Can you explain the problem a little better? were you using the clerk interrupt system? How did you normally sign one clerk off and the next one on?
It is most important to initialise correctly and set up using clerk interrupt. I have never seen that MAC code before. It looks very strange. there seems to be a password embedded in it for some reason. Anyway, it sounds right to have SRVCTL (service total) printing so you are probably nearly there. I find it strange that you are not using 0 CLK# to sign off. Normally you can not sign off correctly without it. try that first
have tray that but I have to finis the transition before I can chance to the next clertk
Sins lest time I have reset the machine to times and now I can´t use the flat plu.
I cant get it, Isn´t it anywhere on the Internet a receipt over, for exemplar: store like ours
We just want to use all the flat plu, departments, and few plu. No taxes, no checks, no bills, no scanning, no printer, no nothing. I have been sitting her nearly hole summer every time after work until bedtime, tray to translate everything I could in Google translate. And that is not good, for example "compulsory" is translate as children school. If you now about somewhere I can find a page how can help me pleace let me now.
It sounds like you are using a manual that you do not understand then. These are dealer settings that you need to understand in order to program them. Most people would not attempt this level of programming. If you want to attempt it, it would pay to get the manual in your language so you can follow flag settings and MAC instructions. Guessing and copying other people's MAC codes is not ideal because there are country and model specific settings. I'm wondering if you are actually using the right manual. It should look like this:
http://the-checkout-tech.com/manuals/cas...
If you do not have the correct manual, you can't run through the Program 5 file structure and set all of the files correctly. Then you should have set the machine features tables in program 3. Once you have these set correctly, you perform key allocation and then program 2 text settings then program 1 pricing. There is nothing simple about setting up a complicated register such as this model - especially if you want extras such as clerk interrupt system. Without knowing your original settings from your dealer, I will only be guessing a lot of it.
this is the manual that I am trying to use but you can not get it in other languish her but English and that is not the English you learn in school. I can better understand Dansk and I am Icelandic so I am in deep sh......
I started with 5 pr. and did file
MENU SHEET NR. 1
38-500
28-100
29-10
32-20
33-3
36-400
41-3
47-168
62-10
78-57
79-78
80-193
81-11
82-38
83-92
09-99-99
10-31
18-20
20-3
15-100
60-300
07-20
30-50
11-200-200
93-2
99-99
01-97-97
02-400-400
05-99-99
04-4500-4500
then I did 3 pr.
01-22--2200000000
04-22--4000009941
05-22--4200003002
06-22--0422000200
07-22--0001017700
08-22--0777707743
09-22--7777777777
10-22--7771000000
15-22--0000000000
16-22--0020000077
17-22--0000000000
18-22--0099000000
21-22--1300300000
26-22--0000002000
28-22--1007250040
29-22--2016310000
and then 5 pr.
CLK#
CORR
NB
#/NS
PD
RCT
RCT ON/OFF
DEP01
DEP02
DEP03
DEP04
DEP05
DEP06
DEP07
DEP08
and pr. 3 I did
for department plu 000000000400
for cash 000004009999
for receipt 000004000003
and for the other programming I have tray back and forward
and it seems to work best to drop it.
then I named all plu and set price and receipt and the I did an X and
01072002 sub CA/TEND CA/TEND 1 CA/TEND 2 CA/TEND curence CA/TEND 1 CA/TEND
I have try so many time and so many different number to see what happens.some time the euro button has not works other times the departments and now the flat plu and I really don´t remember what I did the other time when it worked I have throw out to full big bag of tras
trash just full with receipt so shall I stop now and throw it out like everybody says and by a new one.
Did you link the clerk secret numbers to interrupt buffers?
no how do I do that?
It should be listed in the manager operation section. Have a look for linking clerk secret numbers to interrupt buffers. There is a clerk button method, but you are obviously using secret code logon so that will be the one you want
It says MGR-check no. for interrupt (max. 6 digits) - clerk no. (4 digits) - x/date time - sub.
What is check no.? and clerk no. 4 digits 0001 ore 0107 ???
what is secret code, and what is secret number?
It stand nothing about secret code in the manager operation section.
It depends how you have set your clerk secret codes. If you haven't changed the secret code, then it is the same as the clerk number. For the check number, you just select a check number that you want to save a clerk's current sales into. I would save into the same check number as the clerk number just to keep it simple
so something like that 0000010001 for clerk no.1?
If you havent changed it, the default for clerk 1 is just 1. Clerk 2 is 2 etc
you mean 11 1 for check and 1 for clerk?
I'd use check 1 for clerk 1, check 2 for clerk 2. Just single digits if you haven't changed the clerk secret code from the default one.
now I have done that. and now I can use one clerk and as soon that I tray to use another clerk number the receipt comes out and it stands in the bottom SRVC TL ???' and I can not used cash bottom it just beebs....
It certainly sounds like it is working. You should be able to log clerks on and off and have the service total re-appear. If that isn't happening, then I am sorry but I can't think of anything else. I prefer to use tables instead of clerk overlap, so that is all the experience I have. Now I'm definitely going to stick with tables. they work well.
thanks for trying...
I have try, for so long time now and I did not really thing that I could do it. but I needed to give it a shot . you never know. Sorry for taking your time,I appreciate it :))) Regards her from Denmark. hafdÃs
I sign on with, 1 and then clerk key ore, 2 and clerk key , we thing that the was a loose connections with the battery but now we have fix that. but the clerk is the only on i can not fix
they did not have to sign of between chance clerks just set a new clerk number in and then they could be to ore 3 at the same time
NOW I have reset everything and set ind Initialization 40000040830 I saw it somewhere. And I have reinstall all programmer and everything is working except the clerk button, now if I sign ind as clerk no. 1 and print ind something and then try to sign ind clerk no. 2 the receipt prints out and it says SRVC TL. So I give up This problems with this cash register has been going on for a month now and I am giving up, and I have promised my boyfriend, that on Monday I will throw this register to the trash, if it does not work then. so thanks for at answer my post and good bye
