I've a still problem when i'm playing any games. I used to play EA Sports FIFA 2007,Cricket 2007 etc. But one day,needed to format my computer because of invading threats. After this matter I can't play above mentioned games & many other. Apart from problem my PC has no other problems. Video, picture no ploblems. I have formatted my PC six times,but no solution. Hardwares are totally working but when run a game (like FIFA 2007) PC will be hang, stop responding, and then autometically take restart. This problem is occuring from ten months ago but no solution. I have ATI Radeon 9200 128mb AGP card. I Played the mentioned games former, but do not play now. If it is the problem for ATI settings, please tell me ideal settings. My features: AMD Athlon (AM2), 1 GB Ram, 160 GB HDD, ATI Radeon 9200 128MB, Windows XP (SP2).... Please Help......
What are the minimum system requirements for FIFA 07 ?
Same Problem
Dec 04, 2008
-   My screen crashes while playing EA sports cricket 07 even i updated vediocard to the latest.my PC ifo is : Microsoft Windows XP Professional Service Pack 2 , Display Device : VIA/S3G UniChrome Pro IGP .directX 9.0c, processor: AMD Sempron(tm) Processor LE-1100 1899.8 MSI motherboard , if anyone can help me pls E-mail me. -   alsabah
Problems with this kind of "PC Freeze" or Hang Up when oppening games or 3D accelerated applications are you dont know what part of your PC is failing... many of this problems are very hard to fix... first of all it might be a power supply problem.. take note that it gives the proper current for your pc to work,therefore a failing PSU will make your PC freeze... another one is your motherboard, if you have a faulty motherboard it might make your pc freeze... this might be a video card problem too... maybe your video card is overheating or it can also have conflict with your built in VGA try disabling your Built in VGA... try cleaning your pc with dust and try to run it again... and last is your sound card... it might have conflicts on your onboard sound chip... try disabling it at your BIOS... as ive told you its complicated because you will never be sure what part of your pc is causing the problem... and also check if your pc is overheating...
top 5 problems are 1. Power Supply is Failing 2. Video Card is overheating 3. Faulty Motherboard 4. Your PC is overheating 5. Hardware conflicts
i wish you good luck and i hope my reply helped... :)
when i used to play FIFA Sports Cricket 07 in my Pc My computer hang after 2 to 3 from the start of...
(More)
when i used to play FIFA Sports Cricket 07 in my Pc My computer hang after 2 to 3 from the start of the play. But no problem in using othe games My Pc Configuration Intel 31 PR Mother Board Inel Core2Duo 2.66 Ghz Processor 2 GB Ram Please help me to sought this problem I Format the system for Three Times But No Use Please Help me
hello sir i have COMPAQ CQ50-106AU laptop . sir my laptop had come with
free dos environment and...
(More)
free dos environment and than i had installed xp on it but sir one day
i installed vista in it and downloaded all the supported drivers from
hp site , but sir when i was installing drivers for vista by mistake i
updated my BIOS , and after than when i try to install xp my laptop
will completely turn off. but it will not turn off while installing
vista. with this problem sir 1 more issue is created is that i have 2
.iso images of EA SPORTS CRICKET2007 every time i load image with demon
tools and had installed that game , but after having this xp
installation problem whenever i play that game on xp in my laptop ,
laptop will get turn off but sir if i install that game of vista ,
laptop will not turn off . i was using this game very fine on xp in my
laptop . please sir help me.
