Question about Bosch Washing Machines
Replacing brushes bosch classixx 1000 - Bosch Washing Machines
  • 139 Answers
Hi ya
The brushes on the machine are located on the motor. The motor for this brand of machine is located on the bottom of the drum. The brushes are in black holders usually but can vary in colour.
The are simply held to the motor with 2 screws each either side.
The best way is to disconnect the pipes from the machine make sures theres no water in the machine and and flip it onto its head i.e. upside down.. use a short handle posi screw drive to remove the brushes from the motor and disconnect the the little wire wire from the end of the brush and remove and replace its that simple
hope that helps
washdoctor
Posted on Aug 25, 2008
4 Suggested Answers
  • 57 Answers
SOURCE: Softener won't empty in Bosch Classixx 1000
take out the soap drawer clean in hot water inside the machine where you took the soap drawer out at the top look for the hole where the water runs out it may be blocked with mildew dettox mildew spray is very good at breaking all that down spray in leave for a while put soap draw back in and do a wash without clothing as spray contains bleach
Posted on Mar 30, 2010
beltronic205
  • 1474 Answers
SOURCE: Bosch classixx 1000. Impeller loose.
You are best fitting a new pump asa temp repair impeller can be reglued but a new pump is bet fitted.
Posted on Apr 20, 2010
  • 50 Answers
SOURCE: bosch classixx 1000 express wont spin
Check the motor housing for an overload button, usually on the back and coloured black or red. Give it a push and if it clicks then the motor might have just been a bit stressed out and popped it.
Next two things are more serious unfortunately. The relay on the circuit board might have burnt contacts from switching the motor over the machines life, or, one of the motors windings has developed a fault. (these are both pretty rare though).
Posted on Jul 29, 2010
F21 flashing on my bosch classixx 6 1200 express
F21 is a motor fault and in some cases can also involve a module fault. It could be as simple as the brushes need replacing or the drum has been severely out of balance.
Mar 21, 2013 | Bosch Washing Machines
Bosch classixx 1000 express wont spin
Jul 29, 2010 | Bosch Washing Machines
My Bosch washing stared making fizzing sparking noises when spinning the other day although ran OK, then it started to blow the trip before being unplugged. On trying again, it fills and drains OK but the...
Sounds like the motor coils are gone ,The armature would have been arcing hence the sounds you heard this may be cured by replacing thermal cut out ..This is Buried within the coils.....Check wiring to the brushes are ok also
Apr 13, 2010 | Bosch Classixx WFC 2465 Front Load Washer
My bosch classixx 1000 washing machine is not spinning at the end of the wash cycle, and when set to spin it does not spin, what can i do?
Remove belt, unscrew 2 bolts that hold the motor, unplug the motor connector, lever the motor back with a screwdriver. Check the motor brushes, if they are any shorter than 1 cm replace brushes.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Sites for spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
mcminone.com
Pl vote me 'very helpful' for the free help, thnks!
Apr 03, 2010 | Bosch Classixx WFL 2066 Front Load Washer
I have a bosch maxx 1000 (wfl2000au/30) machine will not spin. pupm impeller was jammed by a bobby pin. i removed the bobby pin. when machine is on spin cycle only the pump opperates. does not spin at all....
If there is no water in washer, and it will not spin, I suggest you remove the motor, and check the brushes.
If they are less than 3 or 4mm long, they need replacing.
Hope this helps.
Dec 05, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosche classixx 1000
Rotate the drum by hand. If the drum spins to freely without much resistance then it is possible that the drive belt has come off. Its unusual but it can happen. Remove back panel and refit the drive belt carefully.
If the machine is older than 5 years its possible that the wash motor brushes need replacing. If this is the case then you need to call a technician to replace them.
0417362396 Melbourne Metro area
Regards Sam
May 20, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Changing the brushes when the motor is off
Nov 16, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Brushes
most brushs are screwed to the back of the motor which are very easy to replace,other are inside the motor and you have to dismanttle the motor.i hope this is what you wanted to know.your question wasnt clear.
Mar 06, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Washing Machines Logo
1,415 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
