1996 Cadillac DeVille Logo
Posted on Aug 25, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1996 cadillac deville want start
No gas getting to the throttle. i detached fuel line from filter turned key forward and fuel pump pumps gas but when i put line back on filter and turn key forward gas still does not reach throttle
  • wally_sermon Aug 26, 2008
    i took the line off between the filter and the throttle at the filter
  • Anonymous May 11, 2010
    Did you take the line off between the pump and filter?If so replace the filter.
Anonymous
Level 2:
New Friend:
  • Expert 182 Answers
  • Posted on Aug 27, 2008
Anonymous
Expert
Level 2:
New Friend:
Answers
182
Questions
Helped
71124
Points
357
If you had a strong stream of gas shooting out then you may have an fuel injector problem. Possibly a clogged injector or bad injector.If the stream of gas was weak replace fuel filter first and test again.If problem persists check pump fuse then replace pump. sorry for miss reading your post.
Deville 2005 quit runnung like shut key off wont start but turns over like no gas getting to engine checked all fuses but all good
chk fuel pump, chk fuel filter, if it was ran with less then half a tank dirt can clog the filter, or burn out the pump, some were ur car is not get fule to the right places.
1982 Cadillac DeVille with Digital Fuel Injection, won't start. How do I know if the fuel pump is bad?
Yes, it should. If it is conventional (like other GM cars), the pump will turn on for a couple of seconds when key is turned to on. This will prime the system for starting. When key is turned to start (cranking), the pump is turned on again at the relay, and pump stays on as long as cranking the engine happens. Once engine is started, the oil pressure switch keeps the pump running.
The best way to check if pump is good is to use a fuel pressure gauge. If it does not have a test port called a Schrader valve on the fuel rail, the pressure gauge must be teed in somewhere convenient. But if you take off the line at the filter, some gas should come out with key on, and when cranking the engine gas should come out in a steady stream.
I have a 1996 deville. I have replaced the in tank fuel pump and can hear run for a minute but I cant get fuel to the rail I disconected the lines and nothing still.
Yes it could.
Sometimes you have to jumper the pump relay to get it to run long enough to get the air out of the system and the new pump primed.
3answers
My car ran out of gas I put gas in it and now it qont start
we just had to replace the fuel pump in our 96 deville, The mechanic said that running the car with a low level of fuel can cause strain that would cause it to break,
1helpful
1999 cadillac deville hard starting after its drove
TPS throttle position sensor needs cleaning or replacment. or if you run the tank low on fuel you might be needing to replace fuel pump and filter.
1helpful
New fuel pump will not pump!
first all i do all of the repairs on my cars and i have got a bad fuel pump once but i would like for you to checkout all of the wire and make sure they are right and after make sure the fuel pump relay is good and the fuse for the sending is good
4helpful
2answers
Fuel problem 1998 cadillac deville
actually it is a theft system problem. the car is acting as if it were stolen and was ran until it was out of gas. the system just needs to be cleared and the car will start right up.
4helpful
2answers
1999 Cadillac Deville- Won't start!
First, obviously, put gas back in the tank.
Check the fuel pump fuse, (20 amp yellow fuse in the lower left corner of the group). If that is not blown, turn the key on and pound hard on the bottom of the fuel tank. The fuel lubricates the fuel pump, once it runs dry, the pump can lock up. Once the pump is immersed in fuel again, a sharp jolt will unstick it and let it pump up to pressure again. If it locks up for too long, the pump will burn out and need replaced.
We found this out by accident, got mad and pounded on the bottom of the tank and the pump jumped to life.
Top Cadillac Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Cadillac Expert? Answer questions, earn points and help others
