Question about JVC AM FM CD DET FACE CAR STEREO
Jvc car cd/radio
Every time I try and pretune/ preset radio stations they never stay set, every time I switch off the ignition I lose the preset station i.e how can I mget the stations to stay set.
  • JVC Master
  • 5,568 Answers
The radio was improperly installed; there are two 12V leads, one services the radio when on, the other, only the circuitry for the clock and presets.
Eventually, this shouldn't be needed if the manufacturers ever think about using a little bit of flash memory for the presets and a coin cell for the clock.
You didn't give any model number so researching the manual is impossible.
If you can find the model number, look for a user's (or installation) guide on line to find the wiring info.
Posted on Aug 25, 2008
Jbl radio A56840 loses station presets and no volume
Toyota vehicles have a fuse in the kick for the amp and sometimes there is located under the hood ... This is the switch turn on for the amp ... And 1 of the fuses is most likely the memory or constant power. B sure to check all fuses ... I do not have AllData pulled up . If the fuses are all good the amp or radio may be bad ... Or both ... Be sure to check all the fuses ... Many times I get clients that say allthe fuses are good and it is still the first thing I check ..Usually is a fuse ..Good Luck
Jan 27, 2014 | JBL Car Audio & Video
When i preset my radio stations 1-6 while the power is still to the system memory of stations will stay but when the car stereo power is turn off for any amount of time and sterio is turn back on all...
Make sure the yellow wire is connected to a source that still has voltage when the key is turned off. The yellow wire controls the memory of the deck.
Jul 24, 2011 | Alpine CDA-9851 CD Player
I set radio stations and when I shut the car off, I lose my presets.
The yellow wire in the wiring harness of your head unit must be connected to a constant power source, a live terminal in the fuse block that is connected to the battery and not affected by the ignition switch. If you do not have your manual this may help: http://resources.jvc.com/Resources/00/00/95/GET0182-002A.pdf
Mar 22, 2011 | JVC KD-G200 CD Player
Does not stay set.
your deck has two power sources a main for when your car is turned on so the radio kicks on and a remote which is always on keeping stations and clock powered passively so whoever installed it did it improperly or do to road wear and tear it was jossled lose and can simply tightened after pulling the deck out
Mar 29, 2010 | Sony MEX-BT2500 CD Player
JVC stereo not working properly - 2001 Sonata
generally wiring from the car is as follows...
red = ignition controlled live
yellow = permanent live
if you want stations saved and manual switch off of uni connect radio's yelow and red wires to the cars yellow.
if you want stations saved and radiounit switch off controlled by ignition (i.e only when car is running) then yellow to yellow and red to red. anything else will cause issues...
Feb 21, 2010 | JVC KD-R200 Car CD/ MP3 Player
Stations on radio will not set
A car radio needs two sources of power. A little bit of 12 volt all the time and more power when you want to hear the music. Also known as battery(all the time) and ignition (when the "power" is on). It might be a bad connection on battery power or it wasn't connected right. Battery power is needed to keep the presets and the clock setting.
May 17, 2009 | Alpine CDA-9887 CD Player
How do I preset individual radio station frequencies?
To set individual presets: 1. tune to the station you want as a preset 2. hold down the number (ie "1") on the remote until the number blinks on the system 3. repeat for all other stations
press the number on the remote to tune to your preset
this is very similar to setting the presets on my car radio
May 04, 2009 | JVC FS-D88 Shelf System
Switching the ignition off loses the preset stations
the red wire and yellow wires are crossed simple fix once radio is off
Sep 28, 2008 | Nakamichi CD-35z CD Changer
Jvc rv-dp100 boom box
tune into the station you want as normal. Then on the remote, press & hold the number key for the preset number you want. This will flash in the display to show you it's set. You can preset 30 FM & 15 AM stations.
Sep 17, 2008 | JVC RV-DP100 Cassette/CD Boombox
EXAD KD - AR5000 Programming
Do you also lose your clock and radio station presets?
Nov 08, 2007 | JVC Arsenal KD-AR5000 CD Player
JVC AM FM CD DET FACE CAR STEREO Logo
532 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
