Question about Sony PlayStation Portable (PSP) Console
Sound does not work
Sound does not turn up or mute.sometimes it will come on but like i said you can not adjust it.sometimes it will just not come on whatever i try doing
thankyou for reading.
  • Sony Master
  • 1,800 Answers
Try the phones if not work u need the chip sound to be replaced
need rate to this post!!
Posted on Aug 25, 2008
Speakers have no sound
Have you tried going into the program and adjusting the volume there? Sometimes that gets put on mute
Jan 08, 2014 | Computers & Internet
How to double check speaker hook up on asus desktop computer
maybe they have the volume muted. Check to make sure the volume is not muted and that the speakers are plugged into the light green port in the back of the computer.
Make sure the volume on the physical speakers are turned on and turned up. And make sure the volume in the Audio Sound Properties it turned up and not muted.
If you see the speaker megaphone at the bottom right near the time click on it to adjust the properties.
You can click Start/Control Panel and look for Sound or Audio properties.
May 02, 2012 | ASUS Computers & Internet
Turn on microphone
Go into your Audio/Sound properties and make sure the microphone is selected. Also make sure the volume is turned up and that it is not on mute.
Sometimes if your megaphone is shown at the bottom right near the time you can right click on it and select adjust audio properties.
Mar 30, 2012 | Computers & Internet
Sound dosesnt work at all
Go to the device manager and check that the sound driver is installed and working correctly. Start>control panel>hardware and sound>device manager. Look for; sound, video and game controllers and expand the menu. Right click on the audio adapter and click properties. This will tell you if the adapter is working correctly. Click on the driver tab and choose; update driver and then; search automatically for updated softwarel. Sometimes the sound can be muted so thats worth a look as well. From the control panel choose hardware and sound and under the sound heading, click adjust system volume and check that the volume is turned up and not muted.
Mar 25, 2012 | HP Computers & Internet
I just received for my birthday, a RCA 900 MHz headphones. Followed the instructions but cannot get it to work. I tried to install it on a Hitasha TV. Can you help me?
First you need to make a test to adjust your headphones wireless system..
.pls follow the step below:
  • "Connect the RCAheadphone base" TO " headphones output of TV" with 3.5mm stereo headphone jack cable (than Tv should mute ) RCA pilot lamp should flicker in parallel to voice coming from TV
  • RCA headphone should have 2 different rotary adjustment on it..one "Volume" and the second "Frequency" adjustment
  • while TV talking , adjust slowly the "frequency rotary dial" to catch the headphone transmitter coming from RCA headphone base,when you catch it you will hear the voice of TV,(sometimes fine adjustment makes it better ) than adjust volume properly..
  • .After this pls do not touch Frequency dial any more..Just Turn it on ,and Volume adjustment ..Thats it..
  • After completion of this test ,I recommend you to switch / use "RCA Audio output plugs-white/Red cable " on the back of TV instead of TV's headphone output ,since it mutes the whole sound..RCA output plugs work independently from the TV's master volume control..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 30, 2011 | RCA Audio Players & Recorders
I have a Clarion XMD3 am/fm marine cd player that came with my 2000 Searay boat. I was somehow able to turn the inside cabin speakers off last season and only have the outside speakers on. I must have...
Might be set on mute !
Mute instructions
Use this function to turn off the sound immediately.
1. Press the [ M ] button.
The sound turns off and "MUTE" appears in the display.
2. Press the [ M ] button again to cancel the mute mode
in this other user manual it is a mute button[m] page 4
http://www.clarion.com/us/en/MungoBlobs/552/388/XMD3.pdf
or
Adjusting the fader
1. Press the [ A-M ] button and select "FAD 0".
2. Press the [ w ] button emphasizes the sound from the front
speaker, press the [ z ] button emphasizes the sound from the
rear speaker.
? The factory default setting is "FAD 0". (Adjustment range: F12 to
R12)
3. When the adjustment is complete, press the [ A-M ] button
several times until the function mode is reached
May 04, 2017 | Clarion XMD3-RET AM/FM MARINE CD PLAYER
Pc sound is not working right now hepl me
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 20, 2011 | Computers & Internet
No Sound on Samsung HDTV? But there is a picture...
Push the MUTE button on the TV remote to restore audio.
Nov 18, 2009 | Samsung LN-T3253H 32 in. LCD Television
Mute is on when I turn my vizio on. How do I
The OSD consists of several menu options: Picture Adjust, Audio Adjust, TV Tuner Setup, Parental Controls,PIP Set Up, or Special Features. When in the TV menu, select the Audio Adjust and make sure the mute is off. It may be worth checking the manual which is avialble from: http://www.vizio.com/downloads.aspx
Aug 20, 2009 | Vizio L32 32 in. LCD HDTV
NO SOUND WITH HEADPHONES
Update driver, gotohttp://www.via.com.tw/en/support/drivers.jsp select OS and choose Audio then VIA HD Audio Codec 1708b. If this does not work, click mute and un-mute ontaskbar when there is no sound. I have had the same problem (sometimes) when using certain headphones,and pausing video, then playing video,sometimes the headphones have no sound, but if I unplugged headphones, the speakers work.I plug headphones back in, no sound. So i press the mute button twice.
Jul 23, 2008 | Everex StepNote NC1500 Notebook
Sony PlayStation Portable (PSP) Console Logo
27 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
