Question about Maytag Washing Machines
Pump on washer making clinking noise as if a coin is stuck in it. Do I need to replace pump?
    Problem Solver:
  • 4 Answers
Remove the pump cover and take out the metal in the filter
Posted on Aug 25, 2008
Does the pump make a funny sound when you have a clogged filter?
sometimes coins get stuck in the pump which causes noise when draining. Front of machine has to come off and pump taken apart and cleaned out.
Mar 02, 2015 | Frigidaire Affinity ATF7000E Front Load...
How to fix the pump in maytag neptune washer
Remove the back panel there are four screws in panel. the pump is acessable on left side facing back. The pump is bad or you have something stuck in the pump.eg.bobby pin, bra support wire, and have found coins in them also. Have towels handy to absorb the water.
Feb 14, 2013 | Maytag Neptune MAH5500B Front Load Washer
Barrel is half full of water and machine just makes a buzzing noise when powered up.
The washer sees the water in the tub and is trying to drain. The drain pump is either bad or there is something stuck in the pump. The pump is located on the back right side looking at the washer from the front. Unplug washer and empty water from tub. Take the back panel off, remove drain pump which more water will come out so have a wet vac ready. Check inside the pump for coins, lint, etc..., If you find something stopping the pump clean and reassemble and run the washer. The pump will have to be replaced if it does not now work. If there is nothing in the pump, replace the pump. Part number w10217134 retails for $95.20.
Thank you
Please rate this post
Jan 22, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Coins making noise in pump area
If you are hearing coin noise in pump area, you need to take hose off pump assembly, and look inside pump, if left inside could block hole of pump and won't let washer pump water out.
Jan 12, 2010 | Whirlpool Washing Machines
Coin is stuck
Does it become quiet for awhile after the coin is removed? I can't imagine how a coin lying in the bottom is making any kind of noise. There is no way for a coin to be trapped on the outside of the drum. It might, if it got past the lint filter and worked it's way into the blower housing, make an occasional 'clink'. Does the lint filter have any sizable holes in it? Do what these techs have done and see what you find.
Aug 26, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Loud noise when draining
You need to tilt this machine back and remove the drain pump from under the machine and check for anything stuck in there eg a hair clip or coin etc. If there's nothing stuck in there you may need to repalce the drain pump. Cheers
May 11, 2009 | Fisher and Paykel GWL11 Top Load Washer
Kenmore 98702 Stacked Washer/Dryer. Dryer making clicking noise
There may be coins stuck inside the tumbling vanes in the drum.
Mar 08, 2009 | Kenmore 98702 Stacked Washer/Dryer
Grinding Noise when Washer Attempts to Spin
It is probably the same problem because it is trying to drain during the spin cycle. My machine sounded as though a chain wis clanking, the solution was removing a coin caught in the drain pump. Access the pump from the bottom of the machine. 4 screws hold the mounting bracket on undo those, the electrical connection and two hose to the pump. Undo three screws holding impeller to motor and coin can fall out. Examine for damage if it is not too tore up, put back together. Keep in mind that when you unclamp the hoses that water will come out.
Feb 02, 2009 | Maytag MAH2400A Front Load Washer
Noise when spinning fast
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth
Dec 15, 2008 | Hotpoint WMA44 Front Load Washer
Clinking noise
after the load is done look in the unit it and hand spin the drum slowly It sounds like you have a coin or something stuck in the baffles rotate untill you can pin point it..
Jan 27, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
41 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
