Question about Garmin GPS
Forerunner 301. Battery won't charge, probably due to corrosion with the USB Port. Any way to clean it?
4 Suggested Answers
eMitH
  • 22 Answers
SOURCE: garmin forerunner 301
hi
the garmin gps often use a soft rubber in their contruction
either wait til the unit is out of the heat or use a bit more pressure to push the button doen firmly
the map60 range has the same issue with the power on/off buttons
there is no replacement parts as its built into the case
D
Posted on Nov 21, 2007
SOURCE: computer has a problem communicating with my forerunner 205
I just got off the phone with garmin tech. She helped me solve the problem. Here are the steps.
1. Go to http://www8.garmin.com/support/collection.jsp?product=010-00466-00
2. Download "Forerunner 205 Ver. 2.80 as of Nov 12, 2007", unzip it, and browse to the folder you unzip the files to.
3. Make sure your Forerunner is connected to your computer and turn it on. Drag file "048401000280.rgn" and drop it on "Updater.exe". A screen will pop up, select "USB" then click OK. Then wait till the process completes.
4. Go to the website on Step 1 and download "Training Center For Windows Ver. 3.3.4 as of Feb 29, 2008". Install it.
5. Run Training Center. At this point, I am able to send/receive data to my Forerunner.
Hope this helps!
Posted on Apr 02, 2008
SOURCE: Change battery on Garmin Forerunner 301
Hi - look at this solution for a forerunner 201, which has the same case design. I was just looking myself! R_nz Rank: Apprentice Rating: 96%, 8 votes I've made some progress here, I discovered that there is a small notch beneath the flat black pastic insert that holds the rubber button cover in. By gently prising this out, I can at least expose the pcb with the buttons on. I still can't figure out how to open the case though ****! Comments: Jan 29, 2008 - Well, I got there in the end! As above, I managed to prise the plastic insert cover off the rubber button cover, the peeeled this off as well. Underneath is a mylar printed circuit with the silver domeos of the buttons moulded in. This is siliconed down, but you can peel it up with a fingernail. The top left end (above the on button) is aatached inside the case, so start at the other end. Jan 29, 2008 - .ctd.. Once you have lifted the mylar strip, you can get at the case seam underneath and prise it gently open with a flat blade. The case is glued together with a light silicon or something. My problem was unresponsive buttons and by detaching and then re-attaching the small connector by the big silver block where the mylar attaches to the main board and then re-attaching it, it seemed to fix it! :-) Oct 22, 2008 - As an end-note; I glued my 201 back together with a light Silicone sealer. It seems to be at least rain proof anyway. Forerunner 201 battery replacement (Expert level): Opening the 201 was not easy and could not be done 100% clean, but thanks to R_nz (above) I got it open. My problem was dead (almost) battery, after 6 years of superb operation. I found the battery to be glued (double sided tape) to the back cover. To remove, push it up slowely and pull out. Beware of the short wires. 1. It is a flat battery, wrapped in shrinkable tube. Made by MDTechnology, P/N 043048 3.7V, 500mAh see http://www.mydbattery.com/EN/products.asp?ID=12 2. On the cover, the battery is soldered to the underside of a small PCB, hard to get to (by expert!). If you find a battery, suggest to cut the wires and solder wire-to-wire. Hope that helps
Posted on Jul 08, 2009
I want to know how to open the device to change the battery
Possible that the battey is weak and so will charge up fast and show a full charge. It will be best to check with a swapped battery and if so the battery can be replaced.
Also cross check the adaptor.
Dec 29, 2011 | Garmin Forerunner 301
Camera will not turn on even though battery is charged
your new batteries may be worn out to the point that they won't accept a charge, but the problem you describe is frequently due to corrosion on the battery contacts inside the camera. Remove the batteries and wipe the camera contacts firmly with a clean cloth (heavy corrosion buildups may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment, clean the contacts at both ends of the batteries, and reinstall them in the camera.
thanks
Apr 21, 2011 | Cameras
My forerunner 205 was charging just fine until I pressed the power button. The screen went blank and I cannot turn it on. Does this mean the battery needs to be replaced. If so, how does one go about...
Probably it is not due to the battery.
Your device is crashed. Perform soft reset :
press & hold mode plus lap/reset keys for 10 seconds, release then press start long enough until device starts.
Sep 26, 2010 | Garmin Forerunner 205 GPS Receiver
Forrunner 301 won't turn on or charge
You can try various resets to see if you can get it to respond.
Have you tried plugging the unit into the wall instead of the USB
port.Do you get the Battery Charging message at any time.You can
try a soft reset.Press mode and reset.Then try to power on while
plugged in.A hard reset will delete all your data and settings from
the Forerunner.Press the Power and the Mode button until the unit
comes on and asks if you want to erase all user data.Select Yes.
If the above won't work, try a hard reset that by-passes the
confirmation screen.Press Mode, Reset and Power.
Oct 29, 2009 | Garmin Forerunner 301
My Garmin forerunner 305 recently got immersed in
I have read in some other posts about the unit only working while being plugged into a USB port. My guess is that the battery is in fact shot and the unit will only run off the USB port while plugged in. Submersing in water is not a good idea. On the back of the unit there are some small holes for the speaker. These speakers corrode from sweat and eventually quit.
Jun 05, 2009 | Garmin Forerunner 305 GPS Receiver
Garmin Forerunner 205 Battery won't charge. A few
Hey everyone. Just called Garmin and got it fixed. Sometimes the forerunner goes into power saver mode and needs to be reset
1. Hook up the usb cable and docking station to the computer.
2. Next, hook up your forerunner to the Docking station - It should pop up saying battery charging in progress
3. Leave it all hooked up and Hold the Mode and Lap/Reset Button together for 15 seconds - screen should go blank.
4. Let both go - should pop back up saying battery charging in progress.
5. Let Charge 20 minutes and it should be good to go.
Hope this helps!!!
Kenny
Feb 20, 2009 | Garmin Forerunner 205 GPS Receiver
Garmin Foreruner 305 will not turn on or charge
I had the exact same problem and thought my beloved forerunner 305 had finally died. Try pressing the lap and mode keys simultaneously, and then power on. That may do a "soft reset." Worked for me.
Jan 05, 2009 | Garmin Forerunner 301
Garmin forerunner 301
hi
D
Nov 21, 2007 | Garmin Forerunner 301
No connection through USB
I have the same problem with my unit. It is 18 months old. The rubber cover seems unable to fully protect the connection. I sent off the unit to "Garmin Europe" located in (UK)Hampshire SO51 9DL". I was expecting some horrible repair bill. They have charged me under £40 for the repair/replacement and given me another years warranty. They have promised a fast turnaround. I think the cost is worth it to retrieve my data and cary on using htis excellent peice of gear.
Feb 12, 2007 | Garmin Forerunner 301
GPS Logo
63 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
