Fisher MC720 with a Matsushia VA2531G0023 turntable
What size electrolytic is across the turntable motor power plug?
Fisher Paykel GWL11- US Washer
- Motor control module fault:
Fisher and Paykel washing machine error 1:
Primary Source: Motor control module.
Action: Replace motor control module.
3 - Motor control module fault:
Fisher and Paykel washing machine error 3:
9 - Size setting fault:
Fisher and Paykel washing machine error 9:
Action: Reset machine size as per service manual instructions. If fault repeats replace Motor control module.
10 - Temperature Sensor (Thermistor) Error:
Fisher and Paykel washing machine error 10:
Primary Source: Thermistor.
Action: Replace Thermistor.
11 - Pressure Sensor Fault:
Fisher and Paykel washing machine error 11:
Primary Source: Pressure Tube.
Action: 1 - Empty all water from the machine. Remove pressure tube from pressure sensor, clear pressure tube of any water and reconnect tube (blow down the tube is necessary). 2 - If fault repeats, replace Motor Control Module.
12 - Flood Protection Error:
Fisher and Paykel washing machine error 12:
Primary Source: Water Valves.
Action: If the water valves are on continuously, check that the water valves turn off mechanically by disconnecting power to the machine.
Secondary Source: Pump System.
Action: Check pump for blockage and drain hose for correct height(end not immersed in water) or kinked.
Tertiary Source: motor control module.
Action: If water valves are been driven on electrically, replace motor control module.
36 - Water Leak Fault:
Fisher and Paykel washing machine error 36:
Motor control module has needed to top up the water level more than 4 times during wash/rinse cycle. Most likely cause is waster siphoning out or the machine has developed a leak.
Primary Source: Drainage system.
Action: Check that the hose is not less than 850mm from the ground
Secondary Source: Pressure tube.
Action: Make sure the pressure tube is fitted correctly and doesnt have any holes.
37 - Blocked pump:
Fisher and Paykel washing machine error 37:
Primary Source: Drain System.
Action:
1. Check that the drain hose has not been kinked.
2. Check the length of the hose. 1m is maximum extension.
3. Check drain pump winding for open circuit.(Note: Pumps are fitted with a thermal cut out and will reset after cooling)
4. Check for physical blockage to pump and hoses.
38 - Pressure Sensor Fault(empty reading during wash cycle):
Fisher and Paykel washing machine error 38:
Primary Source: Pressure tube.
Action: Check if tube is fitted correctly, check for blockages or holes in the pressure tube.
Secondary Source: Motor Control Module
Action: Replace the module.
39 - Pressure Tube Fault:
Fisher and Paykel washing machine error 39:
Same as fault 38.
40 - Bowl Dis-engage Fault:
Fisher and Paykel washing machine error 40:
Primary Source: Mechanical.
Action:
1. Check that there are no clothes or other foreign objects preventing the clutch from re-engaging. Excessive suds can also stop the bowl rotating.
2. Check the clutch splines for physical damage.
3. Check that the pressure tube has not come off, kinked or blocked(blow down the tube.
Secondary Source: Motor Control Board.
Action: Change Board.
43 - Out Of Balance Switch Fault:
Fisher and Paykel washing machine error 43:
Motor control module has found that signal returning from the out of balance switch indicates that the switch is permanently on or the harness to it is disconnected.
Action:
1. Check the level of the machine.
2. Check wiring to the switch.
3. Check switch for continuity and corrosion.
44 - Water in Bowl During Spin:
Fisher and Paykel washing machine error 44:
Primary Source: Drain system.
Action: Check for blockages/kinks in drain hose and function of the drain pump.
48 - Hot and Cold Inlet Valve Incorrect Signal:
Fisher and Paykel washing machine error 48:
Primary Source: Wiring.
Action: Check the wiring.
Secondary Source: Inlet Valves.
Action: Check the resistance of the coils.
Tertiary Source: Motor Control Module.
Action: Change Module.
49 - Cold Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 49:
Action: See fault 48.
50 - Hot Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 50:
51 - Diverter Valve Fault:
Fisher and Paykel washing machine error 51:
Primary Source: Blocked diverter valve.
Action: Check for foreign objects in the valve.
Secondary Source: Motor Control Module & Diverter Valve
Action: Plug the machine into the power point but off at the control panel. Check voltage on the plugs at the diverter valve. If voltage around 230V, change diverter valve and motor control module
Oct 07, 2016 | Fisher and Paykel Washing Machines
Pioneer P L-L800 tangental tracking turntable. With a motor speed problem? I'm the original owner, the turntable has less than 500 hrs on it and it was totally working when put into storage some years ago....
One possibility is that when left and not used Electrolytic Capacitors in the power supply can dry up and cause voltage changes that might effect the speed. It might be wise to replace any large value ones in the supply to the motor. Follow the wires or circuit from the motor till you come across any suspect capacitors.
