slot 4) Optional Image Memory Card Reader SM-R1 for USB interface.
Aug 30, 2005 | Fuji FinePix 1400 Zoom Digital Camera
Fuji FinePix 1400 Zoom Digital Camera Logo
49 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
