Question about Fujitsu Computers & Internet
Wont boot up
Laptop wont boot up tryed re running windows disc but still wont boot up ,just keeps saying error loading opearting system
    Genius:
  • 2,028 Answers
This could be that the disc is corrupt. Check it for obvious signs, scratches, miscolloration, etc..., or try a different disc if you have one available.
Posted on Aug 25, 2008
Can't do a system restore
Please contact acer and ask for operating system disk.
Jul 07, 2013 | Acer Aspire Computers & Internet
Satelitte toshiba u405-s2824 loaded new bios now wont load windows keeps restarting
Terrible sequence. You should load windows on the old bios the flash the new bios.
Did the windows installation complete? What keeps restarting the windows installation or the boot process?
If the boot process keeps restarting try running the check disk utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
May 02, 2012 | Toshiba Computers & Internet
Imedia system32 error
okay this is a confusing post/question. you can always start a machine from bio regardless of what operating system you're running. if you're attempting to boot from the disc, tap f12 @ boot until you get a one time boot menu and choose the dvd/cd drive. that should load the setup file. the windows disc does not load setup onto the hard drive. if you're running xp when you have the option hit 'r' to repair the computer, when you get into command prompt type sfc /scannow. this will search and fix all system files. you can also try chkdsk c: /r this will fix any errors in the file structure. good luck
Jan 30, 2012 | Packard Bell iMedia Computers & Internet
MY LAPTOP CRASHED WHEN PERFORMING A START UP REPAIR NOW I CANT FIX IT, IT KEEPS BLUE SCREENING AND COMES UP WITH LOTS ERRORS .. ALSO WHEN IT TRYS TO SYSTEM RESTORE IT WONT DO IT IT HAS AN ERROR THE...
get a bootable dvd of the same version of windows and start booting from it. instead of installing start repair option. it may help you.
good luck
Sep 03, 2011 | Computers & Internet
My ibm t 22 or 23 not sure i can look but nyway it wont boot says windows 32 system file missing or corrupt i dont know how to get it to ny thing except a menu that says try last working config and a few...
You have a corrupt boot sector. Use your system/restore disc to get back in and boot then run CHKDSK/F to check for and try and fix any errors.
Hope that helps.
Jan 23, 2011 | IBM Tablets & eReaders
I updated vista with SP1. It couldn't update after downloading it so it tried to revert changes. After rebooting, puter won't boot. Loads dell bios screen then switches off to reboot again. It just keeps...
Oh dear, what a problem.
Unfortunately I don't think you can do more that contact Dell and ask them for a "Rescue System Disk"
There may be a charge for this disk but at least it will get your laptop going again.
A memo to Microsoft may make you feel better as well.
Dec 22, 2010 | Dell Inspiron 1525 Notebook
My laptop keeps saying ntdlr is missing and wont start up what should i do
Check to see if you have inserted any DVD/CDs in the CD/DVD drive or any USB/External storage medium connected to the PC when it is booting. If yes, then try removing them and reboot
If no, then try using the Boot File Repair option on Win7/Win Vista installation DVD.
Aug 28, 2010 | Computers & Internet
My dell inspiron 1525 has a black screen with a white cursor showing
First, I want to know if you sees the Dell logo after turning on the laptop? If yes then this is no boot issue.
1. Immediately run the PSA. Make sure laptop is off. Press and hold down the Fn key, while holding down Fn key press the power button at the same time just once. Once the Dell screen loaded you can now let go of the Fn key. Check if the PSA will run short test for the LCD, RAM and HDD. When full color displays on the screen just press Y. PSA will continue. Just take note of any error code will appear on the screen such as 0141, 0142 and 0146 these are HDD failure errors which means HDD needs replacement. If the test says no errors found then proceed to step 2;
2. Try restarting the laptop once you see dell logo then keep tapping F8. Select last known good configuration. Press enter key. Just wait and check if laptop will load Windows. If not then, restart laptop keep tapping F8 try to select safe mode check if it will load Windows. If not then prepare the Windows OS disc the one came with your laptop.
3. While laptop is on insert the Windows OS disc. Restart the computer. On the Dell screen keep tapping on F12 to show boot menu. In the boot menu select CD/DVD ROM Drive. Press enter then keep tapping on space bar until it will say Windows loading files, please wait.
4. In the User Interface it will show you some options to select. Once the Install screen comes up look on the lower part select Repair Your Computer. If will ask you to do Startup Repair, please do start up repair. If fails try the System Restore. If fails then step 5;
5. If you have important files in your HDD then back up your files first. After backing up of files you can now install the Windows OS. Here is the process in installing the Windows OS. Insert the Windows OS disc, restart the laptop, keep tapping F12 on Dell screen, on boot menu select CD/DVD ROM Drive.Install the Windows OS. Just complete the installation.After the installation install the laptop drivers.
Dec 10, 2009 | Dell Inspiron 1525 Notebook
Cant logon my acer 1640 it wont even get to the windows page
This is the menus that you get when you boot from the CD:
http://www.bleepingcomputer.com/tutorials/tutorial148.html
When you run the Startup Repair from your Vista CD you get that error "No OS files found on disk."correct?
Instead of choosing the Startup Repair option try the System Restore option and see if i allows you to take the computer back to another day ,if it gives you an error then choose the other option that says Command Prompt ,it will load to a blinking white cursor.
Type in the following and press Enter key after each one:
bootrec.exe /fixboot
bootrec.exe /fixmbr
When finished Restart the computer and see if it will load normally.
If it doesnt resolve it then it could be a hardware problem on the laptop itself.
Apr 09, 2009 | Acer Aspire 1640Z Notebook
Windows start up repair keeps comming up every time i start it up
Try getting teh Windows Disk & run the windows repair utility.. this will fix any errors with the opearting system.
Note : Windows repair will not delete files however you might require to reload your drivers ...
Mar 23, 2009 | Dell Inspiron® 1501 (N11157) PC Notebook
Computers & Internet Logo
396 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
