You could try searspartsdirect.com or e-replacementparts.com
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Miele model by clicking the link below.
http://m.miele.ca/OperatingInstructions/en-CA/Vacuums/Previous%20models/Miele%20Vacuum%20Cleaner%20Manual%20S500-548_S600-648.pdf
You can purchase a wide variety of high quality Miele replacement parts for your Miele vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Miele
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
SOURCE: My Miele cat & dog
Will it power up without the hose attached? If it does then you have a clogged hose. If not, there is a circuit board by the motor that may be bad.
SOURCE: artico miele vacuum cleaner
Ok, that's usually directly related to the cord reel's contacts separating. I actually just posted this fix as a response to another thread, but here it is:
It is not generally necessary to replace the entire cord reel, although occasionally it is.
Here's the quick and easy DIY way to make your cord reel work again: you will need a #2 phillips head screwdriver, any flat head screwdriver, a pair of scissors, and a zip-tie.
First, remove the bag compartment lid by gently prying the hinge parts inward with the flathead screwdriver until you can lift it free. Remove bag and exhaust filter, and then remove the two screws holding the rear control panel on. Lift the front of the control panel upward until you hear a horrible unpleasant crunching noise. You didn't break it.
Lift that free, and remove all screws from the top of the main housing. (I believe there are 6 or so... but I can't remember off the top of my head.) The housing should then lift free.
You should now be able to see your cord reel. see if it wiggles back and forth along the central axle. If it does, you'll want to place the zip tie around the side of the axle which is away from the large round copper contacts which look almost like leaf springs. This will ensure that the contacts make electrical contact again. Cut off the excess zip-tie.
When putting the parts all back together, it is essentially a reverse of the disassembly, but be sure that you thread the cord through the hole in the back of the housing before you attempt to screw the housing down, or you will be very sad; both because you'll have to disassemble it again, and because you'll probably jack up your cord and have to replace the reel, which is what we're trying to avoid.
Test machine. If it works: party. If not, you will have to replace the cord reel.
For further clarification on the process, contact me.
Good luck,
-R
SOURCE: Miele 5000 vacuum cleaner stopped during use. no lights on
could be your retractable cord assembly's contacts..
push the power on while pulling out the cord. see if it tries to start.
SOURCE: Miele s571 vacuum cleaner power surges up and down
I just repaired the same problem. It is not the motor. There is a defective capacitor in the regulator. Large grey capacitor should have a value of 0.22uF/275V. It was in my case just 85uF. Changed capaitor and it was OK.
SOURCE: Instruction required for the removal of a full
Sure thing, the best thing to do is to have a look at the manual I have found here for you. The part you are looking for is on page 25 of the manual, complete with pictures and everything.
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
Here is the manual:
http://www.miele.co.uk/Resources/OperatingInstructions/S%205211_5781.pdf
Testimonial: "Thank you very much,we have missplaced our operating manual so this is just what we require,again our thanks"
