Question about Maytag Heating & Cooling
Maytag Portable Airconditioner. Model MEP09D2A Rev B; Serial # AT 780436 029W- service required
4 Suggested Answers
  • 82 Answers
SOURCE: hose connection, need parts list, or picture showing connec.
Hello, the unit is made and marketed under Fedders and Maytag....the only difference is the first letter of the model number. Here is a link to a manual for your unit. It is downloaded at a storage site I use. The only bad thing is a few annoying pop ups, but be patient and you can print off the whole manual. Here is link http://www.mediafire.com/?jd0rmmj3dnu
Posted on May 14, 2010
chillmaster
  • 104 Answers
SOURCE: I need to download a
Maytag has manuals available online for all of their products at www.maytag.com I checked though, and Maytag does not recognize the model # of your unit as a valid #. Might want to double check #'s on unit.
Posted on Jun 28, 2008
  • 89 Answers
SOURCE: CAN U ADD R22 TO PORTABLE AIRCONDITIONER
On the nameplate there should be a refrig. type.
Posted on Oct 08, 2009
  • 251 Answers
SOURCE: i have a maytag portable air conditioner model
A few basic principles for air conditioner troubleshooting. For both central home air conditioner or window air conditioner, the first thing to check is whether the unit is getting proper power. If the unit uses 220 volt power be sure that the proper voltage is getting to the unit. Same for 110 volt units. A voltage meter can be used to assure that the voltage is correct.
For window air conditioning units the voltage can also be checked before and after the thermostat. If voltage is being supplied to the thermostat but not from it then the thermostat probably needs replaced. This is a fairly common problem. Another place to check is the fan motor voltage. The fan on window air conditioners runs both the indoor blower and the condenser fan. If that motor fails than the compressor may run for a short time, but will overheat and shut off. Continued operation like this will result in compressor failure. This motor can be economically replaced for larger window air conditioners, but for smaller ones the cost of replacement will be more than a new unit.
Central air conditioners for the home are more complex and there are more things that can go wrong. As with the window air conditioner the thermostat can also be a problem. The central air conditioner thermostat will only have 24 volts going to it. So don't look for high voltage there. Some units the voltage will be coming from the outdoor unit and others the voltage will be supplied by the indoor air handler or furnace. Most home central air conditioning will be supplied by the indoor air handler or the furnace. If the air conditioner is for cooling only the unit will usually have only two wires going to the condenser unit. Make sure that you have 24 volts across those wires.
The next thing to check will be the indoor blower. If your thermostat is calling for cooling then the indoor blower should be running. If there is no air moving across the indoor cooling coil then you will soon have a big block of ice formed on the coil. This can happen for a few reasons. The indoor blower is not working, the air flow is restricted and not allowing air to move across the coil. A clogged air filter would also do this. Or the outdoor condenser unit has lost the charge of refrigerant.
Finally and worst of all is when you have a complete compressor failure. Often when this happens the compressor will "lock up" or not be able to turn when power is supplied to it. Overheating or lack of lubrication are usually the main causes of compressor failure. Overheating can be caused by the outdoor coil around the compressor getting clogged with dirt, leaves, or grass. Loss of the refrigerant charge will also cause the compressor to overheat. It is the cool return gas coming back to the compressor that helps to keep it from overheating.
As you can see there are many things that can go wrong with an air conditioner and I have not come close to exhausting the possibilities here. I have just touched on the most common problems in a very basic way.
There are some basic trouble shooting things that can be done very easily. Most problems are above out of the range of comfort for many homeowners and professional help should be consulted before any attempt is made at repairs. Remember also, that the release of refrigerant gases into the atmosphere is a federal offense in the
US. Proper care must always be taken to minimize the release of any gases. A license is also required to handle refrigerants. Make sure that the professional you call has the proper certifications to handle refrigerants properly.
http://www.fixya.com/support/r3636709-size_air_conditioner_need
http://www.fixya.com/support/r3623253-window_air_conditioners_clean_every_year
http://www.fixya.com/support/r3633369-portable_air_conditioning_great_portable
http://www.fixya.com/support/r3623166-heating_air_conditioning_scams
http://www.fixya.com/support/r3597468-you_can_add_air_conditioning_to_your_hot
http://www.fixya.com/support/r3583697-how_to_keep_house_cool_without_using_air
Posted on Jun 07, 2011
Manual wanted for Airtech Elite Portable Airconditioner model no HF-668RC
Try Googling (Airtech)(HF-668RC)(manual) without parens.
Sep 13, 2016 | Heating & Cooling
How do i find out wether my airconditioner is 110 or 220
All electrical requirements are listed on the Nameplate Data under the Model Nr. and the Serial Nr.
Aug 25, 2014 | Gibson Heating & Cooling
Hose connection, need parts list, or picture showing connec.
May 14, 2010 | Heating & Cooling
Need a new blower wheel where can i get one from i live in kent england
contact maytag service center or online. Make sure that you have model and serial numbers handy. They will be able to ship you a new wheel or be able to tell you where in kent you should be able to get one. It is possible that if you go online to www.firstsourceparts.com you may be able to purchase online with credit card.
Jul 15, 2009 | Maytag Electronic Portable Air Conditioner...
Airconditioner normal only when accelerating
Get the A/C Gas checked it may be low and require servicing
Jan 22, 2009 | 2000 Mercedes-Benz S-Class
DeLonghi portable airconditioner leaking water
nbenz ,
Welcome to fixya.
I'm Huuum and happy to assist you,
Portable units are supposed to spray the water on to the hot compressor an evaporate the water!
If it is only 3 weeks old ,you have a 1 year warranty. call service and let them fix it for !
Please remember to leave a rating before you go!
Thank you
Aug 26, 2008 | DeLonghi Pinguino PACL90 Portable Air...
I need to download a manual for a maytag portable airconditioner model #MEPO9D2A
Jun 28, 2008 | Maytag Heating & Cooling
Heating & Cooling Logo
1,426 people viewed this question
Top Maytag Heating & Cooling Experts
Rick Johnson
Rick Johnson
Donni Steen
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
