Question about Apple iPod MP3 Player
Ipod 20g 4g
I am having a problem with my ipod
it says on the screen plug it it to a main power
i re- store it an the this problem came up
ca u help me
  • 1,879 Answers
Greetings,
For instructions too long to post in here - click on this link
ipod 20g 4g - fxnlogo_s.png Technical Support, Instructions & Repair Service
Posted on Aug 28, 2008
Just recoverd ipod touch got cracked screen worked before now wont slide to open or cancel power off
If the screen is cracked then that is why it will not recognize your touch. It will work normally but when the phone has had enough it will stop working. Hoping you have insurance, you need to replace it or see if they can restore it in any way at the apple store.
Jan 26, 2014 | Apple Ipod Touch 4g
How do you restore a ipod touch 4g
The fourth generation iPod is identified as the iPod with the click wheel and color display, and also known as the iPod Photo. All models of the iPod 4G include the click wheel and full color display, making it easy to view album artwork and photos. Subsequent versions of the iPod also have video capabilities. If you are having trouble with your iPod 4G, there is a series of steps you can follow to try to fix the problem. Start by resetting the iPod (see Below). http://www.apple.com/support/ipod/five_rs/photo/ If this doesn't do the trick, you may need to restore the iPod, which replaces potentially corrupt software components. Doing so will erase all the iPod's files, so you should make sure you have your files backed up in the iTunes Library.
Download and install the latest version of iTunes. Open the program. Connect your iPod to your computer using a USB cord. Select your iPod from the device list in iTunes once it appears. Click "Restore" on the "Summary" tab of the main screen. iTunes will prompt you to select from one or more restore options. Choose how you want to restore the iPod. The first part of the restore will begin. You'll see a progress bar on the screen. Leave the iPod connected to finish the restore, as iTunes prompts you to do. The iPod will now show an Apple logo and progress bar on its screen. Follow the prompts of the iTunes Setup Assistant when it appears onscreen. Enter a name for the iPod. Choose your syncing preferences. Reload your iPod files from the iTunes Library.
Apr 07, 2013 | Apple iPod touch 4th Generation MP3 Player
Why is my ipod 4g screen blank
is it an ipod nano ?
Remove the two screws on the panel on top of the Nano and remove the top panel.
Use a case opener tool to pop the plastic screen cover off the unit.
Slide the screen up to expose the orange ribbon cable on the bottom of the screen that connects to the motherboard.
Unplug the orange ribbon cable from its port and slide the screen out of the Nano.
Fit a new screen in the Nano and plug the ribbon cable into the port.
Replace the screen cover and top panel of the Nano.
hope this helps
http://www.bing.com/videos/search?q=how+to+replace+an+ipod+4g+screen&qpvt=how+to+replace+an+ipod+4g+screen&FORM=VDRE
Sep 29, 2012 | Audio Players & Recorders
A few hours ago, my ipod touch 4g had about half of the screen white. Is there any way i could fix it without paying?
Welcome to Fixya
Looks like the software just hanged-up on you. Try to reset the Ipod by following the procedures below.
1st option:
Turn the Hold switch on, then back to off.
Press and hold the Menu and Select buttons for 10 seconds (until the Apple logo appears).
You may need to repeat the reset several times.
If the reset doesn't help, then put the iPod into forced disk mode.
2nd option (Disk Mode):
Plug the iPod into a high-powered USB port, let it sit for 2 hours, then disconnect it. If you have a wall charger, plug in the iPod, then follow these steps while it is still plugged in.
Press and hold the Menu and Select buttons until the Apple logo appears
Immediately switch your figures to press and hold the Select and the Play/Pause buttons until "Disk Mode" appears at the top.
For a lot of people, this solves the problem. Connect the iPod to the computer and (assuming it shows up) reset the iPod again to get it out of Disk Mode. If at this point you still have the white screen, restore the iPod using the restore function in iTunes under the Summary tab (this will erase everything on the iPod and put it at factory settings).
Note: Do not disconnect or eject the iPod until the store is totally done. After you think it's done, wait another five minutes.
Thank you for using Fixya!
Dec 31, 2010 | Apple iPod nano
When I plug in my Ipod to the inMotion im310 portable speaker the Ipod screen says it is not supported, and it worked this morning.
Check the pins on the speaker and on the plugin on the iPod, that's the problem usually. Also, check if the iPod is truly compatible, even if it worked before it may not be. I have seen car chargers for say a 2G iPhone work for a bit then say incompatible, it happens. Here are the compatible iPods for the iM310:
Plays and charges
iPod mini;
iPod nano 1G, 2G, 3G, 4G;
iPod classic 3G, 4G, 5G, 5.5G, 6G;
iPod touch 1G, 2G
EJ
Apr 10, 2010 | Altec Lansing inMotion iM310 Portable...
Apple iPod MP3 Player Logo
35 people viewed this question
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
