Question about Linksys (NH1005) 5x10/100 Mbps Networking Hub
Problem with printers
We use this hub to connect multiple computers to the same printer, Recently we could not to get anything to print. Is there a way to get new drivers for the hub? or is it plug and play with messed up wires?
  • 89 Answers
The switch that you have does not require drivers or settings you can change in it. it is just a pass-through device. you can check the cables if they are working or the ports of the switch (if it lights up). moreover, check also the computers if their ip address are configured correctly and within the same range and make sure that the printer is still shared through the network.
you can check this website for reference:
http://compnetworking.about.com/od/windowsnetworking/tp/winfilesharing.htm
Posted on Aug 25, 2008
My Zebra 105Se printer keeps printing blank labels
There are several reasons why this could be happening. If the computer accessing the printer changed then I assume the new computer was recently set up with software to send print information to the printer. I would start with simple calibration and move from there. Zebra Technologies 105SL Printer Calibrating the Printer With Video
Jun 04, 2014 | Zebra 105Se Thermal Printer
Wanna connect mulitple computers to my Printer
Yes, you can definitely share one printer to multiple computers. All you need to have is a ethernet hub or some call it network hub and Cat5 cable. Ethernet Hub is a simple, small and inexpensive gadget to connect multiple computers together.For the Cat5 cable is popularly known as LAN cable. For you to share your printer, connect it on a ethernet hub as well as your computers using a Cat5 cable. Once everything is connected to the Ethernet hub fix the network and that's it. Everyone that is on the network can use the printer.
I hope I answered your question.
Thanks a lot!
Jul 25, 2011 | Ricoh Aficio GX3050N All-In-One Printer
I connected my HP Color Laserjet 2550L printer through the Lacie Core7 and it does not print. Printer window says "out of paper" but printer does have paper. Works OK if connected directly to...
USB Hubs are generally a bad idea for big USB devices
for big devices like printers and scanners it is generally rule of thumb to connect them directly to the USB port as USB Hubs share the voltage over many ports and data can be lost if multiple peripherals are using the one port
Mar 21, 2011 | LaCie 130894KUA Core7 USB 20 Hub
Hp 4650dn printer showing offline. Connected through airlink router. Working fine one day, offline the next. Power cycled and checked all connections, still no luck.
Hello !
You have to self diagnose the printer by your self. Please try this solutions.
1. Usually it is getting offline when the main computer that connects directly to the printer is off and you are only sharing from this computer through a router or a switch hub. Sure it will mention that the printer is offline and cannot print anything. You need that workstation to be open to be able to connect to the printer.
2. If not, check the cable connection connecting from your computer to the switch hub or router. Maybe it is just loosen for some reasons. Remove the cable to the router and plug it again. Turn off your printer and your computer and turn it on again. Try to print test page.
3. If not, try to unplug the printer cable connecting from the computer to the printer and maybe just loose up. Turn off your computer and printer, after turn it on again. Try to print test page.
4. If still not working, it not something to do with the hardware problem. I believe is it software problem, maybe you upgrade software or install software that harms your printer. Uninstall some programs from the computer that corrupted the driver files. If you upgrade the main computer, I suggest to uninstall and reinstall the printer software.
5. If not, try to replace the port (whether usb port) and maybe this is the problem. Try to turn off the unit and turn it on again.
6. If not, replace the cable connection from to the switch hub, close all the PC unit and print and try to print again.
Here is the only diagnostics solution I can give to you. Good Luck and Thank you for using Fixya.
Jan 06, 2011 | HP LaserJet 4650dn Printer
Printer to computer connection failure
I assume you're using a USB connection. What you fail to mention is whether you're connecting the printer directly to the PC or through a USB hub. If the latter is the case, because we now have so many USB devices, it is necessary that this hub be powered by its own power supply.
It's very common for these hubs not to work unplugged when devices draw a lot of current which they cannot generate from a simple connection to your PC.
Other than this possibility, I'm also stumped.
Try looking in your user's manual for a built in printer TEST function, usually pressing down some button while you turn power on to the printer. If there's anything wrong with the printer, these diagnostics will tell you what it is.
If all is well, try connecting the printer to a different USB port on your PC. Try testing each USB port with a different device, like a USB pen, to determine that it is not the port.
Aug 26, 2009 | Epson Stylus NX400 InkJet Printer
Need my laptop to communicate wireless to printer
If the printer does not have a built-in network card/print server then there is a couple of ways to do this.
If you have a desktop computer connected to the wireless router with a LAN cable, then connect the printer to the desktop computer and make this printer a shared printer on your network. This means that the desktop computer and printer needs to be on when you want to print from the laptop.
The other way is to purchase a print server, connect the printer to the print server and connect the print server with a LAN cable to the Wireless router.
If you don't have sufficient network ports on the wireless router then you need to purchase a hub. Then connect the hub and wireless router with a LAN cable and then the print server to the hub and other computers to the hub.
Setting up the wireless printing will depend upon which method you want to adopt and I can advise you when further when you are ready.
Aug 02, 2009 | HP Photosmart 3310 Printer
HP 7210 all-in-one is having trouble printing. At best, will print just the first inch or so of the document---at worst, prints only a few symbols at the top, or prints a meaningless barcode-like pattern,...
It was a connectivity problem between the computer and printer. I had recently switched from a direct USB connection to a non-powered USB hub. Apparently, routing through the hub resulted in an inadequate, inconsistent connection between the computer and printer, so print jobs were garbled or only parts of the page were getting printed. Switching the USB cable back to a direct connection between the printer and computer completely resolved the problem.
Dec 02, 2008 | HP Officejet 7210 All-In-One InkJet...
Will not print from my computer
do you receive an error message on display of the printer? If yes, post it here (or use the search function of this forum).
You have to connect the printer directly to the pc. do not use a hub ,or a cable longer than 3m.
Apr 04, 2008 | Brother MFC 210C All-In-One InkJet Printer
Linksys (NH1005) 5x10/100 Mbps Networking Hub Logo
64 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
