Empty the debris filter at the bottom (take the bottom bit off and turn the dial thingy) There will be water coming out so put towels down.
Dear GRC1,
ngfam at you service!
TRY UNPLUGING IT AND THEN REBOOT IT .IF THIS WORKS THEN YOU ARE SAFE!
OTHERWISE
This sounds like it will only fixed by service
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
SOURCE: Whashing machine leaking
Hi my name is joyce
Yes you can fix this yourself but you really need to let a specialist do this so you know that it is done so it wont leak. it may costly at first but it will be worth it.
if you want to do it yourself go online and type in hiya.com and go to their website and type in your model # and get your ser# and then call your local dealer in your area that deals in washers of that sort and order part and go to work.. good luck..
thanks
let me know how it turns out and please remember to rate me
joyce
SOURCE: whirlpool washing machine won`t spin or pump out
1-check the drain hose maybe cloged 2-check the drain filter maybe filed with materials 3- check no spin mode maybe you selected thank you
SOURCE: i have a samsung P1453
hi i also have a samsung p1453 that will not spin when the digital counter gets to 9 mins remaining it jumps back to 10 mins and wont go through the spin cycle the pump is working fine and emptying as it should cann ot see anything blown on the pcb
any advise woulkd be appreciated
SOURCE: hi i have a samsung
The fault can be related to faulty drain pump or timer control board.As you mentioned in your question that pump is clear then this problem is related to timer control.
If the washing machine is filling properly and doing the wash cycle then not going to spin cycle check the door switch and door.The spin cycle will not start if door switch is weak or faulty.
If door switch is checked ok then its timer related problem.Remove the timer control out and check its connection to the main control board.Wiggle the connections a bit then reconnect and check.If still the same problem then its timer.
You can get required parts from sears part direct site.
Thanks. Keep updated for any more query. You can rate this
solution and show your appreciation
SOURCE: do I need 1 or
You will need to replace both. Replacing one will not help.
Kind Regards
* If you found this solution helpful, please rate 4 thumbs up and leave a small testimonial. :-)
Testimonial: "thanks, my fault for not realising there were 2!!"
my samsung washing machine wont drain
