I have a toshiba model 65H81 which is about five years old. When I turn it on it is full of lines and shakes and moves around for ten minutes till you can watch it. Than the upper third shakes ans moves back and forth all the time. Thanks
  • 1,031 Answers
Its a convergence problem so you have to replace the board
Posted on Aug 25, 2008
  • Starnley Johnwells
    Starnley Johnwells Aug 25, 2008
    This is a common problem with Toshiba projection sets. The board inside the set encased in metal shielding called the Hyper Board. There are many small surface-mount electrolytic capacitors on this board and some of them need to be replaced. again replace the stk392-110 or stk392-150 with ever one you have Replacing surface-mount capacitors on a board that asmall is no easy task and should be done by an experienced tech.i think that should solve the problem
  • 10,594 Answers
Symptoms shows your TV has few capacitors weak (lower in performance) in power supply board and horizontal area. If you know how to unsold and sold components, check leaky capacitors in above stated area.
Regards,
    Genius:
  • 2,920 Answers
Your convergence board is getting weak you need to have it checked by a repairman
I have a Sony FD Trinitron 27' Model # KV-27FV310. It is approx 8 years old. After turning it on and watching a full screen for a few minutes; all of a sudden, a line came across half the screen;
top half missing is in vertical circuit of set---if it is a 27 inch and this old consider retiring it and replacing----other option is consider having a shop repair it--a rough guess would be as high as 150 dollars parts and labor is possible for your problems.
May 01, 2012 | Televison & Video
Bad picture until tv warms up
well its a problem fo an ic causing the issue that needs to be replaced
May 30, 2008 | Toshiba 57HX81 57" Rear Projection...
My Toshiba 65H81 won't turn on only flashing red light on the on button
This question with slightly different wording is listed here 2 times--see my previous answer.
Mar 20, 2012 | Toshiba 42H83 42" Rear Projection...
My Toshiba 65H81 65" rear projection TV's picture
You do not have individual lamps in that model. You have 3 individual picture tubes of which I don't believe they are bad. They have fluid in a reservoir that becomes cloudy after time and needs to be replaced, however this is something you cannot do yourself. I recommend you call a qualified technician to take care of it for you.
Nov 26, 2010 | Toshiba 65H81 65" Rear Projection...
Toshiba 65h81
Somewhere along the line you may have missed a cable connection. Recheck to be sure that all of the wires are reconnected. Also, check the +5V line. In the area of the convergence Ics there should be a number of pico fuses. One of those may have opened up.
Keep us posted.
Dan
Jun 09, 2008 | Toshiba 65H81 65" Rear Projection...
this is a very common occurance in these sets. toshiba has issued a servece bullteen with this set. Sorry to tell you this but this is a problem with some very small capacitors on what is known as the hypermodule. in my shop we fix 2 to 5 of these a month. you really have to know how to solder. Idealy replace the hypermodule is the best way. but......that board is hard to find. so we replace these 11 very very small componets with twezzers and a big magnifier. we charge about 250 to 350 for this repair.
May 30, 2008 | Toshiba 65H81 65" Rear Projection...
Toshiba 65h81
hard to give estamate ..let me see if you have to replace the stk ic and possible a couple fuses and resistors... average repair at my shop is about 225 to 350
Apr 20, 2008 | Toshiba 50H81 50" Rear Projection...
Toshiba 65h81 convergence problem
Give this a shot.. in the front of the tv when the access panel is off to where you can see the tubes. look off to the right and you will see a set of 6 small black knobs. The top knobs are for color the bottom knobs are BLUR.. turn those and see if they will help. ~Matt~
Apr 20, 2008 | Toshiba 65H81 65" Rear Projection...
Toshiba 65H81 convergence issue
Does the blue and red crosses move at all ... eather vertically or horizontally. if they move at all then it may not be the chips.. could be a resistor. if the crosses dont move then it probally the ic. these chips run about 7 to 45 dollars apeace depending on type. at our shop we charge around 125 to put in.
Jan 15, 2008 | Toshiba 65H81 65" Rear Projection...
Wavy junping horizontal lines
Requires the hyper board to be repaired . Has to be sent to Toshiba, unless you can change around 15 surface mount capacitors, They usually charge around 420 to 450 Canadian
Aug 31, 2007 | Toshiba 50H81 50" Rear Projection...
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
Electro Med Services...
