Question about Sony Playstation 3 (PS3) Console
6oGB PS3 Console does not recognise when any media is added. Whether it be DVD, BD or games.
  • viejo74 Aug 26, 2008
    My ps3 60gb recognizes ps2 games, but not ps3 games. Please help.
On mine iff u add a mem card it says no files in folder just come out of the foulder bt select the mem card with triangel and press show all hen all immages ect should load
ps this is for a 80gb so possiby can work
Posted on Aug 26, 2008
Hi, my ps3 games are not being recognised in the game section but my dvd's are. what can i do to make it recognise my ps3 games??
u try ugrading your ps3 and try to make it read your dvd since it might be a upgraded verstion of game..in som cases the original dvd wil only be recognised in that u make sure whether its original or not..still u truck with it check this to solve
Dec 02, 2010 | Video Game Consoles & Games
Cut scenes jump
There may be a number of issues that contribute to your game not loading, or freezing up when trying to play. Please try the following:
1. Confirm the disc is clean. To clean a disc, use lint-free cleaning cloths made specifically for cleaning CD/DVD discs, sold at computer software stores. When cleaning the disc, we recommend starting from the innermost circle, and wiping out to the edge in a straight line.
We do not recommend wiping in a circular motion, as it may create more scratches on the disc.
**Note: Other materials, such as a paper towel or a T-shirt, may also scratch the disc. If there are any scratches, smudges, or fingerprints on the disc, it may not function properly. Also, do not use or insert any CD/DVD drive cleaners into the Playstation 3 as doing so may cause damage to the system.
2. Confirm that you have updated the Playstation 3 computer entertainment system with the most recent system software . You can check the version you have installed on your Playstation 3 by selecting:
* Settings.
* Then System Settings.
* Then System Information.
3. Some Playstation or Playstation 2 format software titles may perform differently on the PS3 system. To identify the compatibility status1 of a specific title, please use the Backward Compatibility Status Search provided by Sony.
http://www.us.playstation.com/Support/CompatibleStatus
4. Try playing different CDs, DVDs, and games on the Playstation 3 console to see if the problem exists across multiple discs. Also try playing the disc on a different Playstation 3 console.
5. Confirm that you are not using any game modification devices. Unlicensed devices such as game modification devices can interfere with the proper function of the software. We do not recommend the use of any game modification devices or unlicensed products.
Turn off the BD 1080p 24Hz Output(HDMI) option. If the Blu-ray DiscTM does not support 1080p 24Hz video mode, the video output may not display properly. Go to [BD 1080p 24Hz Output(HDMI)] under [Settings] > [BD/DVD Settings] and select "Off".
6. Confirm that the disc you want to play is supported by the PS3 system.
The PS3 system will support the following media formats*:
Media Formats Supported on the Playstation 3 console
PLAYSTATION®3 format software with either region [1] or [ALL] a
Playstation 2 format software (NTSC U/C standard) - (Not supported on the 40GB model)
Playstation format software (NTSC U/C standard)
Audio CDs, CD-R/-RW, Super Audio CDs b, c
DVD Video with either region [1] or [ALL] a
DVD-R/-RW, DVD+R/+RW a, c
Blu-ray DiscTM (BD) containing video content with region code [A] e
BD-ROM, BD-R, BD-RE c, d, e
a - When outputting DVD content or Playstation 3 format software in SD resolution, only discs recorded in the NTSC standard can be played.
b - Multi-channel Super Audio CD playback requires a multi-channel audio receiver with HDMI input.
c - Playback only.
d - Playback of BD-RE ver 1.0 discs is not supported.
e - Copyright-protected Blu-ray video discs can only be output at 1080p using an HDMI cable connected to a device that is compatible with the HDCP (High-bandwidth Digital Content Protection) standard.
* The 40GB Playstation 3 model does not support SACD.
Apr 03, 2010 | Sony Playstation 3 (PS3) Console
How to fix lag on plasma to play ps2 guitar hero
Try to configure the following settings.
Go Video Setting, BD/DVD Cinema Conversion (Automatic), then BD/DVD Upscaler (Normal), then BD/DVD Video Output Format (RGB if you are using your PC Monitor, Y PbCb PrCr if you are on HD TV), then BD 1080p 24Hz Output (Automatic), then BD/DVD Dynamic Range Control (Off), then BD/DVD Audio Output Format (Linear PCM), then BD/DVD Audio Output Format [Optical Digital] (Bitstream). Go out of Video Setting and go to Display Setting. RGB Full Range (Limited), Y PbCb PrCr Super-white (On).
Hope this will help you.
Jan 17, 2010 | Sony Playstation 3 (PS3) Console
Movies fade in and out
Configure the following settings.
Jan 16, 2010 | Sony Playstation 3 (PS3) Console
PS3 is not reading any discs I insert into the system.
The following types of discs can be played Blue Ray Disc - Playstation No 3 format BD-ROM, BD ROM,BD-R, BD-RE DVD - DVD-ROM, DVD+R/RW, DVD-R/RW, AVCHD, DSD disc CD - Playstation format CD-ROM,CD-DA (Audio CD), CD-R/RW
Also Check the regional code on the disc which should be compatible with the regional codes which can be played by the PS3
Jan 12, 2010 | Sony Playstation 3 (PS3) Console
PS3 problem - Wont recognise or load PS3 game disks
swich back and forth between the ps2 game and ps3 game or just keep putting in the ps3 game until it reads it. your laser is probally going.
Oct 05, 2009 | Sony Playstation 3 (PS3) Console
Plays ps2 games but doesnt plays ps3 games or dvds
please verify:
  • your dvd disc region (must be region free or 1 - for USA)
about ps3 games try:
  • restoring your system
  • reinstalling all game data files
  • re-updating your system
  • playing blu-ray MOVIES disc, to check a possible problem with your reader .
if the bd movie doesn't work, you have got a possible problem with your bd reader .
then, take it to an assistance center for hardware repair .
Jul 26, 2009 | Sony Playstation 3 (PS3) Console
My PS3 display is flashing...
On the XMB go to Settings ---> BD/DVD Settings ---> BD 1080p 24 Hz Output (HDMI). Turn that bad boy off.
Give that a shot.
Feb 20, 2009 | Sony Playstation 3 (PS3) Console
Ps3
you might want to try changing the settings settings just go to sound settings>audio output settings and choose the type of cable you're using sfter that select automatic and press X. if that doesnt solve the problem may be you accidentally chage the BD/DVD audio output format. is locate in BD/DVD Settings change both BD/DVD audio output format (HDMI) and BD Audio Output Format (optical Digital) to linear PCM or viseversa try both to see wich one works.
p.s. it can also be a problem with your sound/ hometheater system.
Apr 25, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
