Question about Olympus Camedia C-5060 Wide Zoom Digital Camera
Reset my camera settings
How do I reset my camera settings to the factory default settings?
  • Anonymous Mar 26, 2014
    my set top box has frozen due to an OTA update. Is there any manual factory reset buttons to try and fix the problem, the menu is not accessable to factory reset it.
    Master:
  • 852 Answers
You can reset the camera to the factory default settings by pressing and holding down the two buttons on the top of the camera next to the shutter button. You will hear a short beep and then a long beep once the camera has been reset.
Posted on Sep 04, 2005
Please email me back at olivestone@bell.net
for an answer to my ??
as most people are having this problem
my finepix S1800 Fuji film Digital camera keeps saying to turn it on and off all the time
Have tried everything and all the buttons on it. Tried changing batteries, new memory card
will try to take the camera apart next.
I have seen some images but cant take pictures
this camera was well taken care of never went anywnere
just sat at one place for a few months
then decided to go one me just like that
bottom Line: What is wrong with this 1.5 years old camera
bought it in Sept 2010.
p.s. Fuji Film wont fix it. says cause I had sticky stuff on the camera
on the outside..they were too lazy to clean it off on the outside
told me a b.s. story that the sticky stuff could have made the camera bad..WHAT B.S.
too LAZY TO TAKE AFEW SECONDS TO WIPE THE CAMERA OFF.!!
ANYONE TEX SAVY ON DIGITAL CAMERAS TO FIX THE CAMERA IN A FEW MINUTES
Posted on Apr 03, 2012
SOURCE:
Deracam will not reset. How do I get it to reset?
If you want to reset your IP Camera to factory defaults, you can use the following 3 methods. After resetting the device you will lose all your settings except Client Settings.
Method 1:Hard reset/ By pressing the RESET button
Step 1- Keep the device powered on for at least 30 seconds to complete its normal startup.
Step 2- Find something like a pin to press the Reset button on the camera and hold it for 15 seconds to restore the settings to factory defaults.
Step 3- Afterwards release Reset button, and the camera will be restored to factory defaults after rebooting.
Note: Reboot process takes about 1 min, please be patient.
Method 2:By using Intelligent IP Installer
Step 1- Install the Intelligent IP Installer with the CD.
Step 2- Run the Intelligent IP Installer. Click Search to find your device.
Step 3- Select your Camera in UPnP device list, click Factory default on the right side.
Step 4- Type the username and password in the login page, the default username and password are both admin. Wait for the device to reboot.
If you changed the username and password before and forgot the username and password, you have to follow
Method 1, make a hard reset.
Method 3:By using Web-based Utility (management page)
Step 1- Open the web browser and type the IP address of the IP Camera into the address bar, press Enter. If you have changed the default port number is 80, Then type the IP address of the camera: new port number into the address bar of web browser.
Step 2- Type the username and password in the login page, the default username and password are both admin. Then click OK to connect to the device.
Step 3- Click SETTING -> BASIC -> Initialize on the left side, and then click Factory default to reset this IP Camera to the factory default settings.
Step 4- Keep waiting until the progress bar shows completion.
Feb 04, 2018 | Miscellaneous
Hello. How can I reset Panasonic Lumix DMC-TZ60 to factory default? (Can I reset software and hardware?) Thank you for answer
Resetting by 'Software'
Resetting to the Factory Default Settings from the interface:
  1. Go to the interface of your camera by typing in the camera's IP address in the browser. Example: http://192.168.1.253/
  2. Click Setup, Maintenance, Default Reset, Reset to default and then click Execute.
Resetting by 'Hardware' Resetting to the Factory Default Settings using the Control button:
  1. Disconnect the 'DC IN' cable from the camera.
  2. Hold down the 'Initial Set' button.
  3. Reconnect the power adapter using the 'DC IN' jack while holding down the 'Initial Set' button. Release the 'Initial Set' button after 5 seconds. (The reset could take up to 180 seconds)
  4. When the 'Status' indicator changes to green, the process is completed and the camera had a Factory Default Reset.
Sep 11, 2016 | Panasonic Cameras
Hi. what is default password Ip Camera model vivotek ip7730 ?
By default, the Network Camera is not password-protected.
Hardware Reset
The reset button is used to reset the system or restore the factory default settings
Sometimes resetting the system can return the camera to normal operation If the system problems remain
after reset, restore the factory settings and install again
Reset
: Press and release the reset button with a paper clip or thin object
Wait for the Network Camera to reboot
Restore
: Press on the reset button continuously for over 5 seconds
Feb 15, 2015 | Computers & Internet
Panasonic WV NS 954 PASSWORD RESET TO FACTORY DEFAULT
Hi
there is no Password reset to default.
in order to restore the camera setting to default are by doing a restore to default inside the configuration page, or , by doing hard reset on the camera by pressing the reset button
Feb 03, 2014 | Panasonic Wvns954 I-pro Wv-ns954 Ip Ptz...
I have sony DSC-W190,i want correct menu setting ,bcos if i take a picture its not clear,i think may be menu setting changed,idnt any idea about menu setting pls help.....
If the Menu settings in the camera is changed, then I suggest you to reset the Camera back to factory default. Initializing the Camera back to factory default will set all the settings in the Camera back to factory default.
To initialize the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
You can also try a manual reset;
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
The blurry image capturing can also adjusted by changing the ISO Settings or the Scene Selection modes.
Thanks for using FixYa!
Apr 07, 2011 | Sony Cyber-shot DSC-W190 Digital Camera
Can i reset the settings to the original factory settings?
In order to reset the camera settings to its default values you need to do the following:
-Press the MENU button
-Use the left or right arrow keys to select the Settings menu (its icon looks like a wrench and hammer)
-Use the up or down arrow keys to scroll to the choice that says "Reset ALL..."
-Press the "Func./Set" button to confirm your choice.
This will reset the camera to its factory default settings.
Jul 14, 2009 | Canon IXUS 80 IS Digital Camera
Master Reset Olympus x840
To reset the camera - have the camera in shooting mode - go to Menu - left arrow to reset - press ok - Highlight yes and press ok. This will set the camera back to factory default settings. Hopefully this should solve the issue.
Apr 13, 2009 | Olympus FE-210 Digital Camera
How to reset to factory specs??
Enter the SETUP menu and select RESET. You'll be prompted to reset two sections. Answer YES to both and everything that can be set to default will go back to the factory default state.
Jan 13, 2008 | Panasonic Lumix DMC-TZ1 Digital Camera
Cd300 resetting default setting
Okie-tex, Why yes you can reset your cd300 back to the factory settings. On the bottom of the camera underneath the on and off button for your LCD is a little hole and it says reset next to it. Insert a straight pin into that hole and it will reset everything back to factory settings. Fellow Texan
Sep 13, 2005 | Sony Mavica MVC-CD300 Digital Camera
Olympus Camedia C-5060 Wide Zoom Digital Camera Logo
1,055 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
