Question about Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint WMA31 Washing machine will not spin
Will not spin on single item programme
  • 1 more comment
  • gingfahp Dec 01, 2008
    When I press start botton, it did regulary sound as if it work fine, water flow in and out(drain), But machine did not spin. What can I do???
  • sarahjane123 Feb 23, 2009
    it makes the same sounds water flows though and drains but it will not spin at all do no how to solve this problem
  • Jodiwoo Mar 25, 2009
    Mine is a WMA30 with the same issue. Bearings gone now too so time to replace I think...........
  • 639 Answers
Dear friend,
ngfam at you service!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 26, 2008
Washing but not spinning
sounds like brushes in motor just take main motor out check brushes if any problems get back in touch and il help you thanks
Jan 05, 2014 | Hotpoint WMA31 Front Load Washer
Hotpoint aqaurius wma31 washing still wet after spin cycle is the problem with belt tension
Dear Scotty12345,
It would not hurt to check the belt tension, but also consider looking at the thermostat, speen speed of the motor, and if there is a reset button on the machine. If there is a reset button, try pressing that, it may fix the issue if the machine spins with the element on.
If the above instructions do not help, get hold of me again and I will investigate the matter further for you.
Yours sincerely
Ouszen
Feb 07, 2012 | Hotpoint Washing Machines
My hotpoint aquarius wma31 washing machine won't drain any suggestions???
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 17, 2010 | Washing Machines
My Hotpoint WMA31 will not drain - the smell is
check for blockage under cap bottom of washing machine
May 26, 2010 | Hotpoint WMA31 Front Load Washer
My hotpoint will start a wash then after about 5- 10 mins just stops?
could be motor brushes are worn if not spinning also...Quite simple to fit
Nov 17, 2009 | Hotpoint WMA31 Front Load Washer
Washing machine noise spinning
Here are a series of free videos to help you with your bearing problems and how to fix them
For all your free videos on appliance repairs remember to mark us down and leave feed back please
For all your parts visit our site http://www.apart4u.co.uk
This first video shows you how to diagnose the problem
The next Hotpoint video is on how to take the drum out
This Hotpoint video will show you how to change the bearings in the drum tub
the last one will show you how to change the spider or drum support as they are known
Feb 12, 2009 | Hotpoint WMA31 Front Load Washer
Filter
take off rear bottom panel.
you will see a large diameter pipe going from bottom of machine to pump. take off this pipe at the machine end - careful, lots of water may come out.
filter is located inside this pipe. remove and clean
Aug 31, 2008 | Hotpoint WMA31 Front Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
601 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
