Question about Olympus Camedia C-60 Zoom Digital Camera
Green power light continues to flash when camera is "off"
I just put this note in with some people's messages re: same problem but I see it's coming up in the "solved" category because someone suggested that maybe there's an additional battery of some sort somewhere else in the camera. I didn't think that was a solution, so I'm re-posting in this area. In a nutshell, the green power lamp next to the selection wheel on top of the camera continues to flash even when the monitor is turned off and the lens barrier is shut. It will flash until the battery has no charge left. I couldn't find anything in any reference material that came with the camera. Finally called Olympus and the customer service guy consulted all his reference material, his peers and his supervisor and could not tell me what's going on. They did send me a new battery :) but it didn't help with the flashing light. I don't think it's a matter of barrier incomplete closure or anything like that. One thing I did notice is that when the power lamp is flashing and the lens barrier is closed, the monitor doesn't want to come on right away - sometimes I have to try three or four times to get it to come up so I can view pictures.
If anyone has any ideas about this or has found a solution (other than removing the battery when camera isn't in use), I'd really appreciate it.
Regards,
Bonnie
  • bcomfy Sep 23, 2008
    That worked for me too, once. The next time it didn't work. Couldn't figure out why. And, yes, the first time I had the flashing problem, it was right after I had installed a freshly charged battery! I've been using the camera a lot and it hasn't happened again at all in the last three weeks. However, I did get a second battery about that time and now I never put a freshly charged battery in the camera! I charge the one that's just run out and then keep it in my camera case until needed. You don't suppose that just gives it enough time to discharge enough to avoid the problem...? It's the only thing I can think of that's different now.
I had the same problem after inserting a freshly charged battery. I finally got rid of it by just removing the battery over night. The next morning when I inserted the battery, the camera worked as before.
Posted on Sep 22, 2008
How do you know if you have a voice mail message
Yes, the was bothering me for some time. I think the indicator is a little green light that blinks in the extreme upper left hand portion of the phone...not on screen, above it....but the blinking light may indicate a missed call or a voice mail is present.
Try this. Go into your phone icon, press and hold '1' and listen to any open messages. Delete each. Next go into your Call Log and delete all call history. Now exit.There should be no green light flashing in the upper left hand corner of phone. You have just cleared everything.
Next call your phone but hang up before leaving a message. Note the blinking green light in the upper left hand corner apparently indicating you missed a call. Go into your Call Log. It will say one missed call. Exit the call log and note that the blinking light is now off. You have acknowleged the call in the call log so the light goes off when you exit.
Call the phone again. This time leave a message. Note the blinking light again. Go into your call log again. Note the missed call. It would be nice if there was an icon or something HERE that indicates if this call left a voice message....but there does not appear to be. Exit again. This time note that the light continues to blink even though you entered the call log and acknowleged the call. I believe it continues to blink because you have a voice message. Exit.
Go into the call log again. Delete the missed call from the call hsitory. Exit. The light still blinks, I believe still indicating a voice message.
Go to your phone icone. Press '1' to check messages, delete the message and exit. The blinking is now gone.
So it appears a blinking green light indicates a missed call. If it still blinks after exiting the call log, you have a voice message.
If someone figures something else out let me know because this stinks!
May 28, 2014 | AT&T GoPhone Radiant
Samsung camera problems
when trying to power off the camera a green light which is on the right corner blinked and the images are displayed continuously. What could be the problem?
Apr 25, 2013 | Samsung ST30 Digital Camera Pink
When you turn of the TV the POWER indicator flashes green for several minutes. The TV never comes on. After the several minutes of the POWER indicator flashing green, it stops, I hear a click and the...
A continuous flashing red light with the word LAMP on it would definitely mean you're going to need to spend a few bucks on a new lamp....or for a few more, upgrade to a TV from this century that doesn't require lamp changes :)
May 11, 2011 | Panasonic PT-52LCX66 Projection Television
Turn on power, green light flashes, powers off
Hi there its happens when the lens not ready for work. Some how its not able to stable his focus method. That's why its come out & go back. There is a chances of lens guide pin disturbed or damaged & thats why green light blinking continues. Its mean he inform you there is a system error. So please visit the service center for repair that. Thanks.
Apr 02, 2010 | Rokinon DZ1000 Digital Camera
When charging battery green light flashes then red 3 times
KODAK Easyhare digital camera light status
1. Blinking green light(or blinking blue or white light in some models) - Means camera is performing a power up procedure. Note: Wait a few moments to see if the camera displays a solid green (or blue or white) light or a blinking red light.
2. Solid green light(or blinking blue or white light in some models) - Means Camera has sufficient power
3. Blinking red light - Means camera batteries are weak or need replacement; If battery are new and still red light camera needed to be repaired
For futher assistance contact Kodak support line 1 800 235 6325 (23KODAK)
Nov 21, 2009 | Kodak EasyShare M863 Digital Camera
Flashing green light prevents printing.
hi!!!!
try to pull out the cardtridge and put it back properly
sometime the cartrigde is place properly on the printer!!!
try to email me ronaldsuboc@gmail.com
Aug 08, 2008 | Canon S520 InkJet Photo Printer
I also have the same problem.
Does anyone know the solution?
Mar 30, 2008 | Polaroid One600 Ultra Instant Camera
Olympus Camedia D-565 Problem
you left it too long for a free replacement
But it is worth contacting Olympus as it is know this one was a lemon.
Jan 15, 2008 | Olympus Camedia C-350 Digital Camera
Error code messages in the status panel of the Fun! Digital 320 camera.
The following is a listing of the error codes you might see on the status panel of the PhotoMAX Fun! Digital 320 camera: 1.FL - Photo memory is full. You cannot take more photos. Download and then erase the photos in your camera. 2.FE - Flash memory error. A camera hardware error occurred. This can happen when the power is shut off before a photo is completely stored in the camera. Do not shut off the power until the green light comes back on steady after you take a photo. 3.bE - Hardware problem. Turn the power switch on and off and see if the error message disappears. If the error message persists, the camera may need to be replaced. 4.Lo - Battery low. Replace the camera battery as soon as possible. If you continue to use the camera, picture quality will be poor. 5.LL - Low light condition. The camera does not have enough light to take a good photo. Improve the subject lighting if possible. Example: When taking indoor photos, add additional room lighting.
Sep 21, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
Olympus Camedia C-60 Zoom Digital Camera Logo
104 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
