Question about Vulcan AUW230A Heater
Vulcan pyrox wall heater has f1 fault what is f1
  • Paul Jun 14, 2016
    Hi I have had problems with this heater for 7 years. Guess I shouldn't have bought it off a plumber...
    It's always got f1 errors. I pulled out the fan and cleaned out all the dust. I also cut off the bottom green capacitor sensor altogether and then rejoined it. I leave this on the outside of heater with the resister fully out of the circuit. When it stops ( which it still does but at least it pumps out 5 mins of heat) I untwist the wires to re enable the "faulty" capacitor - and this enables the fan to start again.. Sounds really dodgy but it sort of works for a bit?
    Any better suggestions on how to fix?
5 Suggested Answers
  • 403 Answers
SOURCE: The Unit is maybe 2-3
replace the t-stat
Posted on May 25, 2011
mikeywaf
  • 346 Answers
SOURCE: I have a pyrox vulcan
Hello Chilly - First I'd like to know if this is a new unit or one that has been working until now.
If it had previously working are these the steps you're going through to start it?
START-UP SEQUENCE 1. Press the ON / OFF button. 2. Raise the temperature to HIGH so that the heater calls for heat 3. Within 10 seconds the gas valve will open and the sparker will function. Ignition will commence on a low gas rate and move to high fire after 3- 5 seconds (if high is selected on the control) 4. Within 5 seconds the flame sensor will prove the flame. 5. The fan will not operate until the fan thermostat switch has sensed temperature rise. This may take 2 or 3 minutes. 6. The fan will then start on a low fan speed and after 3 - 5 seconds move to high speed (if High is selected on the control)
If that is or is not what you have been doing let me know and we'll go from there.
Regards,
Mikeywaf
Posted on Mar 26, 2011
  • 661 Answers
SOURCE: pyrox /vulcan model no 4720006
Hi Chastrix,
Are you follow the below steps to start up your device?
  • First Press the ON / OFF button
  • Then you need to raise the temperature to HIGH so that the heater calls for heat
  • The you will find that within 10 seconds the gas valve will open and the sparkler will function and Also Ignition will commence on a low gas rate and move to high fire after 3- 5 seconds (only if high is selected on the control)
  • Within 5 seconds the flame sensor will prove the flame. 5. The fan will not operate until the fan thermostat switch has sensed temperature rise. This may take 2 or 3 minutes.
  • The fan will then start on a low fan speed and after 3 - 5 seconds move to high speed (if High is selected on the control)
Hope this helps..:)
Let me know in case you have any queries.
Posted on Jul 04, 2011
richroth
  • 9472 Answers
SOURCE: We have just purchased a
Information is very tight from the manufacturer on the error codes. You will need to contact them at one of the numbers below.
For Metro Service only ring the numbers below. South Australia/ (08) 8307 5230 Northern Territory New South Wales / (03) 8795 2457 Australian Capital Territory Western Australia (08) 9454 1000 Victoria/Tasmania (03) 8795 2456 Queensland (07) 4634 1803 Outside Metro areas please contact your nearest Climate Technologies Service Provider. New Zealand (ABERGAS Ltd) 0800 161 161
Regards, Richard
Posted on Jul 30, 2011
Pyrox wall heater turns off after an hour running and Er 12 is on there
Seems like you need to call the Pyrox to find out. If you need more questions for your AC Repair needs, check us out online.
Jul 11, 2017 | Heating & Cooling
Does Vulcan Pyrox gas wall furnace have a filter? It seems to cycle on and off too often and the gas seems too high. Also it makes a bang when reigniting. How can I turn the gas down inside it?
get it serviced by a licenced gas fitter / plumber. Should be serviced every two years. Don't risk your life via carbon Monoxide poisoning get a licenced gas fitter /plumber to assess the unit.
Jul 12, 2015 | Vulcan Heating & Cooling
Trying to locate replacement parts for my gas wall heater
http://www.enviro-friendly.com/bonaire-gas-wall-furnaces.shtml
Bonaire pyrox is the old Vulcan company
Standard Appliance Parts Sacramento California can get you anything you need as well.
Apr 05, 2015 | Vulcan Heating & Cooling
F1/08 vulcan fault code
Hi Geoff,
Is your heater a ducted gas heater how old is it and what does the wall control look like.
May 10, 2014 | Heating & Cooling
Bonaire Vulcan ducted heating system flashes F08 and HC 01. What do I do?
I was able to fix my Pyrox ducted gas heater (flashing between HC01 and F08 by pressing the reset button on the main PCB located in the main heating unit.
The reset button is located next to a set of indicator led's. It's easy to get to by just removing the covering shroud.
May 02, 2011 | Heating & Cooling
Pyrox Vulcan gas wall furnace.
my pyrox wall furnace has a digital pad it turns off & on but i cant turn the heat or fan uo or down its 4 weeks old
Jun 13, 2009 | Heating & Cooling
Error f1 3
What did you find out about this code? did you contact Pyrox? ask them the code meaning. if it is a need for a tech then thats the way to go they should be able to advise you.
Jun 09, 2009 | Carrier 36KCARMS Air Conditioner
Error code f1 on vulcan basic deluxe
Ck and ensure there is a pilot light.No pilot light, no gas.
May 26, 2009 | Heating & Cooling
Vulcan AUW230A Heater Logo
1,139 people viewed this question
Top Vulcan Heating & Cooling Experts
Paul Carew
Oloyede Monsuru
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Vulcan Heating and Cooling Expert? Answer questions, earn points and help others
