Question about Fisher and Paykel GWL11 Top Load Washer
Stabalizer Is it necessary to keep the plastic stabalizer attached to the bottom, and if so where can I get a replacement?
  • 639 Answers
Dear friend,
ngfam at you service!
The Neptune was discontinued for 98 design defects!!!!!!!!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Posted on Aug 26, 2008
I am replacing a positive terminal and need to know if the original plastic cap or relay it is really needed. Having trouble with the old bolts
The plastic caps are not needed but the bolts are important to make sure they are tightening the terminal to the battery posts.
Jul 28, 2016 | 2001 Hyundai Sonata
How can I replace passenger side fender?
Too many unknowns here. How bad is the fender damaged? Is there any damage to other parts of the body that the fender attaches to? If so, then let a body shop do it because they have the equipment necessary to straighten those body parts. If you still want to give it a go, then take out all the bolts and other fasteners that attach other things to the fender like hose clamps,plastic reservoirs etc. The inner fender well has bolts that have to be removed from the fender. The fender itself has bolts accessible from under the hood. Get them all out and any stiffener rods at the front of the fender. There are a couple of bolts on the bottom of the fender where it meets the body nearest the front door. You have to get those from underneath. Keep track of where all the bolts and fasteners go so reassembly will go smoothly.
Jan 01, 2016 | 2007 GMC Envoy
Lamp replacement
No its just to keep glass out of your eyes and such you will need something to release the plastic clips that hold the lamp housing in like a nail file and a philips screw driver.
Dec 15, 2013 | Mitsubishi XD221U 3D Projector
How do I change a keyboard on a satellite A85-S107 laptop?
1. Take out the battery and AC adapter, unplugged from the wall, enusre the laptop is fully powered off.
2. Remove those screws with a T-8 or Phillips screwdriver.
3. Turn the laptop back over and open it up. Check and see if the Toshiba Satellite A85-S107 keyboard is tucked under any plastic pieces. If so, find them if those plastic pieces are screwed into anything, and unfasten them as well. If not, it probably uses clamps that can easily be removed.
4. Remove the plastic pieces carefully.
5. Unscrew any screws at the top (if necessary) and remove the keyboard itself from top to bottom. You'll notice that the keyboard is connected with a thin, but wide, data cable to the system board at the bottom.
6. Disconnect the data cable attachment of the keyboard which will sever all the remaining attachments of the laptop keyboard with the laptop computer motherboard. To remove this cable, you have to just carefully pull it out from the socket to which it is attached. Then you can lift out the entire keyboard out of the laptop.
7. Take the new Toshiba Satellite A85-S107 keyboard out of the plastic and place it inside with the right orientation, attach the data cable.
8. Refasten the keyboard in place at the top.
9. If you had to remove any plastic pieces, carefully snap them back in and replace any screws you had to remove.
10. Turn the laptop over and replace all of the keyboard screws.
11. Put the laptop battery back in place and switch it on to check Toshiba Satellite A85-S107 keyboard functionality. If everything has gone according to plan, you should be ready to type away!
Mar 12, 2012 | Toshiba Satellite A85-S107 Notebook
2011 Dodge Caravan. Ran into a metal wheelchair ramp rain. Drove back - dislodged - the black trim insert near the bottom of the plastic bumper cover. That black plastic thing has to be just put back on...
Hello are the steps to follow per All Data.
Release hood latch and open hood.
Remove the headlamp assemblies.
Hoist vehicle and support with safety stands.
Remove the five push pin fasteners attaching bottom of fascia/air dam to radiator closure panel.
Remove front wheels.
Remove front wheelhouse splash shields fasteners as necessary to gain access to bolts attaching front fascia to fender.
Remove the two bolts and two nuts attaching fascia to the front fenders (Fig. 1) and (Fig. 2).
Disconnect fog lamp wire connectors, if necessary.
Lower vehicle.
Remove two bolts attaching the upper grille support to the headlamp mounting panel at each side of the grille.
Remove bumper fascia from vehicle.
Position front bumper fascia on vehicle (Fig. 1) and (Fig. 2).
Install the two bolts attaching fascia to headlamp mounting panel at each side of grille.
