SOURCE: Why is my projection dark and muddy compared to the brightness on my computer screen?
John here, customer advocate at Dell headquarters. If you can nvigate to the On Screen Display Menu, you should see an "all images" section on the main menu. There you will find brightness, contrast, color temp, white intensity, and gamma controls. You should be able to make adjustments from that menu to sharpen and brighten the image.
SOURCE: Polarview 211e
Go to:
System Preferences (you can get there by clicking on the Apple Menu in the top left corner) -> Displays -> Detect displays
After you click "Detect Displays" your G3 should automatically send the display image to your projector.
SOURCE: Half of monitor screen shows on the projector.
You will need to set your computer to the correct display properties.
This you can do by either going to presentation mode.
Alternatively,
on Window XP you can simply go on to your desktop and right click > go to properties>go to setting> press display 2 and set the screen resolution as per your projectors resolution and enjoy.
( for information: display1 is the resolution meant for your computer).
Please do rate this solution and Thanks for usinf FixYa!
SOURCE: i need a cable to convert my projector to a mac computer
I got a catalog in the mail with lots of oddball computer stuff for PCs and Macs.Go to cyberguys.com,you should be able to find an adapter module or some kind of cable to do just about any media conversion.
