Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
When I turn on my camera, it says 'Lens error. Please restart.' and then the lens makes a funny noise and turns off
I checked the lens for sand, and didn't see any (but I could have missed it). I opened it up (took off the silver/black cover), and then cleaned it, to remove the dust that had built up. Then I put it all back together, but still, it didn't work.
Any suggestions? :-)
Thanks tons!!!
  • jellybelly57 Sep 07, 2008
    no, its not turning on. well, it turns on to say lens error but then makes that noise and shuts off
  • Sri Raghu
    Sri Raghu May 11, 2010
    Wats the question?
    is the camera not turning ON?
  • 489 Answers
Hi
What you are seeing is a generic stuck lens error message and obviously you didn't cause it as you said it was already happening before you tried to clean the camera and get it working again.
Your lens needs to be cleaned, repaired or replaced by someone experienced with digital camera repair. There are online places that will do it for a decent price and there are others that overcharge by way too much.
I know, because I own one that charges a reasonable price to do the repair... only about $70 total! (Google 'darntoothysam')
Just let us know if we can help.
Also.... you can also buy a defective camera online and use the parts to fix one from the two yourself if you don't mind getting in there and messing around with the parts.
Good luck from Darntoothysam com
Thomas
Posted on Oct 13, 2008
  • 21 Answers
The lens is just stuck and its not letting u do anything.i tihnk this happened while you tried to clean up the mess.You can just take it to any camera doc and they can fix the lens and then the camera will work fine.....
Posted on Sep 14, 2008
Lens error.....restart camera. Tried over and over again. Nothing works. HELP!
Went to the beach yesterday, by the end of the night my camera gave me this error: "lens error, restart camera". The lens would no longer come out.
I figured sand got stuck within the lens, so I did the following:
1. Turn camera up-side-down (with lens facing down)
2. Gently tap the sides of the camera (to loosen particles in lens)
3. Turn camera on
4. The lens will eventually come out
5. Gently tap the sides of the lens
6. Turn camera off (continue tapping side of lens as it retracts)
I turned the camera on and off a couple of times to ensure I removed all sand particles from the camera.
Now the camera works...thank god....
thanks.
Apr 11, 2011 | Canon PowerShot SX10 IS Digital Camera
When i turn on my canon powershot s3 iS , it says lens error restart camera. i tried restarting it , but my when my lens are trying to come out it makes a jammed noise. CAN YOU PLEASE HELP ?!
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Feb 13, 2011 | Canon PowerShot S3 IS Digital Camera
When i turn the camera on it makes this funny noise and then says lens problem how do i fix it
Dec 29, 2010 | Nikon COOLPIX S230 Digital Camera
When i press the on button, it make a funny noise and says lens error, resart camera but i dont know how to restart it
It means turn it off and on again, but this probably won't help. You get this message with a lens error, problem with focussing/zooming or whatever. Usually means there is grit in the mechanism or it has been damaged by a knock.
Nov 22, 2010 | Canon IXUS 80 IS Digital Camera
My camera displayed a error message, the lens makes funny noises
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Nov 18, 2009 | Canon PowerShot A570 IS Digital Camera
My camera lens won't go back in and is making weird noises.
Since you said it makes noise when you turn it on, the gear system controlling the lens might be faulty. have it checked.
Sep 16, 2009 | Panasonic Lumix DMC-FS3 Digital Camera
I have a Cannon Powershot SD600, just got it recently and it worked great, then all of a sudden I noticed the cover lens's that slide over to protect the lens when you shut it off were messed up. Onle 1...
The Canon series are fine camera's, but they seem to suffer from lens errors (check how many people suffered from this by googling lens error canon).
The problem seems to come from sand/dust entering the body and jamming the lens gear. A handy person may be able to fix it, but I think Canon should have designed an enclosed lens gear so sand/dust can not enter.
Camera's are commonly carried in pockets, so it is logical sand and dust can be expected.
There are some issues with getting perfect focus in some situations.
Jan 03, 2009 | Canon PowerShot SD600 Digital Camera
Camera turns on BUT then get "lens error restart camera" msg
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Aug 09, 2008 | Canon PowerShot S3 IS Digital Camera
How do you fix 'lens error restart camera' I put it in my bookbag. I guess i threw my bookbag around and now i have this "lens error, restart camera." The lens froze halfway and it's staying that way....
It sounds like. You really need to have some one take it apart and clean the sand out of it. The camera will make those noises when the sand gets between the gears of the lens assembly and they cant connect correctly.
ou could try helping the lens go back in GENTLY. But thats risky and you could ruin a lens that would work just fine if it where cleaned out.
let me know which model and brand you have and I could tell you better whether or not you should try anything your self.
goodluck,
Caleb
Jun 30, 2008 | Cameras
Lens error Help please
The Lens Error usually means the lens has sand or another obstruction stopping it from retracting.
Nov 07, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
56 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