Install the two bolts and two nuts attaching fascia to the front fenders. The fascia should be flush to fender.
Install front wheelhouse splash shields fasteners.
Install front wheels.
Connect fog lamp wire connectors, if necessary.
Install the five push pin fasteners attaching bottom of fascia to radiator closure panel.
Lower the vehicle.
Install the headlamp assemblies.
The "push pin fasteners" are the pain you are having i believe. They push in, but to get them out you need squeeze them on the back & pull at the same time. If you happen to break a few, you can buy them in various sizes at the auto parts store. I hope this information is helpful, an owners manual will not have any info like this in it.
Dec 02, 2011 | Cars & Trucks
How do you replace a drive cable on a toro recycler 6.5 hp.
Its a bit of a pain - but with ordinary tools, it can be done. Get the replacement cable first. You can see how the bottom spring wraps around the cable with a universal joint sort of arrangement. Remove the belt protector (three screws from the top deck; if you have a battery compartment, that will temporarily need to go. Release the old cable from the top and middle attachment points, then unhook the spring from the traction lever. You might need to destroy the old cable lock to the mower deck to remove the old cable. Remove the plastic cup next to the cable where it exits the mower deck. Replace parts in this order: New spring/cable to the traction lever, snap in plastic interface to mower deck, small plastic cup top cable attachment, then middle attachment. You might need to move the middle attachment after you give it a test run. Replace belt cover and battery compartment if necessary. A lot of steps but, except for a difficult fit to get the spring hooked up, nothing is really difficult. I paid about $30 for the replacement cable from a local dealer; Overpriced, but I wanted to get the job done today.
Oct 15, 2010 | Toro Lawn Mower With Toro Power Tools
How do u install the stabalizer link on a 1992 olds 88
Locate the old link, it is one bolt that holds isolators and washers around the stabalizer bar to keep it from moving up and down, and eliminates body torsional twisting.
Remove the old link-you may have to cut it off if it is rotted, and replace it as the old one was, there is one stabilizer link on each side of the stabilizer bar so if one is broke, look at the other side to see how the isolators and washers go.
Always replace both of these , never just replace one. Good practice and not expensive. (They may come in pairs, depending on where you buy them.)
Pretty simple once you attack it.
Oct 03, 2010 | 1992 Oldsmobile 88
There is water leaking from the bottom of the washing machine
couple of things to check, one make sure the drain hose is properly attached and no clogging. and also make sure all gakets are in good shape. and not worn out.
Nov 06, 2009 | Washing Machines
1995 Ford Taurus stabilizer bars cause rear end of car to ''sway''.
If you are any kind of car savy then you can do this yourself. Go to your local parts store and buy the stabalizer link kits. The stabalizer links are located behind the tires and bolt to the struts at the top and the stabalizer bar on the bottom. You don't need any special tools for this project and the stabalizer bars will cost you anywhere from 30-65 dollars a piece.
Apr 09, 2009 | 2008 Ford Taurus X
Plastic piece came loose inside printer
The parking mechanism front spring has a tendency to come off in the C4x family of printers. Re-attaching it is a fiddly task not covered in the service manual. The pictures show: a general shot of the parking mechanism from the front; a shot of the actuation lever, illustrating where the front spring attaches to it; a view into the empty parking mechanism compartment showing where the lug is to which the bottom end of the front sprint attaches; a suggested tool for re-attaching the front spring, made from a large paper clip.
Proceed as follows, using a torch where necessary: lift the parking mechanism out its holder; be careful not to detach the drain pipe. Using the tool, attach one end of50f32be.gif54a9806.gif88c5669.gif9145528.gif the spring to the lug at the bottom of the parking mechanism compartment. Remove the tool and leave the spring laying at the bottom with one end attached to the lug. Replace the parking mechanism in its holder, with the actuation lever in place. Now for the fiddly bit! Peer into the compartment to locate the free end of the spring and get the tool on it. Pull the spring until you can put the free end over the lug on the actuation lever. Remove the tool.
Sep 15, 2008 | Epson Stylus C42UX InkJet Printer
Fisher and Paykel GWL11 Top Load Washer Logo
20 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