Jan 03, 2015 | Audio Players & Recorders
F & P MW511 Washing Machine ... Driving me Mad ... Please Help!
Size setting
Action - Reselect the size of Smartdrive by using the SIZE SETTING MODE. Push and hold
the water temp up button, then press the power button to enter SIZE SETTING MODE. Three
LEDs are used to identify size.
The cold water temperature LED identifies 5kg.
The low water level LED identifies 6kg.
The hold spin speed LED identifies 7kg.
If the product has not been setup before all 3 LEDs will be on.
To set the size for 5kg push the wash temp up button then
the power button.
To set the size for 6kg push the water level up button then the power button.
To set the size for 7kg push the spin speed up button then the power button.
This locks the size
into memory. To check the size is set, start a cycle.
Aug 16, 2012 | Fisher and Paykel Fisher & Paykel Washer
I use my Sl1200 with Serato and the other day one of the decks was starting slow. I solved the problem by spinning the record first and then placing the stylus down. But I want it to go back to the way...
p { margin-bottom: 0.21cm; }
HI,
After long years of use the electrolytic capacitors in the circuitry will get slightly change its value. If so it can affect the speed of the turntable. Its better to replace all the electrolytic capacitors in the turntable's electronic circuit board. It will not coast a lot for all the capacitors. Will only come around $3 or $4. .
OK
Oct 28, 2011 | Technics SL-1200MK2 Turntable
I recently had my deck stored in it's box for a few weeks after I had played a gig. When I opened it up some kind of brown liquid (presumably oil) had leaked out. The power switches on, but now the platter...
Brown liquid huh? A small amount may be a blown electrolytic capacitor. Take a look around for a component that's about the size of a pencil eraser and also brown. Or - just some wires where it used to be. This can happen in storage if temps are too high or low and it can just plain happen. If there's a LOT of brown stuff, then its probably external contamination. Can you run your finger across it and give a sniff - see oily stuff on your finger? In that case, you've got a serious clean up job ahead. Tons of contact cleaner and/or alcohol and lots of careful work are in your future. DO NOT power up anything until you've totally cleaned up everything - it will only get worse if you power it up and things can short out.
Oct 22, 2010 | Technics SL-1200 Turntable
Hi, I have a Fisher & Paykel Phase 5 IW709 top load washer. It has an intermittant problem (although becoming more often) that appears related to the pump . Upon power up at the wall plug there is...
i have come across this problem before ,yes the pump is apart of the switch mode power supply in motor controller,the motor controller also changes the speed of the pump by altering the hertz range ( for lint rejection) unfortunatley you will have to replace motor controller ......to solve this problem
Feb 11, 2010 | Fisher and Paykel Fisher & Paykel Washer
JVC - problem. The turntable does not move,
Most modern day turntables are semi-automatic. You move the tonearm from the rest post
over to the record and the platter will start turning. There is a small microswitch inside
either below the arm base or near. There should be a flat bar connected to the base of the arm
and this will actuate the microswitch. The switch is wired in series to the rotation motor.
Solution: 1. Obviously verify the belt is on. Take off the rubber mat and rotate the platter.
The rotation motor is on the left and it has a small brass spindle. The belt should
be visable through the holes in the platter. If not pull the platter gently up, there will
be some resistance. The belt wraps around a smaller inner ring on the underside
of the platter and the rotation motor spindle. If it is degraded it will be stuck to the
platter or fall apart. Generally there 3 common sizes. ( 21.4 / 23.6 / 25 inch) they
readily available on E-Bay, search term "turntable belt".
2. Obviously check power.
3. Check the microswitch, it should "click", verify with ohm meter.
4. Some turntables have a "cut" or stop function. The arm must return first to rest before
starting again, again the microswitch is the trigger.
Apr 07, 2009 | JVC AL A158BK Turntable
Fisher and paykel iwl10 or iw810 changing motor controler
Hi, welcome to FixYa.
Typically, the "machine size" setting must be programmed into the new control when it is first powered up. Fisher Paykel includes a tech sheet with the replacement control that explains how to do this. On most machines, with the power off, you hold the water temp UP button down with one finger, then press the power button. This activates the mode for setting the machine size. You then select the machine size and lock it in when you shut the power back off. Now the machine is ready to use. On some models, the digital readout screen displays these settings and it is very easy to do. I hope this is useful info to you and thanks for using FixYa.
Jan 30, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Sony PS-LX250H Turntable Problem
If Sony does not have it available, you won't be able to find one. You can go generic, but you have to worry about size and fit.
- OPTiC
Turntable Technician
www.1200s.com
Sep 01, 2008 | Sony PS-LX250H Turntable
Fisher-paykel electric dryer
Try turning it on while holding the door switch and give the drum a spin. If it starts you will need a motor if it does nothing then look for a solenoid.
Dec 20, 2007 | Fisher DEIX2 Dryer
278 people viewed this question
 Grubhead
Grubhead
