Which model of Ricoh are we talking about here? If touch screen is not responding before replacement, re-calibrate touch screen or replace it. I can help you with the calibration code if you require. If the touch screen is not responding after replacement, check whether the replacement lcd display panel was installed reverse as the connectors will not have contact.
you must execute touchpanel adjustment.In the right side on copier in neighborough to USB connector located one plastic door.Pull out the plastic and press a little microswitch.After press the switch wait to appaire a * symbol and press 3.In the blue yield introduction 00000000 and press END.On the touchscreen appaire screen adjustment.
The problem with your phone is as a result of a bad flex connector cable which connects the touch screen to the panel,it's weak and needs to be replaced.
However,the solution is to take apart the phone and remove the flex cable which is in form of a ribbon situated behind the touch screen and replace it with a newly purchased flex cable.
if you would have sent it to me first I would have replaced the case for you and you wouldn't have had these problems, but I can still help you out. I have a white nintendo DS lite in stock that I had to replace the bottom lcd display in. I will ship to you for $90 and if you are feeling adventurous send me your parts and I will take off $10 since I have no clue what is broken and what is not, but to me it sounds like the bottom lcd, touch screen , and circuit board are trash. Thanks Josh Boyer [email protected]
As far I can see with this information is that you have a connector problem. Help you with that by writing solutions would nog easy solve your problem so my advice is to find a repair service in your city that can help you out or send it to Nintendo.
The cable for the touchscreen is one with 4 conductors that connect directly to the overlay on the face of the LCD. The flat ribbon connector on the main board is quite delicate. The three connectors for the bottom screen are on the right side of the component side of the DS phat board. The touchscreen is labeled P6. On the DS Lite, the connector is closer to the R button.
