Cn-btu1 I ned driver for my bluetooth dongle from canyon cn-btu1
Usb dongle is not working
Step 1:
A Bluetooth dongle is an external Bluetooth device used to enable your PC's Bluetooth connection. Many Bluetooth dongles come without installation disks since the software is pre-programmed into the actual USB stick. These Bluetooth dongles are very useful on netbooks that don't have Bluetooth connection, since netbooks have no CD-Rom drives. Turn on your PC. Insert the USB Bluetooth dongle into the USB port on your desktop tower, or the USB ports located on the perimeter of your laptop. Wait for the program to auto run. Once you connect your dongle, the driver program should launch. Follow the onscreen prompts to install the dongle. A dialogue box should open that says "Installing Drivers" from the taskbar. Allow the driver to install completely before closing the box. Unplug the dongle and restart your PC. Once the PC has been switched on, insert the dongle. Double-click "My Bluetooth Places." This is the Bluetooth icon located in your taskbar, and it should launch the "Initial Bluetooth Configuration Wizard." Click "Next" on the first screen. Next, type in the name of your computer and select your computer type from the drop-down menu, then click "Next." Click "Skip" on the onscreen prompts, then finish. Pairing the Devices Turn on your external Bluetooth device. Double-click "My Bluetooth Places." Select "Find Bluetooth Devices." The name your Bluetooth device should display in the next window. Right click the icon for your Bluetooth device, and scroll down to "Pair Device." Enter the Bluetooth pin code for your external device in the "Bluetooth Pin Code Request" pop-up window. Then click "OK." The default pin code is normally "0000" or "12345." You can find your pin code in your user manual. If you are pairing a cell phone to your PC, you will have to enter the same pin code on your cell phone to establish the Bluetooth connection.
Apr 10, 2013 | Computers & Internet
Tip
How do you solve a Bluetooth Dongle Problems?
<p>Bluetooth wireless technology allows many devices to connect wirelessly to computers, keyboards, mice, speakers and even other computers. Most desktop computers come with Bluetooth pre-installed adapters, allowing many to purchase and install an external Bluetooth dongle adapter. These dongles are usually connected to an available USB port and automatically installs without much fuss, but there is the possibility of going wrong, because usually when people and computers interact. Fortunately, hiccups are usually quite easy to solve. <br /> <p><br /> <p>1. Unplug the dongle on the computer using the "Wizard Safely Remove Hardware". Look for an icon in the Windows taskbar that looks like a USB connector with a green circle and check mark next to it. Wait a few minutes, and then reinsert it. This will cause the drivers are loaded on your computer and your problem. <br /> <p><br /> <p>2. Restart the computer; make sure the dongle is working properly. Some drivers need to restart your computer before working properly. <br /> <p><br /> <p>3. Download and install the latest drivers for your Bluetooth dongle. If you are unsure of where to get it, Windows can do it for you. Open "Control Panel" menu "Start," click "Hardware and Sound" and then "Device Manager". Expand the Bluetooth Radios section "from the list that appears, right click on the Bluetooth adapter, and select" Update Driver ". Select" Search automatically for updated driver software. " <br /> <p><br /> <p> <p>4. Then remove, reinstall the Bluetooth dongle. Right-click on the Bluetooth dongle "Bluetooth Radios" from the "Device Manager" and select "Uninstall." Remove the dongle from your computer, restart the computer. Connect the dongle back and reinstall drivers for Windows.
on Jun 26, 2011 | Televison & Video
Tip
How to Fix a Bluetooth Dongle in a computer
<p>Bluetooth devices connected to a computer system via a wireless signal, so that the desktop of annoying cables and wires to strip. Even if your computer does not have a built-in Bluetooth receiver, you can create a Bluetooth dongle, the function adds the system to connect. If the dongle is not working to resolve the situation. <br /> <p><br /> <p>1. Check the system requirements for the Bluetooth dongle. If the system does not fit all the requirements, the device will not work. The requirements for the Bluetooth dongle can be printed in the manual and packaging. You can compare that with what is running on your computer by clicking "Start" "Control Panel" and "System". This gives the computer hardware. <br /> <p><br /> <p>2. Unplug the Bluetooth dongle, restart the computer, plug it into a USB port. If you leave power on the computer with the dongle already instead, the system can not detect the devices. Restart the computer and perform this action helps to correct the problem. <br /> <p><br /> <p>3. Remove the dongle from the USB port and plug it into another compound. Some USB ports do not meet certain computer hardware detection. Changing the connection port fixes this. <br /> <p><br /> <p>4. Install the driver on the included CD driver installation. Without the driver, the computer can not detect and use the dongle. Insert the installation CD driver on your computer and follow the steps on screen to install the driver on the system. <br />
on Jun 26, 2011 | Computers & Internet
I lost the cd install for my web cam canyon cn-wcamni
Dear user, you can download it in this link.http://www.canyon-tech.com/support/drivers?NODE_ID=70321073942096252&ITEM=80410120115521921
Apr 29, 2011 | Computers & Internet
No driver for mustek bluetooth mbt-d120 for Windows 7
windows should automatically detect the bluetooth dongle and install windows standard drivers for it, if it doesnt , then you have a faulty dongle
Apr 10, 2011 | Mustek (MBT-D120) Bluetooth USB Wireless...
Bluetooth 2.1 USB nano dongle no driver
Click here to download the driver.
Now install it on your windows 2000.
Note: Windows xp will automatically recognize your dongle without external driver. I personally recommend you to use xp
Wishes .. :)
Jul 18, 2010 | Adapters.com Bluetooth USB Adapater, USB...
Driver for bluetooth dongle Device :- Blue tooth Dongle Problem:- Driver for Win Xp
http://www.bonphi.com/download.html
http://www.brothersoft.com/downloads/bluetooth-dongle-driver.html
http://download.cnet.com/Bluetooth-USB-Dongle/3000-18493_4-75778.html
Jul 11, 2010 | Computers & Internet
Lost the cd installer for my webcam
i lost my cd drive my web cam model no canyon cnr-wcam43
Sep 18, 2008 | Canyon Drag And View (CSDV0004) for PC
Bluetooth class 2 dongle
here are some sites in which the bluetooth dongle drivers for vista are available just download it from here for free........
www.exwell.com/support.html
www.telusplanet.net/public/wladykad/
www.dev-toast.com/2007/01/05/uncrippling-bluetooth-in-vista-rtm
www.dirfile.com/medieval_bluetooth_diagnostic_tool.htm
www.fulldownloads.us/free-full-download-bluetooth+usb+dongle+driver+vista-crack-serial-keygen-torrent.html
yzoo.co.uk/search/web/mikomi+bluetooth+driver+vista.html
www.radarsync.com/vista/vista_more.php?result=400
www.mobilefun.co.uk/cheap-jabra-bluetooth-dongle-vista-driver-download.htm
www.nodevice.com/driver/company/Gigabyte/Bluetooth_network.html
Feb 08, 2008 | Microsoft Windows Vista Ultimate Edition
Problem with my bluetooth dongle
Do you have tried to uninstall the drivers from the bluetooth dongle?
Uninstall the bluetooth, then try in other usb port.
It could be some problem whit the driver
Nov 09, 2007 | 11Wave amb-1101 Bluetooth Wireless Adapter
Computers & Internet Logo
1,206 people viewed this question
David Payne
David Payne
